Firestone lifetime alignment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reyalam, Dec 14, 2018.
  1. Dec 14, 2018 at 2:30 PM
    reyalam
    reyalam [OP] Active Member
    rey
    NJ, United States
    2015 tacoma trd sport dcsb
    im having my suspension lifted this weekend and put on size 33 tires. Now i need an alignment. Lifetime alignment with firestone is very enticing. Any experience with them? Would you guys recommend them?
  2. Dec 14, 2018 at 2:31 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    I’ve heard some of the Firestone’s won’t do it cause of the lift others will it’s hit or miss
  3. Dec 14, 2018 at 2:34 PM
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    I have it. I recommend it. Not much experience though.
    I heard they are "toe and go". So no camber. My first alignment wasn't that great.
    Then I went to a local firestone guy that "has a tacoma" and he dialed it in.
    Honestly, theres not much to it. If you got and you don't like the numbers, go to another one and show them the numbers don't satisfy you. They will do it again.
    Then go to another one etc. That's what I'd do.
    Sterling_vH111 likes this.
  4. Dec 14, 2018 at 2:41 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Depends on the location, do research on the one(s) you plan on going to. Many people have had bad luck with Firestone. Yeah technically their "policy" is that they can refuse to work on any modified suspension & will only align with manufacturer's specs as in no custom alignment specs. It really depends on the store manager though.
    The one I go to has been great. Manager is cool & the techs know what they're doing. I have had no problems with them getting my alignment on point, including caster & camber. Lazy or inexperienced techs try to avoid adjusting caster & camber.
  5. Dec 14, 2018 at 2:42 PM
    reyalam
    rey
    NJ, United States
    I spoke to the guy at the firestone shop and he said they have done lifted trucks with 33 tires before.
  6. Dec 14, 2018 at 2:43 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    My local firestone’s tech owns a lifted tacoma and he knows about the tacomas different aftermarket UCA’s. He was able to get the specs i wanted perfectly.
  7. Dec 14, 2018 at 2:44 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    Tire size doesnt have a single thing to do with alignment.
  8. Dec 14, 2018 at 2:49 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    As others have said, if you have a firestone close by that’ll work with your prefernaces and your truck, is go for it.
    I have and it’s more than paid for itself for me.
  9. Dec 14, 2018 at 3:07 PM
    reyalam
    rey
    NJ, United States
    Can anyone care to share their alignment specs? Perhaps a picture of the sheet
  10. Dec 14, 2018 at 3:12 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    I have it, I got 4 alignments in one month.. I go a little fast through the desert and fk up my alignment constantly
    Depends on lift and parts, i ask for 3+ caster & -1d camber & the remainder to follow spec
    reyalam[OP] and El Duderino like this.
  11. Dec 14, 2018 at 3:43 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    firestone alignments are hit or miss, i have 8 in my area so i got to test most of them out. Some of the techs are lazy, get grease all over your interior, and some know what they are doing. All of my cars have it now
    I routinely go to the one closest to work as they have aligned my truck many times before and the tech actually spends the hours to dial it in the way i request it.
    I usually have them zero it out and get the caster to +3.5 for my truck. Can take anywhere between 30 to 2 hours depending how badly i knocked it out of spec.
  12. Dec 14, 2018 at 3:45 PM
    Boatbldr
    Boatbldr Well-Known Member
    Florida
    2002 prerunner
    None
    I have Tires Plus lifetime they have been great. Been almost 10yrs
    reyalam[QUOTED][OP] likes this.
  13. Dec 14, 2018 at 4:42 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Most Firestone mechanics are newbs. I’m not saying anything bad about them, just make sure you get a senior mechanic if there is one available.
    reyalam[OP] likes this.
  14. Dec 14, 2018 at 6:45 PM
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    I've been going to the same Firestone for a little over 10 years now. The same two guys have ran it the entire time and I have nothing but respect for them.
  15. Dec 15, 2018 at 7:52 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    It's not about Firestone, but the guy who runs it and the people who work for him.
    If the place has the same owner and techs, year after year, it's probably a good shop.
    Dealership service depts. in my area are a revolving door - techs come and go with the wind. Independent repair shops tend to keep techs longer.
    frenchee likes this.
  16. Jan 3, 2022 at 7:27 PM
    Jose_Dirte
    Jose_Dirte Life's a garden, dig it
    Joey
    Green Acres, CO
    A Tacoma, just like everybody else...
    I know this is old but....
    If you get it through Firestone you can also go to tires plus and vice versa, they are owned by the same company and honor the program.
    JimIowa and reallifedog like this.
  17. Jan 4, 2022 at 6:50 AM
    tacomaboned
    tacomaboned Well-Known Member
    Georgia
    Silver 2012 Toyota Tacoma TRD Offroad
    Firestone has been good for me, I think I've gotten 3 or 4 alignments so far, stock and lifted, across 2 different Tacomas for the cost of one liftime alignment.
