Firestone Alignment w/ SPC UCA...what a joke
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reneaux, Sep 3, 2019.
  1. Sep 4, 2019 at 12:56 PM
    #41
    eon_blue
    Azusa, CA
    FWIW Toyota wouldn't align my truck with SPCs and Kings. At least not my local dealership here in SoCal. They referred me to a custom alignment shop.
    I think it really just depends on the technicians and what they're comfortable with doing, or maybe each individual dealership's policies on aftermarket parts.
  2. Sep 4, 2019 at 12:58 PM
    #42
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    I have seen it mentioned in my local toyota groups that Firsestone NO LONGER honors their lifetime alignment on modified trucks and that they were offering refunds even. Just sharing
    whatstcp likes this.
  3. Sep 4, 2019 at 1:01 PM
    #43
    eon_blue
    Azusa, CA
    Hmm interesting. Well like I said above I rarely use my lifetime package anymore because they won't give me the caster numbers I want at Firestone. Got a local 4x4 shop down the street from me that does it right every time, worth the $$$.
  4. Sep 4, 2019 at 1:22 PM
    #44
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    This was true with the OG SPC arms but it's no longer the case.
    Reneaux[OP] likes this.
  5. Sep 4, 2019 at 1:26 PM
    #45
    Reneaux
    Reneaux [OP] Active Member
    Joel
    Houston, TX
    13' DCLB Sr5 4x4
    CBI Bumper, Method Wheels, Wheelers AAL, 2019 OEM TRD suspension with front spring spacers
    100% agree, and when I was leaving the guy mentioned that if he were to adjust the UCA's it would be an upgraded package to "Exotic Alignment", I was not about to spend any additional money there so I just said thanks and left.
  6. Sep 4, 2019 at 1:38 PM
    #46
    Muddinfun
    Muddinfun Well-Known Member
    They didn't even try to improve on the shitty caster and camber numbers. "It's in the green. Send it". I am confidant that a very nice alignment is possible on your truck just dialing in the cams. As I mentioned before, there's lots of adjustment left from where the cams are now. You'll even gain some tire clearance, at the back of the tire, in the process.
  7. Sep 4, 2019 at 1:42 PM
    #47
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    An alignment recheck on a bone stock Ford Fusion with just toe and go. =.8
    A nightmare on a modified truck with multiple adjustments including aftermarket parts and upper control arm adjustments that suck. =.8
    What would you rather do?
  8. Sep 4, 2019 at 1:47 PM
    #48
    eon_blue
    Azusa, CA
    Honestly the SPC arms are really easy to adjust yourself using the install guide that comes with them (also on their website). With the front wheels off the ground and the top nut loose, you can turn the balljoint by hand to any of the settings shown on the guide. There's a slot for camber there too that you just have to eyeball. Would need to get a proper alignment afterward to make sure the numbers are where you wanted them but at least that way you can get the SPCs to the setting you want and have the alignment shop correct the rest.
    tcjacado and Bebop like this.
  9. Sep 4, 2019 at 2:01 PM
    #49
    Reneaux
    Joel
    Houston, TX
    13' DCLB Sr5 4x4
    I mean honestly I would find another shop to work at, with better pay structure since it is that big of an issue.
    That being said you're in Cypress not far from me, can you do the alignment then? No shops to suggest in the area or anything else helpful?
  10. Sep 4, 2019 at 2:05 PM
    #50
    Bebop
    Nick
    I would, but I moved to Colorado. But I can give you some info of a few guys that are more than capable of doing a good alignment in cypress
  11. Sep 4, 2019 at 2:07 PM
    #51
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    While some may not agree, I believe the flat rate pay system does little or nothing for the tech. He IS the one doing the work. This system benefits the shop and and theoretically, the vehicles owner. A guy isn't going to kill himself for .8 with the rent due in 3 days.
    Bebop[QUOTED] likes this.
  12. Sep 4, 2019 at 2:09 PM
    #52
    Reneaux
    Joel
    Houston, TX
    13' DCLB Sr5 4x4
    The original camber numbers are from me eye balling adjustments on the UCAs prior to going in, I am comfortable with those, just not the cams yet. However I just purchased a digital angle gauge and protractor to DIY the rest of the alignment. nd4spdbh write up/amendment seems pretty easy to follow along with the rest of the information. I will post up results when I get to it, most likely this weekend once Amazon brings me everything.
    elduder likes this.
  13. Sep 4, 2019 at 2:12 PM
    #53
    Woolybugger
    Woolybugger Well-Known Member
    Aaron
    2005 blk acess cab trd 4x4
    King coilovers
    Firestone did a horrific job aligning my truck then complained when i picked it up that it was un alignable. At the begining i was told the lift wouldnt be an issue so i assumed it would be fine. Ended up being a waste of time and money and had to find a specialty alignment shop who did an excellent job.
  14. Sep 4, 2019 at 2:12 PM
    #54
    Reneaux
    Joel
    Houston, TX
    13' DCLB Sr5 4x4
    Nice! Yeah man I'll take some contacts if you want to send them my way!
  15. Sep 4, 2019 at 2:19 PM
    #55
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    It seems like you they gave you the cheap toe & go alignment. They did not bother to adjust the caster or camber at all. You should get +4° of caster on both sides with the right side being 0.5° higher if necessary for road crown. Your alignment seems like it will make your truck pull right most of the time.
  16. Sep 4, 2019 at 2:22 PM
    #56
    Hans Moleman
    Bay Area, CA
    Toyota dealers don't seem to be that expensive for alignments, only like $99 dollars from most of them around here. The national auto repair chains and mom & pop shops charge $120+
  17. Sep 4, 2019 at 2:28 PM
    #57
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Bay area problems.
    Ventura area, big brand is 50 bucks and they do a free check if you want. To go to an actual alignment shop its 90 bucks.
  18. Sep 4, 2019 at 2:39 PM
    #58
    Reneaux
    Joel
    Houston, TX
    13' DCLB Sr5 4x4
    I just called Duggy's Garage in Houston, $144 for an alignment at their shop after tax, Javiers/Gulf Coast was pretty much the same price....DIY here I come!
  19. Sep 4, 2019 at 3:04 PM
    #59
    TacoCasa
    TacoCasa Well-Known Member
    Tim
    The 719
    2013 Black Tacoma OR DCSB
    Bilstein 6112/5160, Camburg UCAs, HD Dakars, Uni filter, diff breather relocated.
    JBAs seemed to be good UCAs as well for trails (anything that requires a jumps likely will need uniballs).
  20. Sep 4, 2019 at 3:26 PM
    #60
    MDub07
    MDub07 Well-Known Member
    KS
    2012 Tacoma AC 4WD SR5 SSM
    Nice license plate!
    wheeliest[QUOTED] likes this.
