Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Sep 22, 2018 at 11:27 AM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    If you want a PCC in 9mm, I'd go with a built-up AR pistol with a brace, CZ Scorpion with a brace, or a Hi-point 995TS in an MBS-95 bullpup chassis. My buddy has the bullpup and it's awesome, flat shooting (for a 9mm) and the only jams it's had are the suckass promags. OEM 10 rounders and redball 20's work flawlessly. It's eaten bad brass case reloads, steel case, and regular fmj without issue.
  2. Sep 22, 2018 at 11:35 AM
    azshooter40
    azshooter40 Well-Known Member
    Robert
    Chandler, AZ
    2020 OR 4x4
    Hope to be able to do that once I retire and get out of the city!!!!
  3. Sep 22, 2018 at 11:35 AM
    azshooter40
    Robert
    Chandler, AZ
    2020 OR 4x4
    Agree!! Those are so much fun!
  4. Sep 22, 2018 at 1:18 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    I'd vote the cz scorpion or an mp5 clone. A 16" in 9mm really doesn't do much other than add weight. Youll generally gain some velocity buts it pretty negligible over the 4-6" barrels.
    I like my zenith mp5-k clone cause...its an mp5 lol. But the scorpion is fun too especially with the carbine length handguard and "tucked" suppressor
  5. Sep 22, 2018 at 1:42 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I have a 400yd gong...technically not on my property But the neighbor doesnt care I have it out there. and he allows me to hunt on the property. I do wish I had a 10plate handgun/rifle target :)
  6. Sep 23, 2018 at 8:21 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Stupid question, is this line around the case normal?
  7. Sep 23, 2018 at 8:23 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Crimp line, in my experience they’re typically higher than that, shouldn’t be dangerous to shoot as bullet setback looks normal.
  8. Sep 23, 2018 at 8:38 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    It is called a cannelure. It is meant to prevent the bullet from getting pushed into the case from chambering.
    Some have had issues of separation on extraction where the case split and the section forward of the cannelure stayed in.
    95 taco likes this.
  9. Sep 23, 2018 at 8:57 PM
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    Like this one. Unsure if it was a double charge or worn out brass.
    Blew out an M&P frame.
    Toyota Kawasaki, Lawfarin and 95 taco like this.
  10. Sep 23, 2018 at 9:07 PM
    Ayeele
    Ayeele Well-Known Member
    Houston, Tx
    18 TRD Pro, 04 DCSB 4x4
    Getting tired of shooting this m240h.. why cant we get mini guns like the Airforce and the navy lol
  11. Sep 23, 2018 at 9:10 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Wanna trade jobs?
    MadDaddy and Lawfarin like this.
  12. Sep 23, 2018 at 9:11 PM
    95 taco
    95 taco Battle Born
    Double charge would be my bet, based on both the Cannelure separating and the base blowing out like that. Although it’s possible the brass was weak enough to do both with a standard charge I don’t see it being very likely.
  13. Sep 23, 2018 at 9:13 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Becuase, that'd be something like fun and you'd waste too much ammo... :hattip:
    95 taco likes this.
  14. Sep 24, 2018 at 4:39 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    Running my SSO/SPOSN rig at the last 3 gun match.
    EubeenHadd and smugly like this.
  15. Sep 26, 2018 at 6:04 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    SOOOOO! what did you end up with??????:popcorn:
  16. Sep 26, 2018 at 2:23 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Bigdaddy4760 likes this.
  17. Oct 1, 2018 at 3:22 PM
    relkins0413
    relkins0413 Well-Known Member
    Kings Mountain, NC
    2013 Silverado 2500HD Duramax
    Any Savage gurus in the house?
    I picked up this 308 for fairly cheap and after researching for a couple days I have finally narrowed it down to a model 10 PSR. There’s not much info out there other than it seems to be a neutered down Model 10 FCP. It does not have the accu stock or the one piece scope mount and has a 4 round flush fit magazine. Stock options also seem to be limited due to the bottom bolt release.
    This is my first Savage and for the most part it seems to be a solid gun. The accu trigger is feather light.
    I’m going to get rid of that corny muzzle brake and put some better glass on it. I should be able to make it out to the range tomorrow and see what it can do as is. Hopefully there won’t be many people there for me to offend with that obnoxious brake.
    So has anyone else seen or had experience with this bastard of a rifle?
    SilverII and KRAMERICA like this.
  18. Oct 1, 2018 at 4:05 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Looks like I might be going with a Remington 700 XCR .308 Bell & Carlson stock
  19. Oct 1, 2018 at 4:36 PM
    smugly
    Doug
    some nice handguns there!
  20. Oct 1, 2018 at 4:37 PM
    smugly
    Doug
    :anonymous:
