Firestone Ride Rite Sale
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RKCRUZA, Jul 6, 2015.
  1. Jul 8, 2015 at 2:56 PM
    calico
    calico Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
    Thank you. I expected as such as I have been under the impression that the purpose for them is to bring the rear of the truck up to level when a tow or haul causes rear end sag.
  2. Jul 8, 2015 at 3:06 PM
    RKCRUZA
    RKCRUZA [OP] Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Much to the dismay of many folks on this site, I run mine with a Tee and single fill line which gives even pressure to both bags. According to the Tecs at Firestone, dual fill is for use where you are carrying a camper or such and have a "lopsided" load. Single fill is for normal use with fairly even loads. No need to start a debate on single vs dual fills, if you have questions, call the tec at the 800 number located on the bottom of the back page of the install instructions. Plan to set my Taco up the same way as I try not to haul uneven loads. Would be cool if I could find a small ball valve that would work on the airlines, add another Tee and you could actually have both types of set up at the same time. Open the valve to have a single fill, close it to have a dual fill...best of both worlds.
    1truckdriver likes this.
  3. Jul 8, 2015 at 5:09 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    I also use a "Tee", single fill line, to equalize the pressure between my Air Lift bags. I very seldom find load situations where I need to compensate for unequal load distribution ( any weight on the trailer hitch, for example, is better handled with equal pressure in both bags). Just works better for me.
  4. Jul 8, 2015 at 6:12 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    OK, well, science be damned then. Who needs physics anyway?
