Firestone Ride Rite question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 802Tacoma, Mar 23, 2013.
  1. Mar 23, 2013 at 10:51 AM
    802Tacoma
    802Tacoma [OP] Well-Known Member
    I am thinking of getting a set of ride rites. I live in VT. Wondering how they hold up in the winter weather with the salt. Thanks
  2. Mar 23, 2013 at 3:39 PM
    jrogers329
    jrogers329 Well-Known Member
    Huntsville, AL
    2011 Prerunner TRD DCLB-TRADED!
    If they are made with the same material as the air suspension on 18 wheelers (and I think they are, based on their website), then you will have no problem. I have been from Miami to Maine, and all the way to California in a tractor trailer. Never had a problem with them. Only thing I would recommend is to wash them to get the salt off when you can.
  3. Mar 23, 2013 at 6:10 PM
    802Tacoma
    Thanks for the info. That is what I was thinking but wanted to check.
    Cheers
  4. Mar 26, 2013 at 9:16 AM
    OutbackHack
    OutbackHack Well-Known Member
    Evergreen, CO
    2014 DCLB Heavy
    Stupid amount of extra heavy metal all over
    Only had mine on for 2 winters so far, but was under the truck last week and they still looked brand new.
  5. Mar 26, 2013 at 10:49 AM
    SimpleTaco
    SimpleTaco Member
    New Brunswick
    V6 4x4 Woddy
    K&N 3 inch and 285's to come
    Just got mine. Will install this weekend!!
  6. Mar 26, 2013 at 11:17 AM
    OmegaQuest
    OmegaQuest Well-Known Member
    Maryland
    2013 Tacoma Limited Double Cab 4X4
    Oil Catch Can, Motorcycle Chock, WeatherTech Window Deflectors, Bilstein 5100, OEM 4 Leaf, Chrome Satoshi Grille, FX-R Stage III Retrofit, Color Match Head Light Mod, Front Hella 500 HID, Behind Grill Light Bar, Rear LED Bed Lights, Pop and Lock Tailgate, Chrome License Plate Covers, AFE Air Filter, Removed Secondary Air Filter, Paint engine cover (Red), ImMrYo Rear-View Mirror Lift Bracket, Center Console Organizer, ScanGauge 2, Firestone W217602407 Ride-Rite Kit, Firestone WR17602178 Air-Rite Dual Electric Air Command
    Sorry to Hijack, but will a set of those on the back make for a "Smoother" highway ride or should I go with 5100 in the rear. I dont do any off-roading, only long highway rides with a motorcycle in the back. I want the "Smoothest" cadilac type ride I can get LOL
    * I have Stock OEM Suspention currently and stock 265/60/18 Wheels
  7. Mar 26, 2013 at 11:25 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    I have them and they have been through quite a few northern canadian winters now full of salted and gravelled roads, no issues yet!
  8. Mar 26, 2013 at 11:32 AM
    OutbackHack
    Evergreen, CO
    2014 DCLB Heavy
    Yes and no. They basically augment your stock springs to help hold up the back end, giving you a stiffer ride for a given payload.
    On the plus side, they help keep you up off the bump stops and let you use the full range of suspension travel regardless of how much payload you're carrying.
    The cool thing is that they are adjustable, so your truck can ride almost the same whether you're carrying your motorcycle back there or have an empty bed. Compared to add-a-leafs that help you carry more payload but can be harsh when running empty.
    From what I understand, 5100's in the rear won't make much difference if you're not lifting the truck and only driving on the highway.
    /Hijack
  9. Mar 27, 2013 at 4:56 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    I've been thinking about these myself since I spend a lot of time with 2 bikes in the bed.
    I actually worry more about the piece of the frame where the mounting bolt goes through being a salt and dirt trap after the ride rites are installed. ( I'm talking about the area around that little cup thingy above the rear tire on the outside of the frame) I hose that spot out every time I wash the truck and theres always a lot of dirt and debris that comes out of there. Looks like a great spot for rust to start...Do the ride rite mounts block that area at all? Looks like it would make cleaning that area diffficult...
  10. Mar 27, 2013 at 5:01 PM
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    It's not totally blocked from allowing water to penetrate. Before it was possible to put your finger in there and scoop out some crud. Now it is partially blocked. If you had a hose you shoot water in it and it'll blast around all that. There is just a bracket that bolts in there, but it doesn't fully seal it in.
  11. Mar 27, 2013 at 7:01 PM
    autoloader
    autoloader Active Member
    Rodney
    Jamestown,OH & Morhead,KY
    05 TRD OFF ROAD 4x4
    carbon filter removed,fog light mod,tailgate lock,ARE cap 5100's at 1.75 firestone ride rites Wheelers 2" aal
    You can still flush it out with a hose.
  12. Mar 27, 2013 at 8:50 PM
    802Tacoma
    Thats the info I am looking for. Thanks
    Cheers
