Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Mar 3, 2020 at 10:37 AM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    It is one of those things I wish I'd been told when I bought my first handgun. Buy a Glock 19MOS, between the aftermarket support and history of reliability you cannot go wrong, and you'll get used to the brick grip soon enough.
    95 taco[QUOTED] likes this.
  2. Mar 3, 2020 at 10:58 AM
    Ayeele
    Ayeele Well-Known Member
    Houston, Tx
    18 TRD Pro, 04 DCSB 4x4
    Yeah that's what i was gonna ask. Kinda sucks.. would hate to have it flapping but also would hate having a leg strap . Maybe ill have to try that high ride. Its basically how we carry in the army with our m9
  3. Mar 3, 2020 at 11:05 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I’m leaning against MOS on my Glock purchases (as well as the S&W system) because the MOS system isn’t as strong as having a slide milled for a specific optic as well as introducing 2 extra screws to the component.
    But MOS does make sense for non-duty applications or for R&D purposes.
    Full disclosure: I’m going to get a CORE pistol from S&W because it’s the configuration I want, I’m a little nervous about it though.
    I agree with the options/compatibility aspect of the Glock 17/19 though.
  4. Mar 3, 2020 at 11:16 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    In what way is it annoying? PM me if you would like!
  5. Mar 3, 2020 at 11:55 AM
    Ayeele
    Houston, Tx
    You have to do 2 atf forms, 1 ceo (i think that's what it's called), send a copy to the sheriff of your county per every tax stamp. Also when traveling you have to notify all states in advance that you will have those NFA items. This makes just building a pistol much easier and cheaper
    Phoosa likes this.
  6. Mar 3, 2020 at 12:23 PM
    95 taco
    95 taco Battle Born
    CLEO sign off was eliminated via 41F (I think that’s what a member said the final designation was) so it’s just a notification sent to CLEO.
    The 5320.20 form (travel intention) is required for ATF items except for suppressors.
    IPNPULZ likes this.
  7. Mar 3, 2020 at 1:26 PM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    I did some digging, and I can get a Safariland 6390 for a P07 with a Surefire X300, but without the optic support. For those who have one, is there a part of the ALS system that runs near the top where the optic goes? I'm considering buying one and clearancing the holster where it would interfere with the optic but I can't tell where the ALS system runs inside the holster to be sure that I can cut the necessary parts off of the holster without otherwise interfering with the retention.
    95 taco likes this.
  8. Mar 3, 2020 at 1:30 PM
    95 taco
    95 taco Battle Born
    I’ll get you photos when I get home tonight, I have 3 non red dot ALS holsters and 1 red dot (the 6390 RDS) and I’ll get quality photos to compare the systems in them.
  9. Mar 3, 2020 at 3:17 PM
    IPNPULZ
    going to be fun!
    Your travel certs are good for a yr though right?
  10. Mar 3, 2020 at 3:58 PM
    95 taco
    95 taco Battle Born
    Yes, you can fill them out so that the travel dates are 1 day short of a year.
  11. Mar 3, 2020 at 4:59 PM
    95 taco
    95 taco Battle Born
    The modification would remove the pivot point of the ALS on both the 6 series and 7 series non-RDS holsters.
    This is my 6390 RDS for M&P with TLR-1, the pivot point (green) is very low (below the ejection port) and on the side (There's one on the opposite side as well).
    And the interior view. The red is the RDS hood, the blue is solid kydex, and the green is again an approximation of the pivot point.
    This is the 6 series (6360 I believe) ALS/SLS for M&P with TLR-1
    Exterior (green is again pivot point)
    And the interior, notice the ALS assembly is one piece in this holster moving the pivot (attachment) point to well above the ejection port and just in front of the rear sight.
    And for posterity, the 7 series, this one is for a Sig P320 with no light.
    And the exterior with the P320 installed to show how far up the slide the mount point is.
    mcharfauros likes this.
  12. Mar 3, 2020 at 7:50 PM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Damn, that rules out the modification path for me. Thanks!
    Unrelated:
    Finally sewed them on, trying to figure out how to add a couple more underneath now.
  13. Mar 4, 2020 at 4:47 AM
    jmd025
    jmd025 Well-Known Member
    Louisiana
    2010 TRD double cab 4x4
    I had the same concerns with the Glock mos and was pointed in this direction :
    http://www.chpws.com/product/holosun-glock-mos-adapter-plate-v3
    Plate is thinner , better posts to secure the optic , very tight fit with no gaps , Trijicon would stay on with no screws when placed into it .Edit : I did use a sealing plate as well
    I agree that a milled slide has pontential to be better than the mos setup , assuming it’s well executed
  14. Mar 4, 2020 at 4:58 AM
    95 taco
    95 taco Battle Born
    Nice! I wasn’t aware of those adapter plates, I’ll have to pick one up for my Glock 40 MOS.
  15. Mar 4, 2020 at 5:52 AM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
  16. Mar 4, 2020 at 4:57 PM
    Tom0662
    Tom0662 Well-Known Member
    Tom
    Iowa
    2016 TRDORSB
    This is what I used with my non mos G41. Lot of people don't know these exist.
    Remove rear sight and slide into dovetail.
    I have ran the crap out of this thing and it hasnt came loose or moved at all.
    Sight will of course sit a little higher.
    https://www.trijicon.com/products/details/RM44
  17. Mar 4, 2020 at 9:05 PM
    PacNW_Taco
    PacNW_Taco Get lost.
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    Peachy Peach air fesheners
    Any idea what these little pews are? Found a handful of them last weekend. They don’t appear to be shot shells as I scraped some of the blue coating off, and there appears to be a slug underneath.
    ‘CCI 9mm with ‘N’ ‘R’’ stamped as well.
  18. Mar 4, 2020 at 9:23 PM
    token3495
    token3495 Well-Known Member
    Kevin
    Snohomish
    08 4Runner
    Looks like that herters nylon jacketed stuff
    PacNW_Taco likes this.
  19. Mar 4, 2020 at 11:06 PM
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    That'd be my guess as well...
    https://www.targetsportsusa.com/cci...15-grain-total-nylon-jacket-3575-p-59019.aspx
    PacNW_Taco[QUOTED] likes this.
  20. Mar 5, 2020 at 6:33 AM
    PacNW_Taco
    Colby
    Tacoma, WA
    2016 Black DCSB OR
