Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Dec 9, 2016 at 4:51 PM
    #8261
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    8 oz trigger are u freakin rediculous. My deer rifle says it came set at 2lbs i assume it to be closer to 2.5-3lbs in reality, i couldnt image one being half that weight much less a quarter or less
    smugly and scottalot like this.
  2. Dec 9, 2016 at 4:56 PM
    #8262
    Member1Zillion
    Member1Zillion Involuntary Kamikaze Co-Pilot
    Big Whiskey, WY
    '01 TRD, '17 Tundra, '07 FJ Cruiser, 94 PU, '18 T4R, '84 PU
    This, that, & the other thing
    Still kickin! Barely, I gotta have surgery on my neck here pretty soon, 2 discs are basically nonexistent, so yeah....good times! You'll probably see me more in here when I'm healing from that little ordeal. What about you?
    scottalot likes this.
  3. Dec 9, 2016 at 4:58 PM
    #8263
    Member1Zillion
    Big Whiskey, WY
    smugly likes this.
  4. Dec 9, 2016 at 4:58 PM
    #8264
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Actually, not to sound like a Cliff Claybin, but it's the other way around, you exhale during the trigger pull, to fully explain the trigger, it is a hybrid two-stage trigger the first day age goes to 1.3 ounces and then the second stage is introduced and brakes at 1.11 ounces. So although the trigger itself is only 8 ounces there is technically a built in safety and pre-trigger involved
    scottalot[QUOTED] likes this.
  5. Dec 9, 2016 at 4:59 PM
    #8265
    smugly
    Doug
  6. Dec 9, 2016 at 5:02 PM
    #8266
    smugly
    Doug
    That sounds like a pain in the neck, LOL, just kidding. I myself got my left hand caught up in a 2 foot circular saw blade at work. I did keep all my fingers as of now but definitely have some recovery time ahead of me.
  7. Dec 9, 2016 at 5:02 PM
    #8267
    Member1Zillion
    Big Whiskey, WY
    Thanks man, not to sound like a d!ck but are those balls hangin off your little prayin' dude's chin?:eek: They oughta call that little emoji "ballchinian":notsure:
  8. Dec 9, 2016 at 5:03 PM
    #8268
    Member1Zillion
    Big Whiskey, WY
    2 Feet? That sounds like a ripsaw blade! Daumn!
  9. Dec 9, 2016 at 5:05 PM
    #8269
    smugly
    Doug
    The funny thing is according to Ruger's website the triggers on the RPRs are supposed to be between 3 1/2 and 5 pounds adjustable, but when I went to pick mine up and tried the trigger, and having prior good trigger weight knowledge, new immediately something was up and that the trigger was way below 3 pounds so when they asked me if I was going to take it obviously the answer was hell yeah! I'm guessing the trigger building guy at Ruger was in a real good mood on a Friday afternoon when he built mine .
  10. Dec 9, 2016 at 5:07 PM
    #8270
    smugly
    Doug
    It's definitely not a party I ever want to go to again!i'm actually having flashbacks of the sound the blade made when I hit it
  11. Dec 9, 2016 at 5:07 PM
    #8271
    yota243
    E.J.
    north Alabama
    7.62 what? I assume u mean x51, in that case i would think it to be somewhat comparable to a .308 since they are the same deminsions. Likewise the 7.62x54r should be in the same ball park. But if u mean x39 u will be severely out classed by the formers and other aforementioneds.
  12. Dec 9, 2016 at 5:07 PM
    #8272
    Member1Zillion
    Big Whiskey, WY
    Are you guys talking about Echo triggers or the electronic ones? I ordered an Echo. Should be here in about 6 weeks.
  13. Dec 9, 2016 at 5:10 PM
    #8273
    smugly
    Doug
    That should be a fun billed!
  14. Dec 9, 2016 at 5:11 PM
    #8274
    Member1Zillion
    Big Whiskey, WY
    Why would anyone compare a .308 to a 6.5? They have completely different ballistic coefficients and one is lighter grain and one heavier. They were designed for different jobs.
  15. Dec 9, 2016 at 5:12 PM
    #8275
    Member1Zillion
    Big Whiskey, WY
    Yes.
  16. Dec 9, 2016 at 5:18 PM
    #8276
    smugly
    Doug
    I am a machinist, and I've never done an 80% receiver, rock on!
  17. Dec 9, 2016 at 5:19 PM
    #8277
    Member1Zillion
    Big Whiskey, WY
    Yes, but a drill press with good bits and a rotary vise with good mill bits helps tremendously.
    smugly and scottalot[QUOTED] like this.
  18. Dec 9, 2016 at 5:21 PM
    #8278
    Member1Zillion
    Big Whiskey, WY
    Wuss, LOL! They're only $50 for a polymer. Give it a try man. Worst that can happen is you're out a little dough. Practice on plastic, perfect on billet.
  19. Dec 9, 2016 at 5:23 PM
    #8279
    Member1Zillion
    Big Whiskey, WY
    I use heat shrink on my drill bits, then coat them liberally with petroleum jelly as to not disturb the jig. The heat shrink will be the weak link and save the plastic jig. Drill straight and true and you should have success.
  20. Dec 9, 2016 at 5:24 PM
    #8280
    Member1Zillion
    Big Whiskey, WY
