Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Apr 23, 2014 at 10:18 AM
    #1961
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I started documenting the process for sending the shotgun back to Mossberg but they disappeared and haven't responded since. It was easier to just take it apart and fix it myself. I still like it, just disappointed in their customer service.
  2. Apr 23, 2014 at 10:21 AM
    #1962
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    KSG is just fine. UTAS is complete trash and you're better off taking the money you would use to buy that and throwing it directly into the toilet and then double flushing. It will cause much less stress.
    That sucks.
  3. Apr 23, 2014 at 10:23 AM
    #1963
    TCprerunner
    TCprerunner Well-Known Member
    Wondering if I could get some help with a at issue I am thinking its the extractor but want opinions.
    Out hunting the other night and at the end of the night the bolt hung open like my mag was empty (it was not) so I manually chambered a round with the charging handle went to shoot and just a click went to cycle the round and the whole bolt was jammed I had to completely remove the upper and then pull with alot of fource to get the bolt to come back and eject the round happend 3 times and I called it quits.. Now at home 1 of about every 6 rounds fails to eject. Brass or steel does not matter. Gun has less then 100 rounds threw it
  4. Apr 23, 2014 at 11:26 AM
    #1964
    TCprerunner
    Its a ar I built, all parts from PSA. Sorry thought I wrote that lol
  5. Apr 23, 2014 at 11:32 AM
    #1965
    TCprerunner
    Tried it with mulyipul mags and ammo same thing happens I may try running extra lube
  6. Apr 23, 2014 at 11:35 AM
    #1966
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    What lube you running? Iv had buddies have issues with cheap lube
  7. Apr 23, 2014 at 11:37 AM
    #1967
    TCprerunner
    Remington that's all I know will have to look when I get home
  8. Apr 23, 2014 at 11:40 AM
    #1968
    TexasPreRunner
    Anthony
    2011 PreRunner
    Hmm iv never had issues with rem oil, maybe try some frog lube you made need that little extra slide
  9. Apr 23, 2014 at 11:47 AM
    #1969
    TRD Auddie
    TRD Auddie NOT A FLAKE
    Austin
    Conyers, Ga
    03 TRD EC
    Is your buffer tube far enough in that it is retaining the buffer detent pin? I don't think this is your problem, but it is plausible.
    Any idea what is catching on the inside of the receiver if anything, if it isn't under-lubed? I.E. Can you see any bare metal or marring anywhere where there may be more metal on metal contact than there is supposed to be?
  10. Apr 23, 2014 at 11:55 AM
    #1970
    TCprerunner
    Could the castle not being loose cause this? It was only hand tight I had used loc tight bit I guess not enough it was not falling off though was just snug by hand
    And nope nothing seems to be catching that I noticed everything functions perfect when unloaded only have issues when cycling rounds
  11. Apr 23, 2014 at 11:57 AM
    #1971
    TCprerunner
    Mine didn't have a single problem till this night something's wrong I'm just ignorant with this stuff and don't really know what to look for
  12. Apr 23, 2014 at 11:58 AM
    #1972
    Ostrichsak
    Jer
    What type of firearm (guessing AR)? What buffer? What length gas system? What magazines? What ammo? Specifically what caliber and what chamber is your barrel? Who's BCG? Properly staked & assembled? Who's upper receiver? There's some other things that could help but that's a good start.
  13. Apr 23, 2014 at 11:58 AM
    #1973
    TCprerunner
    Its a 5.56 issue happens with both .223 and 5.56 I hunt with 5.56 and got the upper for that exact reason
  14. Apr 23, 2014 at 12:00 PM
    #1974
    TCprerunner
    And yes its a ar
    Everything is PSA about all I know I can get part numbers if that helps you when I get home. It happens with surplus mags my mag pulls and a few of a friends I tried. And has happend with my hogzilla rounflds steel and brass rounds and everything else I had to try to cycle.
  15. Apr 23, 2014 at 1:25 PM
    #1975
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Anybody here running Ameriglo Hack sights on their pistols?
    I'm not a fan of all white 3 dots, and none of my pistols are competition guns, so I'm thinking running 1 dots on them. I feel like the fluorescent paint with trit insert up front and solid back would make for a nice all lighting quick pickup sight system.
  16. Apr 23, 2014 at 6:06 PM
    #1976
    TRD Auddie
    Austin
    Conyers, Ga
    03 TRD EC
    It's not impossible that it not being quite tight enough could allow the buffer tube to shift just enough to get the detent out of whack and inadvertently retaining the BCG. :notsure:
  17. Apr 23, 2014 at 6:26 PM
    #1977
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Check the common stuff. Make sure you didn't install the bolt backwards. Pull the carrier & make sure the das tube looks straight in the upper receiver. Look at the barrel extension and make sure there's no primers in there, or up under the carrier. Pull the buffer & the spring & make sure there are no primers or shavings or gunk in the extension tube. I built a gun for a buddy one time & he kept blowing primers out of cheapo ammo and causing his upper to lock up. One was up above the gas key and really jammed the sucker up.
  18. Apr 23, 2014 at 8:48 PM
    #1978
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Anyone here conceal carry a glock 23/19? I got a 23 today and am looking for holsters
  19. Apr 23, 2014 at 8:57 PM
    #1979
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    I carry a 19 daily. I make my own index holsters. The one I normally use is a leather backed kydex holster. I modded my 19 to accept an Insight x2 light that is just past muzzle length.
  20. Apr 23, 2014 at 9:33 PM
    #1980
    TCprerunner
    Okay to avoid massive quotes this is to all the posts above removed and completely reinstalled everythingafter cleaning and oil problem still occurring everything on bolt appears fine but I now can give a exact discretion of what is going on.
    The at is functioning 100% unloaded. No issues. I can manually load a round (without a magazine) and the at again will function 100%
    I can again manually chamber a round insert the magazine and cycle the round ejects normally next round goes in. Here is where issues start any round being chambered from the magazine and the bolt will not fully set..
    I have 3 different types of magazines and happens with all 3 imi defense a cheap surplus and a mag pul. I have a friend bringing more mags over tomorrow to see if it happens with his..
    Any input on what could be going on?
