Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Jan 19, 2019 at 6:22 AM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    Both of mine fit just fine. Only downside is I’m taking my Corolla to Texas to hunt and the case doesn’t fit in the trunk:annoyed:
  2. Jan 19, 2019 at 6:27 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    If that ain’t a dream job I don’t know what is
    MadDaddy[QUOTED] likes this.
  3. Jan 19, 2019 at 8:07 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    The perks are neat but it is a grind this time of year.
    95 taco likes this.
  4. Jan 19, 2019 at 8:08 AM
    MadDaddy
    Many & varied
    Yeah, I need something capable of fitting in my Taco with two car seats in the rear.
  5. Jan 19, 2019 at 9:06 AM
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    Once you have one in a booster as versus in something that uses LATCH it's a lot easier to get to those back seat storage compartments.
    Sub2k time? Or some sort of takedown rifle?
  6. Jan 19, 2019 at 10:16 AM
    MadDaddy
    Many & varied
    Yeah, I need a takedown for a truck gun. Most likely a 10/22, sooner than later.
  7. Jan 19, 2019 at 10:19 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Out of curiousity, anyone running a larue m4? From the reviews their rifles are hard to put down once people start shooting. I’m digging the POf setup with a floating barrel and muzzle break, but get the vibe that larue still can outshoot it any day. I have some larue furniture and it def is quality stuff for sure.
  8. Jan 19, 2019 at 11:17 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  9. Jan 19, 2019 at 12:44 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    I got to shoot a larue AR pattern rifle chambered in 260. Thing was a tack driver. Probably could do 1" groups at 200yds or very close to it.
    wilcam47 likes this.
  10. Jan 19, 2019 at 1:00 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    That’s what I have been hearing too. Originally I was set on getting a POf warhog, but it sounds like the larue is just unmatched.
  11. Jan 19, 2019 at 3:48 PM
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    :hattip:
    :thumbsup:
    You know I'm a fan ;)
    POF's get pretty good reviews plus they're local. Do they make a 6.5 caliber?
    JP Rifles also make an astounding rifle. Top shelf for sure.
    Larue has their OEM rifle or their Ultimate Upper kits (buy their lower after buying the UU kit) The UU kits are hard to beat price wise.
    TidBit: If you want to make it easier to shoot good groups and long range with less recoil stick to the .264 caliber bullets. These include 6.5 creedmore, .260, and 6.5 Grendel (although this is for a small frame AR). All of those use the same bullet (.264) just different weights. Better ballistics than 308 (at distance) and less recoil.
    .260 PredatAR (heavy barreled limited edition)
    5.56 PredatAR
  12. Jan 19, 2019 at 3:50 PM
    wilcam47
    Will
    Bourbon state
    Nice! What bi-pod do you have on it?
  13. Jan 19, 2019 at 3:55 PM
    Mike330R
    Far West Phoenix
    Atlas
    Tlook likes this.
  14. Jan 19, 2019 at 4:16 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Dammit mike you got everything! Alright I need to get out there and get schooled up. I had a chance to try out carters bcm build with that larue trigger drop in and man it felt good. So a drop in kit might be your recommendation? I’m about as green as it gets when it comes to ar building. Do some buy the ar in pieces and then simply put it together? I would figure getting a larue in pieces might be more costly then getting a full build from the get go?
  15. Jan 19, 2019 at 4:30 PM
    Mike330R
    Far West Phoenix
    Did you look at the links I posted?
    Click the UU link (add $200 for the cost of a lower) then click the factory 260 link.
    The UU kit is EVERYTHING except the lower.
    Factory rifle get you a few extras-different hand guard, gas block, etc.
    This is assuming you want the large framed rifle (308, 260, 6.5CM).
    Small framed rifles are a little less.
    Plenty of people in AZ that can help you build it.
    Coot83 and 95 taco like this.
  16. Jan 19, 2019 at 4:35 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Don’t bother with large frame ARs. Learn how to reload and the world of .308 case head size cartridges in the AR15 platform opens up. Less weight and bulk with 95% of the performance of the large frame AR10 size rifles.
    95 taco likes this.
  17. Jan 19, 2019 at 4:37 PM
    Mike330R
    Far West Phoenix
    .308 case in an AR15 frame? Only one I know of is the POF revolution rifle.
  18. Jan 19, 2019 at 4:48 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Case head size (.473”) vs the standard 5.56 (.378”). Most are made from either 6.5x47 Lapua or 6mm Dasher brass. They require special bolts and barrel extensions but other than that are standard AR15 rifles. The two I shoot are a 7mm Valkyrie pushing a 140gr Accubond at 2650fps from an 18” barrel and a 45 Velociraptor pushing a 250gr bullet at 2400fps in a 16” barrel. They are available in 22, 24, 26, 28, 30, 35 and 45 calibers right now.
    Holloman and Coot83 like this.
  19. Jan 19, 2019 at 4:52 PM
    Mike330R
    Far West Phoenix
    Ahh, ok. No experience using any of those oddball calibers.
    Would you recommend any of that to someone new to AR's?
  20. Jan 19, 2019 at 4:55 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    As long as they have an understanding of how to reload. The basic build and functioning of the rifle is the same as if it were a standard 5.56 but the process of loading andy tailoring the round to the rifle can be a bit more complicated.
