Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Feb 6, 2020 at 7:47 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Any reason not to consolidate these down to no box and single ammo can? Seems wasteful to only have 200 rounds each box.
  2. Feb 6, 2020 at 7:49 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Just if you care about lot numbers.
    95 taco[QUOTED] likes this.
  3. Feb 6, 2020 at 7:55 PM
    95 taco
    95 taco Battle Born
    I’m not that concerned about a recall, and I wouldn’t use the lot numbers for anything else...
  4. Feb 6, 2020 at 7:57 PM
    dfanonymous
    Recall isn’t what I would use lot numbers for but I think that answers the question. Pour those things loose in the box, and save space.
  5. Feb 6, 2020 at 8:05 PM
    95 taco
    95 taco Battle Born
    Pardon my nosiness/ignorance, what would you use lot numbers for?
    All 800 barely fit in one box, not sure when it will be used though as I don’t have a slower twist barrel to shoot these 50 grain projectiles through.
  6. Feb 6, 2020 at 8:17 PM
    dfanonymous
    Sorting. This still probably doesn’t apply to 98% of people. Also more so applies to match grade stuff, used for match grade stuff.
    Without going into immense detail, different lots will give slight velocity changes, and sometimes slightly different zeros. Different tooling and quality control standards at the factory. If you aren’t into knowing your ES and SDs on factory ammo, then it’s of no concern really. I only mentioned it because you said “any reason.”
    Vabunch and 95 taco[QUOTED] like this.
  7. Feb 6, 2020 at 8:29 PM
    95 taco
    95 taco Battle Born
    Good to know, I don’t even have a Chrono to track that data so it definitely doesn’t apply, but still good knowledge to have.
    dfanonymous[QUOTED] likes this.
  8. Feb 6, 2020 at 8:49 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Consolidate them in to loaded mags :thumbsup::D
    jeff b, PacNW_Taco, KY_Rob and 4 others like this.
  9. Feb 7, 2020 at 3:35 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Picked this up yesterday. Second CZ. First Dan Wesson.
    Think I should replace the grips for G10? I can't decide. Those wood grips are pretty sexy, but I like the grip on G10.
    IPNPULZ, Bagman, JimboAnz and 5 others like this.
  10. Feb 7, 2020 at 5:30 AM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    223 is dense, and a full can of 223 gets pretty heavy. Not as bad as some other calibers, but still considerable mass to lug around. I'd run with the condensed into mags option myself.
  11. Feb 7, 2020 at 5:37 AM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    I have replaced all my 1911 grips with G10 simply because of bite. They stay in my bears so much better....
  12. Feb 7, 2020 at 5:45 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I have these:
    https://www.tacticalinc.com/catalog/product/id-5154
    More expensive than brownells, but thet are nice. I'm leery of brownell's warning that "non OEM parts may not fit". I don't think I've got any Ruger OEM parts in mine and thet work fine.
  13. Feb 7, 2020 at 5:59 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    They really do have a good bite to them. Plus, they look awesome. Was looking at VZgrips and they told me they can do Bobtail grips.
  14. Feb 7, 2020 at 8:05 AM
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    Well, it would be easier to keep some here and there, and a little across the way, if you kept them the way they are. If your intent is to keep them together, then you really need to consolidate.
  15. Feb 7, 2020 at 8:14 AM
    jamesfishn09
    jamesfishn09 Well-Known Member
    2003 Tundra
    These are VZ grips on the C-Bob and G10’s on the Nighthawk GRP, many options.
  16. Feb 7, 2020 at 8:42 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    They look great.
    I like the super scoop on the DW too.
  17. Feb 7, 2020 at 1:43 PM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    Yeah I saw that warning on the Brownells ones. With the good reviews I took that more as CYA type note on their part.
  18. Feb 8, 2020 at 5:35 PM
    95 taco
    95 taco Battle Born
    I take the whole box to the range but it’s a good idea to simplify inventory! Thanks!
    wilcam47 likes this.
  19. Feb 8, 2020 at 5:59 PM
    KY_Rob
    Rob
    North East Ohio
    Palmetto State Armory is running a 1-6x24 Vortex Strike Eagle with mount deal, $249 (was $389) shipped with code VORTEX. Good until 2/10.
    These are pretty good middle of the road types of scopes. Really happy with the one on my poverty pony, so I figured another would go good on my higher end build.
    My eyes are getting to the point where an unmagnified red dot doesn’t get me nearly as far out as it used to, and price for high quality optics is almost obscene. Looks like I’ll be moving the MRO to the PC9 with this buy.
    six5crèéd and 95 taco like this.
  20. Feb 8, 2020 at 6:06 PM
    95 taco
    95 taco Battle Born
    Got some range time in tonight, tested the 10/22 build, it had some hiccups with Geco rifle (red box) and CCI standard but otherwise it shoots well.
    I also got to test the Larue trigger while practing 1R1 drills, it’s really nice and easy to shoot quickly.
    Check out how nasty the BCG is after 2-3 mags.
