Firestone Ride Rite Airbags installed but make some noise...
Discussion in 'Towing' started by 08BlackTacoma, May 5, 2009.
  1. May 5, 2009 at 12:20 AM
    08BlackTacoma
    08BlackTacoma [OP] Well-Known Member
    South Florida
    09' Double Cab V6 SR5, Long Bed, TRD Sport
    Hey Guys
    I just installed a set of firestone ride rite airbags on my 09 DC V6 LB, I installed them correctly and only put about 10psi in each until I tow and need to inflate them more. However today i realized i get a noise when going over speed bumps from the rear suspsnsion, its almost like it lifts off the leaf then comes back down and that is what i hear, does anyone else have this? I know they are installed correctly though. I think i wont hear it if i inflate it more or if i tighten the screws more that connect it to the leafs, but i didnt want it so tight that it will bend.
    Thanks
    Neal
  2. May 5, 2009 at 4:05 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Got pictures?
  3. May 5, 2009 at 11:41 AM
    08BlackTacoma
    South Florida
    Of what? the car? or the airbag installed, its not really that special looking, lol.
  4. May 5, 2009 at 11:46 AM
    08BlackTacoma
    South Florida
    I had everything real tight when I installed it, I cannot imagine it being loose, but I will double check it later and make sure everything is tight.
  5. May 5, 2009 at 11:55 AM
    08BlackTacoma
    South Florida
    Hmmm. I dont really have anything in the bed to make noise and the ride doesn't feel that much stiffer. I will check all the bolts again to make sure. How tight did you make the 4 bolts that connect to the leafs? I have might tight, and if I do it any tighter that black metal bar will bend that is holding the nuts down.
  6. May 5, 2009 at 12:33 PM
    08BlackTacoma
    South Florida
    What pin? you do not mean the bump stop do you? if so yes i cut that down flush.
  7. Jul 15, 2009 at 12:18 AM
    peel.m
    peel.m Member
    flowmaster exhaust, K&N cold air intake
    Neal,
    I also just recently installed the Air Lift Bags for my 05' double cab taco. (well maybe 5K ago). Anyways, my springs made some noise for about the first 1K miles or so. I think it was just the springs adjusting to their new position with the bags around 7psi. Long story short, the noises are all gone at this point. It could simply be to just wait a while and see if the noise goes away.
    Hope this helps.
  8. Mar 18, 2015 at 2:38 PM
    nomagination
    nomagination New Member
    TN
    06 PreRunner SR5
    Airlift Suspension Kit
    I installed the AirLift 59561 kit on my 06 PreRunner to help with towing my camper. They were quiet for the first few months then the drivers side bag started popping. I checked all the hardward and it was tight and intact. So I took off the bags thinking I might have a bad leafspring (from the recall). Leafs weren't bad. Left bags off for a while, no noise. Put the bags back on and they were quiet at first, but the sound from the drivers side bag came back after a while. It does it when going over speedbumps or taking off from a stop. Towing or loading doesn't seem to be affected, its just annoying. If I find an answer or cause, I'll post it.
  9. Mar 18, 2015 at 5:53 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    You realize the last reply in this thread was nearly 6 years ago?:eek:
