Firm Brakes/Rear Brakes Locking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elk340, Mar 5, 2012.
  1. Mar 5, 2012 at 7:31 AM
    elk340
    elk340 [OP] Well-Known Member
    Justin
    Ouray, CO
    '11 Tacoma TRD Off-Road AC
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; sway bar delete; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    *FIXED*
    Everyone,
    I just had my truck lifted with a Toytec ULK and had stainless steel braided rear lines installed. Now, when pressing on the brake peddle while driving, it feels very firm and does not travel very far, maybe 2". The problem is that, at first, there is no discernable braking action taking place. I can apply more force but more force does not equal more braking force in this specific case. Then, after about 5 seconds, the truck starts slowing down faster, as if you just ran into quick sand, and then the rear wheels lock up and start to skid.
    I am not sure if this is related to the lift (VSC) or the stainless steel brake lines as they were both done at the same time. I am confused. Help!
    Justin
  2. Mar 5, 2012 at 7:39 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Unless you changed tire size, the VSC shouldn't have been affected. Are you getting any dash lights flashing, like the ABS or BRAKE light?
    I've heard SS brake lines do firm up the pedal, but you shouldn't be locking up the rear tires at all.
  3. Mar 5, 2012 at 7:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like they may need bled again.
  4. Mar 5, 2012 at 7:56 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    x2 start at the wheel farthest from the master cylinder and work your way to closest. Make sure your reservior stays full or you'll be starting all over again mid way through.
  5. Mar 5, 2012 at 10:45 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    There's a Toyota procedure in the FSM to bleed brakes. It's not quite the same as old-school bleeding. I don't have a link, but I would look into that.
  6. Mar 5, 2012 at 10:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    With VSC w/o VSC
  7. Mar 5, 2012 at 11:19 AM
    elk340
    Justin
    Ouray, CO
    FIXED! I originally thought it was VSC related due to the lift and 33" tires, but, as you all suggested, I bled the brakes in the rear again and they are now fixed! The company who installed them said that they bled them but apparently they didn't get all of it. Just a little bit of air out of each rear assembly was causing all of the trouble.
    So much for a squishy peddle indicating air in the system. Now a firm one might do the same, ha-ha.
    Thank you!
