Firestone Ride Rite's Installed
Discussion in 'Towing' started by Av8er, Jan 26, 2013.
  1. Jan 26, 2013 at 6:17 AM
    Av8er
    Av8er [OP] Well-Known Member
    Taylor
    Formaly Houston, now Tampa, FL.
    09 Prerunner SR5/TRD DC, LB, w/ Tow
    Threw on some Ride Rite's yesterday. Non-Tsb 3-leaf pack, stock suspension. Plan to do some towing (boat, travel trailer, etc.) in the near future so I picked these up for Christmas. Even at the min. 5psi, it definitely lifts the back end a bit. Took it for a test drive last night with 40 psi in each and the dude in the camaro at the light did not appreciate my lights shinning all up in his shit. [​IMG] Looks goofy pumped up with no load in the back but damn good to know I have em' when I need em.
  2. Feb 15, 2013 at 5:46 PM
    PatSully
    PatSully Well-Known Member
    Pat
    Phoenix
    07 Access Cab TRD O/R
    Rear AAL, Extra D-Rings
    i have been looking at this set up for myself. how have they been towing, if you have used them?
  3. Feb 16, 2013 at 2:13 PM
    Av8er
    Taylor
    Haven't towed with them yet, only had loads in the back. You can do a search, especially in the towing section and find tons of great reviews of these bags while towing.
    Really enjoying them so far though for the loads ive hauled.
  4. Feb 17, 2013 at 5:34 PM
    gologit
    gologit Well-Known Member
    Bob
    In the redwoods.
    2011 4x4. Leer canopy Firestone airbags
    Nothing major or fancy. Just stuff to make it work better for me.
    They work great. I put a set on my 2011 last year. I have a Leer shell and tow a Casita 17SD. I usually carry quite a bit of work related stuff in the Toyota, saws, rigging, lots of gas and oil in 5 gallon cans and other misc. heavy stuff.
    I usually stay in the woods all week while I'm working so the trailer leaves home with a full water tank and lots of groceries.
    I've never weighed it...kinda scared to...but it's a big load. The most air I've ever put in the bags to level the back of the pickup was 25 lbs. That's with the Casita hooked on. The bags don't seem to add any sway for feeling of back-end "walk". They're very stable.
    I had the rear spring tsb done....mostly because it was free...but I really think that the air bags make it unnecessary. I installed them myself and the only major problem was cutting the bump stops off with a damn dull hack saw...I should have known better.
    Try 'em.
  5. Feb 24, 2013 at 6:51 AM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    I installed my Firestone's shortly after I bought the truck. It really helped the towing stability out a lot. As for cutting the old bump stops I used a saws-all only problem then was all the smoke and mess. It did make short work of them though.
  6. Feb 24, 2013 at 6:56 AM
    Brentmeister
    Brentmeister Active Member
    Brent
    Dallas
    I'm planning to do this same install myself. Please let us know how the towing is improved.
  7. Feb 24, 2013 at 8:00 AM
    03stepsidetaco
    03stepsidetaco Member
    David
    centralcoast CA
    03 stepside taco
    just did the Air Lift ride control set on my 03 yesterday. 20lbs make it ride tail high!
    next friday get to see how it tows.
  8. Feb 24, 2013 at 2:54 PM
    PatSully
    Pat
    Phoenix
    Thanks a lot for the feedback!
    i guess that settles it and i will watch for a deal show up on them.
  9. Feb 24, 2013 at 11:14 PM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    I'm wondering if I can fit these on my reg cab that's lowered I only want it pumped up when I'm hauling my streetbike in the back. Will these even fit if my rear is lowered three inches??
  10. Feb 25, 2013 at 12:03 AM
    acdronin
    acdronin Well-Known Member
    I haven't a clue. Maybe you could measure the space that you have from the top of the axle (where the bumpstop is) to the frame and one of us could measure ours deflated and maybe it could work but IDK.
  11. Feb 25, 2013 at 12:04 AM
    acdronin
    Yes, awesome is the word
  12. Feb 25, 2013 at 12:06 AM
    acdronin
    That's what I did, IIRC there was an angle grinder involved too, saves the trouble of pulling the U-Bolts off to get the bumpstops out.
  13. Feb 25, 2013 at 4:12 AM
    tx_shooter
    I'm going to say doubtful because the bags do require that some air be in them all the time and even 10 psi picks up my bed a little.
    That said - if you had the time/equipment you could probably fab a bracket for it to mount to a little higher than the bottom of the frame and make it work. There is always a way if you have enough tools and time.
  14. Feb 25, 2013 at 2:00 PM
    jmarquez808
    Jess
    Hawaii
    07 4x2 reg cab
    true true i was thinking the same thing because you cant leave them flat, they wont fit in there. I saw somthing that did mount to the side of the frame and farther back than the u bolts but i cant actually find it online, saw a picture of it next to the ride rights on some site. i donno guess ill do some searching
