Firm shifts/unusual shift points
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02ttaco, Mar 13, 2011.
  1. Mar 13, 2011 at 9:51 AM
    02ttaco
    02ttaco [OP] Member
    Tyler
    Maryland
    02 tacoma trd
    three inch spacer lift with blocks in the rear
    I have an 02 taco 3.4 130k miles. The tranny is an automatic and i have recently noticed the shifts have been unusually firm. I had the system flushed 20k miles ago. Is this normal or could the torque converter be bad?
    i have also noticed the shift points are not consistant
    -thanks
  2. Mar 13, 2011 at 12:36 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Shift points may not be consistent because of oil temps. If they are inconsistent when you're at operating temps and you're driving the same stretch of road (no real grade changes) then you might have a bigger problem. My advice would be to grease the driveshaft(s) to take care of the hard shifting. I'm sure chris4x4 will be in here to give more advice though
  3. Mar 14, 2011 at 1:48 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    Has your check engine light come on recently?
  4. Mar 16, 2011 at 2:08 PM
    02ttaco
    02ttaco [OP] Member
    Tyler
    Maryland
    02 tacoma trd
    I haven't noticed the check engine light. But one day the truck just shut off in traffic but i was able to restart it.
  5. Oct 5, 2011 at 9:53 PM
    Big Phill 02
    Big Phill 02 New Member
    02 Tacoma 4x4 3" Lift
    Roof rack with 6" Hella Lights, Brush Guard, Camo TRD graphics, 3" Fabtech Lift
    I have 02 tacoma with the same problem. MY engine light kept showing shift solenoid. The only difference is mine is on its 4th transmisson. 3 have been from jasper and one was a reman toyota tranny. I was told that the computers are supposed to reset themselves when the new transmission is installed. But after the 2nd one I dont think this is true. 3 year warranty from jasper so i guess ill just keep getting new ones until they do what they supposed to. hopefully someone knows more than my mechanic.
  6. Oct 5, 2011 at 10:57 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    For any of you experiencing unusually firm/hard shifts, take note this is exactly what mine was doing before this happened....
    About half a pound of metal
