Firewall Pass-through for Accessory Wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PaulK, Dec 12, 2013.
  1. Dec 12, 2013 at 11:32 AM
    PaulK
    PaulK [OP] Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    I am installing some off-road lights on an Avid light bar. Is there a spot in the firewall to pass the wires through, or am I going to have to drill one?
  2. Dec 12, 2013 at 11:34 AM
    Large
    Large Red
    Behind the brake pedal there is a rubber grommet.
  3. Dec 12, 2013 at 11:35 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Most of the threads I've seen people use a coat hanger and put the new wires through in a location that already has wires passing through
  4. Dec 12, 2013 at 11:45 AM
    bbdmac
    bbdmac Well-Known Member
    Leominster, MA
    2013 TRD Sport Double Cab
    On the passenger side there's a rubber grommet that you can remove and put a slice in. Then you can add wires through the hole and slide the grommet back into place. It's about 10 -12 inches down from top of the firewall behind the glove compartment.
  5. Dec 12, 2013 at 11:47 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    x2
  6. Dec 12, 2013 at 11:48 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Below the driver's side grommet, is a smaller grommet that is closed shut. its about 3/4" diameter. you can cut it at a rib near the tip on the engine side. then you can run your wiring through there.
  7. Dec 12, 2013 at 11:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This is what I did, shove a coat hanger through where the wires already come through, tape my wires onto the hanger and pull them through. I squirted from RTV in afterwards for good measure. A local member found a rubber grommet at the top, driver's side, it's hidden behind something but it's nice and concealed.
