Firewall Wiring Access
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MattRRT, Jul 3, 2015.
  1. Jul 3, 2015 at 8:43 AM
    MattRRT
    MattRRT [OP] Well-Known Member
    Concord, NC
    2009 Tacoma TRD Sport
    5100s, BGF TA KO2, Trifold Tonneau Cover, Weathertech window visors, window tint,
    OK I have searched and browsed and decided on a generic thread, on your opinions of the best ways to wire through the firewall to run a switch into the cab.
    I am putting LEDs on my grill guard, and have an 09 Access Cab.
    Where do you guys think the best access point is?
    Could you please post pictures?
  2. Jul 3, 2015 at 9:27 AM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
  3. Jul 4, 2015 at 12:50 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    That's where I got mine running through, too.
  4. Jul 4, 2015 at 1:59 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    X3.
    Years ago, I used to install hardwired cell phones in vehicles (yeah that long ago), and for our battery feed, I would use a small piece fish tape (a piece of flat wire used to fish wire through walls), with the wire taped to it and poke through the side of the rubber grommet. The idea is the fish tape has a somewhat of a sharp end, would poke through the rubber making a hole slightly smaller than the wire it itself. As you pull the wire through, it would still have a nice tight seal. Just be careful not to poke into anything on the main harness.
    DrFunker likes this.
  5. Jul 4, 2015 at 3:14 AM
    DrFunker
    DrFunker Well-Known Member
  6. Jul 4, 2015 at 4:07 AM
    Fitz235
    Rob
    New Hampshire
    De nada.
  7. Jul 4, 2015 at 5:13 AM
    GSHEP4
    GSHEP4 Well-Known Member
    Lehighton, PA
    2014 spruce mica sport
    s/c,fluid film, bug shield, window vents, under hood lights, bed lights, tailgate reinforcement, and more.
    Drilled and put weatherproof grommet at about 1 oclock to the main harness by the brake booster.
  8. Jul 4, 2015 at 2:05 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    This is how I did it.
