Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Apr 2, 2020 at 10:18 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Try some Ballistol on all your wood. It has special chemical properties that makes it emulsify when mixed with water so it's perfect for any part of a weapon from protection to lubrication.
    https://ballistol.com/
    I use it on all my outdoor locks and have never had one seize. On my roller bearing hinged knives nothings better. It cleans and protects leather unlike anything else. Because it doesn't contain any toxic chemicals it's not only safe for the environment, and because it contains some isopropyl alcohol, in a pinch you can use it to help clean and disinfect a wound in the field until you can get some proper first aid.
    I've been using it for years. However, I just bought new fangled synthetic oil to try on my Glock. I'll give it a try and see what all the fuss is but most likely I'll just stick with my tried and true.
    EubeenHadd and six5crèéd like this.
  2. Apr 2, 2020 at 10:24 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    That’s my go to for everything. Leather, metals, wood. I use that on all my firearms.
  3. Apr 2, 2020 at 10:39 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hey Jeremy :wave: yea, it has an odd aroma and feels somewhat light which makes you wonder about it, but it just works on anything.
  4. Apr 2, 2020 at 10:48 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Counter question to the question....how much warning response time do you get? If you have motion detection at the beginning of the property and it takes an average person, say 2 minutes to get to the door then, sure, Kit up.
    However if you have just a 30 second response time, and you go for the weapon, you’ll need the ear pro right there. The problem is when people are in a rush, and under stress they tend cut out the things that are least important to their immediate and relevant situation.
    six5crèéd, 95 taco and El Duderino like this.
  5. Apr 3, 2020 at 5:51 AM
    GATacoRookie
    GATacoRookie Well-Known Member
    Phil
    Atlanta GA
    MGM TRD OR DCSB 4x4 AT. Mall Rated sticker
    Toytec Fronts. 18x9 Fuels on 285/65/18 TerraGrapplerG2's. LEDs everywhere.
    I certainly agree. I personally anticipate (and plan) on having verrrrry little time to do anything before me and the bad guy start dancing. I do have some early warning methods installed inside & outside the property/house to buy me a few more seconds to prep. Ear pro is certainly last on my list of kit necessities.
    six5crèéd likes this.
  6. Apr 3, 2020 at 5:58 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Not only are you going to have to have them close by the weapon, you are going to have to put them on and then remember to turn them on if they are noise cancelling. I use the Howard leight impact sport muffs. They work fine and aren't expensive. Esp when they go on sale. You have to turn them on by rotating the volume which I can see myself easily forgetting to do if it's go time. So then I would think I'm at a disadvantage at that point. But of course this can probably be minimized with practice and muscle memory.
  7. Apr 3, 2020 at 6:35 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'll probably catch some flak for this, but I'm not going to be going out and clearing my house john wick style if I think someone is in the house. My ass will roll out of bed and use it as cover, while I aim at the door to my master bedroom. That leaves me with enough time to don some ear pro. Stuff can be replaced, and I don't want the weight of killing someone on my conscience. As long as my wife and dog are in the room with me, that's all I care about.
    Edited because I quoted the wrong post.
  8. Apr 3, 2020 at 6:43 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    If I hear glass break or any other sign that there’s somebody actively in the house then I 100% agree, if it’s just the dogs aggressively barking in the back yard then I will check the house on the way to the back yard, verify that there’s nobody in the yard and verify that the doors are locked and alarm is set.
    EatSleepTacos[QUOTED] likes this.
  9. Apr 3, 2020 at 6:44 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's a good point. We have cameras both inside and out so my go-to is to check the cameras from my phone if I think anything is afoot, and then do a walk around and make sure everything is squared away.
    mcharfauros, EubeenHadd and RobP62 like this.
  10. Apr 3, 2020 at 6:45 AM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    Adding to this theory, I live in a two story with stairs that fold back on themselves. That is the most vulnerable point should I decide to play John Wick. So for me, use the choke point at the top of the stairs from down the hall, 14 yes away.
    Trying to clear a house, single handed, against unknown numbers and zero Intel seems like a death mission.
    You want me and mine, come get some!
  11. Apr 3, 2020 at 6:59 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I can see myself taking this route of defense too Randy. I think though, (after reading some of these posts) that I am missing something.
    Are you all talking about needing or wanting to wear hearing protection during your response to a home invasion because your weapon is too loud? I just want to be sure I am on the same page.
  12. Apr 3, 2020 at 6:59 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep exactly. It's very loud and will be disorienting if you have to fire it in the tight confines of your home.
    RobP62[QUOTED] likes this.
  13. Apr 3, 2020 at 7:17 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Here, some people may want a point of reference.
    Of course these figures below are generally meant to indicate extended exposure (8 hours).
    The motorcycle is for one with legal mufflers. A straight pipe 1100 cc motorcycle is measured closer to 125 dBA.
  14. Apr 3, 2020 at 7:19 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I shot my gun one time without ear pro in, never again. A single shot from my 9mm and my ears were ringing a bit. Damn guns, being all loud and shit.
  15. Apr 3, 2020 at 7:22 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I shot a .308 Browning lever action inside my bedroom once by accident, it was loud but didn't deafen me.
  16. Apr 3, 2020 at 7:38 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I think each person is going to be different, and some will obviously be more sensitive than others. It might also be determined by whether or not they are accustomed to extremely loud noises. Some people never experience those.
    My security siren alarm for example is pushing 110 dBAs. In the event of a break-in, it will not stop until I turn it off. Then the monitoring company will be calling me on top of that. If I don't answer the phone the police are immediately dispatched.
    Twizted, six5crèéd and shane100700 like this.
  17. Apr 3, 2020 at 7:39 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Is Ear Pro a brand or model?
  18. Apr 3, 2020 at 7:41 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's slang for ear protection, just a general terminology used for anything that'll protect your hearing.
  19. Apr 3, 2020 at 7:41 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Just my .02 here. I have had two attempted home invasions. First one in 2006 and the second one last year. I have cameras inside and out. The first one ended with me holding the POS at gunpoint until the Sheriff showed up. The second one ended with a K9 catching the POS in the woods behind my house. I have had a lot of training Military and civilian. Both times this happened the last thing I thought of was hearing protection. What if you accidentally shot a family member or child because you had on hearing protection and were unable to properly hear some faint sound that could have saved a life. OK rant over
  20. Apr 3, 2020 at 7:42 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I'm glad this is a BS thread. :devil:
    shane100700 and TomTwo[QUOTED] like this.
