Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Feb 3, 2017 at 1:24 PM
    #9141
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    They are certainly on the backside of their life, being 8 to 9 years old. I believe they say they generally last somewhere in the area of 10 years but I have heard people get much longer out of them
  2. Feb 3, 2017 at 2:21 PM
    #9142
    96accord
    96accord Well-Known Member
    Jeff
    Baltimore, MD
    2015 Honda Accord EX-L V6
    Brass vs Aluminum casing.
    What's the difference? Advantages/disadvantages?
    This would be for range use.
    Thanks.
  3. Feb 3, 2017 at 2:36 PM
    #9143
    smugly
    Doug
    If for ranger use, aluminum is fine. The advantage to brass over aluminum is obviously reloading, and selling your brass to reload. Obviously, at the range you wouldn't be collecting up your spent casings. Aluminum will expand more in the chamber than brass, so in some applications there might be ejection difficulties resulting in stove piping and such,
  4. Feb 3, 2017 at 2:39 PM
    #9144
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    10 yrs is the halflife of tritium. So, theoretically, there is half as much radioactive material left after 10 years, which means less excited phosphorus and 50% dimmer sights at the decade mark. I don't know if the phosphorus itself degrades or not.
    I installed a set of Trijicon HD sights on my G20 today...they seem really great so far!!
    3378jakesr5 likes this.
  5. Feb 3, 2017 at 3:06 PM
    #9145
    44357
    44357 Whithersoever...
    Eric
    Desert RATS
    2017 T4R ORP MF
    For range use = cheap serviceable ammo
    Brass:
    Cheap = Reload! Value in shell (cost more off shelf)
    Serviceable = proper case expansion, natural lubricity, more accurate, less likely to cause failure.
    Aluminum:
    Cheap = off shelf low price (unable to reload)
    Serviceable = great corrosion resistance, less accurate, some platforms will have failures (notably melting onset temperature)
    Steel:
    Serviceable = less expansion, less lubricity, less accuracy, and some platforms will have failures.
    IMO Good Brass/reload is the way (you can reload cheap plink rounds or go full OCD to squeeze accuracy or build home defense/game specific loads by choosing projectile/bullet and powder)
  6. Feb 3, 2017 at 3:40 PM
    #9146
    smugly
    Doug
    That's my point, once they've gone to 50% dimness. There just not that effective, you have to work to see them, where as when there are new they jump out at you. but yes you still can see them,
  7. Feb 3, 2017 at 3:43 PM
    #9147
    Polymerhead
    Missouri
    I disagree with the lumping of steel & aluminum together.
    I would say that aluminum has equal reliability to brass, assuming all other components are of equal quality. Aluminum expands just as well as brass in a chamber.
    Steel cases do sometimes have lacquer coatings that leave residue & can build up, causing malfunctions if not removed.
    Aluminum pistol ammo is good to go.
    44357[QUOTED] likes this.
  8. Feb 3, 2017 at 3:45 PM
    #9148
    Polymerhead
    Missouri
    I don't disagree. I would not spend money on 10 year old tritium sights.
  9. Feb 3, 2017 at 3:52 PM
    #9149
    smugly
    Doug
    I will simply say it like this, I own a shooting range. So I have seen much much more than the average fair share of bullets. And aluminum does show up more times than brass with problems.
  10. Feb 3, 2017 at 3:54 PM
    #9150
    Polymerhead
    Missouri
    What type of problems? I'm always interested in market research. Something based on the aluminum ammo itself? Or is it that cheaper guns are fed more aluminum because it's cheaper?
  11. Feb 3, 2017 at 3:55 PM
    #9151
    smugly
    Doug
    Stove piping and failure to eject as I already stated.
    44357 likes this.
  12. Feb 3, 2017 at 3:58 PM
    #9152
    BananaPeelOut
    BananaPeelOut Well-Known Member
    Ben
    NH
    2005 silver access cab TRD Off-Road
    Kenwood Headunit, CB radio setup, wind deflectors.
    The new CZ p10c fits into Glock 19 holsters, at least some. Skip to the 15 minute mark for proof! (Or watch the whole thing if you wanna check out the gun) Also Im not sure how well it would work, if at all, if you add in a light.
    https://www.youtube.com/watch?v=r1zWm09BOrM
    StZu likes this.
  13. Feb 3, 2017 at 3:59 PM
    #9153
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    o i forgot ot add make sure you use a die to bell the case a bit. You need to bell the mouth so youll scrap the coating off when you seat it. Kind of like loading pistol ammo. I got a Lee universal die and it worked fine
    3378jakesr5[QUOTED] likes this.
  14. Feb 3, 2017 at 4:10 PM
    #9154
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Yup already got that on the way, got some hornady 208's for subsonics and some 4227 to add one more to the party for load work up.
  15. Feb 3, 2017 at 4:11 PM
    #9155
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Yall better watch out for doctor octopus with all this tritium... Also you can sometimes you can find companies that reload 1 shot brass and they are pretty cheap and offer all the benifits of brass well because they are brass
    Supra4x4 and Polymerhead like this.
  16. Feb 3, 2017 at 4:18 PM
    #9156
    yota243
    E.J.
    north Alabama
  17. Feb 3, 2017 at 4:18 PM
    #9157
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    You can get brass case ammo for almost the same price if not a little cheaper than alu case at walmart last time I looked.
    If you have no intentions of picking up brass and reloading, anything will be fine as long as it works in your pistol...some eat steel case fine while others don't. Try out a few and go with whats cheapest.
  18. Feb 3, 2017 at 4:37 PM
    #9158
    96accord
    Jeff
    Baltimore, MD
    Thanks for the reply.
    The range does allow collecting of your spent casings but I will not be reloading.
    Speaking of Walmart... I tried out the aluminum and the brass cases (9mm) that I bought from Walmart this past Wednesday at the range and I didn't notice any difference (it's my first handgun tho).
    It was roughly a $3/difference per box (50 rounds).
  19. Feb 3, 2017 at 4:44 PM
    #9159
    pittim
    Pennsyltucky
    Boujee Prius
    Mine has cheap brass case (Perfecta) and it's slightly cheaper (like, 10c a box) than the Federal aluminium. If both run fine, I'd get the brass since people will pick it up at the range to sell or reload thus keeping everything cleaner.
    96accord[QUOTED] likes this.
  20. Feb 3, 2017 at 5:04 PM
    #9160
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    People who dont pick up their own brass amaze me. Its leaving free money behind at a range. Might take a bit before you can sell it (quantity wise). 1k of 9mm brass, uncleaned and not processed can be sold for 20 bucks. Other calibers can be sold for more. Silly not to collect it and sell it off once a year or whatever and just have a bit of extra beer money.
    I wont go to a range that doesnt allow me to collect my own brass. Its mine not theirs and I hate the "soon as it hits our floor its ours" mentality of some ranges.
    44357, 96accord, smugly and 1 other person like this.
