Firestone Ride Rite
Discussion in 'Suspension' started by CoopersTacoma, May 10, 2013.
  1. May 10, 2013 at 2:34 PM
    CoopersTacoma
    CoopersTacoma [OP] Active Member
    2010 Double Cab TRD OffRoad V6 Auto
    ARE CAP
    I want to install Firestone Ride Rite air bags and was wondering if this will add any lift to the rear. Currently have Bilstein 5100s all around with front set at .85.
  2. May 10, 2013 at 2:37 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    depends on how much air you put in the bags. at 5 psi its pretty much stock height, at 20 ints up about and 1.5 in, or 2. so its up to you! and theyre pretty much awesome! enjoy them!
  3. May 10, 2013 at 4:10 PM
    CoopersTacoma
    ARE CAP
    Thanks for the info...If I change my front 5100s to 1.75 will I need a Differential drop kit?
  4. May 10, 2013 at 4:35 PM
    jpneely
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    i dont know. but ive read alot that the drop kits do more harm than good. theres a couple of big threads on it here somewhere. search it up! people here know alot more about that part than i do
  5. May 10, 2013 at 4:37 PM
    jpneely
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
  6. May 10, 2013 at 4:44 PM
    acdronin
    acdronin Well-Known Member
    I'm set at 1.75, had a little hum for a while then it went away, diff drop isn't really a must do kinda thing with these trucks at that height.
  7. May 10, 2013 at 4:46 PM
    acdronin
    Pump em up to the max of 125psi and watch the back end of the truck fly into the air on speedbumps :D
    j/k i use mine to level the truck when i'm not hauling a load, anywhere from 5 to 20psi should work for you unloaded.
