Firestone Air Bags and 1 inch Block
Discussion in 'Suspension' started by Equara11, Jun 2, 2012.
  1. Jun 2, 2012 at 9:22 AM
    Equara11
    Equara11 [OP] Member
    San Jose, Ca.
    '11 4x4 Dbl. Cab V6
    OME 885x front coils with OME shocks, Driver side coil Trim Packer, 10mm top plate spacers, Light Racing UCA's, 1 inch differential drop, swaybar relocate hardware, carrier bearing drop, rear Bilstein 5100 shocks with 1.5 inch block, Firestone Ride Rite Air Bags, front windows tinted.
    I'm having a difficult time finding an answer to my question......so here it goes..........
    My 2011 double cab TRD Off Road is running 1 inch blocks with the stock rear springs and OME shocks. I prefer not to remove the blocks. Does anyone know if the Firestone air bags will fit with my current set-up?
    Any advice will be appreciated.
  2. Jun 2, 2012 at 9:28 AM
    berg2065
    berg2065 Well-Known Member
    Phoenix
    11 reg cab 4x4
    5100's set at .85,eibachs, LR uca's, toytec 1.5" aal, ride rite bags, receiver hitch, ARE cap with bedrug, Thule rack, wet-okole cover, ultragauge, kenwood dnx5180 navi/receiver, ss rubi404 running factory doors and JL8
    They should fit, but you will need to make a custom bracket to help support the bottom of the air bag since the 1" block is going to give up a gap between the axle housing and the support bracket that comes with the air bags.
  3. Jun 2, 2012 at 11:47 AM
    Equara11
    San Jose, Ca.
    '11 4x4 Dbl. Cab V6
    I realize that the frame and the leaf springs raise as a unit when the rear is lifted with the block, so technically there should not be a problem. I'm just still thinking that the gap between the top of the axle housing and the spot where the air bag bracket gets installed on the frame, will be or looks too small to accommodate the actual bag. Hence, the custom bracket you mention? Would you happen to have a photo you can share of the bracket work you did for your 1.5 inch lift? Or, perhaps clarify further for me to figure it out if I am wrong in my thinking. Thanks!
  4. Jun 3, 2012 at 12:34 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    wouldn't it be easier to replace the 1" blocks with 1" lift shackles therefore removing the complication of getting the air bag mounts to work with the block?
  5. Jun 3, 2012 at 10:12 AM
    Equara11
    San Jose, Ca.
    '11 4x4 Dbl. Cab V6
    The shackles were a thought, but I think I still need more load support. The stock springs, as you know, sag way too much. And I do like the versatility of the air option. I have friends using air bags on all different type trucks and they love 'em. I'll probably just purchase them and see what happens. I could always return them if they don't work out.
  6. Mar 27, 2013 at 5:50 AM
    SimpleTaco
    SimpleTaco Member
    New Brunswick
    V6 4x4 Woddy
    K&N 3 inch and 285's to come
    Any updates? I Already have air springs and want to raise the rear a bit more. Dont want an AAl and cant justify a new leaf pack because I got the air springs.
  7. Jul 16, 2013 at 3:43 PM
    09 taco mark
    09 taco mark bc 4x4
    mark
    squamish bc
    09 trd sport leather
    3" lift, K+N intake, magnaflow exhaust, 32" rubber, ride right bags, spidertraxx spaces, 6" HID off road lights, pro comp rpd light bar, rs9000xl coilover, skyjacker 1.5 travel hydro7000 rear, 1" rear block kit
    I have an 09 trd dbl cab sport. My airbags are awsome but I also want the 1" block. One thing I know for sure is that you do need extended travel shock or you will top out your oem shock (bad news). I'm going to try out skyjacker. My block and ubolt kit and shocks come in on friday so after this weekend ill let you know how she runs. Fyi I love my air bags and I do daily commuter and mid level off-roading.
