Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Jan 1, 2017 at 1:45 PM
    #8701
    Soflanick
    Soflanick Well-Known Member
    Nick
    FLORIDA
    2001 tacoma prerunner
    5100 front, 5125 rear, 2"all, old ARE topper, 16x8 XD enduro's on 265/75r16 KO2's
    had one, sold it, didnt like the thumb safety, but never had a misfire with it.
    scottalot likes this.
  2. Jan 1, 2017 at 1:48 PM
    #8702
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Yeah thats the only downside i have heard from it really but the shields have a similar safety now dont they? Also couldnt u just leave it off?
  3. Jan 1, 2017 at 4:48 PM
    #8703
    Soflanick
    Nick
    FLORIDA
    the shields have both. I guess you could leave it off, but its another step that could go wrong under a stressful situation. also the reset was a full reset if i remember correctly. and there wasn't much of a aftermarket support for it.
  4. Jan 2, 2017 at 11:21 AM
    #8704
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Well, After 2 months this finally came in.......FN FNS 9mm compact
    uurx, Lord Helmet, SilverII and 5 others like this.
  5. Jan 2, 2017 at 2:55 PM
    #8705
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
  6. Jan 2, 2017 at 3:31 PM
    #8706
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Where'd you pick that up?
  7. Jan 2, 2017 at 3:32 PM
    #8707
    IPNPULZ
    going to be fun!
    My local dealer. You want one he has one more I can call him and tell him to hold it?
  8. Jan 2, 2017 at 5:06 PM
    #8708
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Adjusted the angle of my crossbreed with my shaved mag plate and it's so much better. Sucks into the body without being noticed.
  9. Jan 2, 2017 at 7:17 PM
    #8709
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Rifle is:
    Walther KK Match - Silhouette
    0.22 l.r.
    600 mm barrel length
    1060 mm overall length
    4.2 Kg base weight (excluding compensator and B&L 6-24X scope)
    240 gram compensator on a custom barrel extension
    Match trigger 3-way adjustable for Trigger Weight, Slack and Let-off Point
    Crafted in West Germany
    Base of the forestock is a custom Delrin plate designed to rest on a Delrin rail to minimize any movement, except fore/aft.
    Pistol is:
    Anschutz Exemplar
    0.22 l.r.
    5 round magazine
    Acquired these about 33 years ago. Still my favorites.
    SilverII and Member1Zillion like this.
  10. Jan 3, 2017 at 2:18 PM
    #8710
    -dustin
    -dustin Well-Known Member
    Leander, TX
    2020SWDCSBTRDPROFTW
    Tips/ tricks/ links to products that y'all like for cleaning this Glock I just got. I have a basic kit. Wondering if y'all have preferences for cleaners or oils.
  11. Jan 3, 2017 at 2:49 PM
    #8711
    IPNPULZ
    going to be fun!
    Toss it in the dishwasher done!
    smugly likes this.
  12. Jan 3, 2017 at 2:56 PM
    #8712
    -dustin
    Leander, TX
    2020SWDCSBTRDPROFTW
    did that last night. should i just spray some WD-40 on it and call it good?
  13. Jan 3, 2017 at 3:05 PM
    #8713
    IPNPULZ
    going to be fun!
    Usually what I do is pull the slide off spray the internals with carb cleaner toss it in the DW let it run 30 minutes go out in the garage blow it out with the compressor. Oil internals in select spots and use Amsoil 20/50...But again I only clean my Glocks about every 3000 rounds if that...
  14. Jan 3, 2017 at 3:49 PM
    #8714
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Noooooo! Never use WD-40 on any firearm, airregardless of what any person might want to tell you. It's not a lubricant, it is an emulsifier
    IPNPULZ likes this.
  15. Jan 3, 2017 at 3:58 PM
    #8715
    smugly
    Doug
    Rem-oil is always a safe call. Here is a photo of some good examples. No this is not the Bible of what you should always use, but good starter examples. The first three are cleaners and the rest are various forms of lubrication
  16. Jan 3, 2017 at 4:19 PM
    #8716
    smugly
    Doug
    I have never seen that rifle before ! Hmmmm
  17. Jan 3, 2017 at 4:51 PM
    #8717
    -dustin
    Leander, TX
    2020SWDCSBTRDPROFTW
    I was just kidding. I've got Rem Oil and Hoppe's 9 cleaner.
    What about jags and brushes? Any special there?
  18. Jan 3, 2017 at 5:36 PM
    #8718
    smugly
    Doug
    I just wanted to make sure that I squash that notion for anybody reading it, or people just starting out. :rimshot: As far as the jags and brushes, I don't really see one brand being better over another but I myself prefer using nylon brushes over brass brushes.
  19. Jan 4, 2017 at 10:17 AM
    #8719
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    423 TACO[QUOTED] and smugly like this.
  20. Jan 4, 2017 at 10:22 AM
    #8720
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Has anybody used the Colt branded gun lube/grease? It's in a small aerosol can.
    Found like 4 cans the other day, never used it, not sure they still work but figured I'd ask and see in case I should just toss them in the trash.
