Firm up the rear end
Discussion in 'Towing' started by mix1234, Apr 22, 2019.
  1. Apr 22, 2019 at 4:57 PM
    mix1234
    mix1234 [OP] Member
    I want to firm up the rear end of my 2010 V6. Pretty bouncy with my 2950lb trailer hooked up. What are my options? Shocks..leafs..air bags? I think my rear stock shocks are currently a little soft.
  2. Apr 22, 2019 at 6:30 PM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Sumo springs work well, cost effective, and are an easy diy project
    MuddySquirrel likes this.
  3. Apr 22, 2019 at 8:22 PM
    mix1234
    mix1234 [OP] Member
    I just ordered a set. Thanks
  4. Apr 22, 2019 at 8:40 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    If it’s “bouncy” the problem may likely be your shocks are shot. Have the shocks on your 2010 ever been replaced? I pull a 3500 lb boat and recently put a new set of Bilstein 4600 heavy duty shocks on. Difference is amazing with the new shocks. If your truck isn’t lifted get a set of Bilstein 4600’s. They are the same as 5100’s but for trucks that are not lifted.
  5. Apr 22, 2019 at 8:43 PM
    Thetacotruck71
    Thetacotruck71 Well-Known Member
    James
    2019 TRD Off Road
    I'm changing out my leef lac in the rear too. The canopy along sags the back a little.
  6. Apr 23, 2019 at 7:30 AM
    mix1234
    mix1234 [OP] Member
    Thanks. I ordered a set of these today. They have never been changed out. Will put them on this week and report back. Thanks!
  7. Apr 27, 2019 at 5:06 PM
    eMKay
    eMKay Well-Known Member
    Michael
    Buffalo, NY
    2019 Cavalry Blue DCOR 6MT
    Pro Grill, roof rack, HID headlights, yellow fogs, LED high beams, trailer brake controller
    If by “bouncing” you mean porpoising, then a weight distributing hitch will help the most. If you have one already then like others have said, check your shocks, upgrade your shocks, sumo springs...
  8. Apr 30, 2019 at 7:07 AM
    mix1234
    mix1234 [OP] Member
    The 4600's are in. What a difference. I haven't towed with them yet but they ride and handle so much better than my old ones. Next up Sumo Springs.
    Sprig likes this.
  9. May 1, 2019 at 7:18 AM
    mix1234
    mix1234 [OP] Member
    Sumo Springs in. Will tow the trailer tomorrow to see how much of a difference this made. I'm thinking it will be substantial.
  10. May 1, 2019 at 10:12 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I liked my Firestone air bags when I had the Taco. The problem with springs or shocks or anything else is when you aren't hauling it's too stiff a ride. The airbags can be put low enough that it's like going back to stock.
  11. May 2, 2019 at 10:34 AM
    mix1234
    mix1234 [OP] Member
    Tows much better. Need to adjust the WD hitch but otherwise these upgrades seem to have helped.
  12. May 3, 2019 at 10:29 AM
    Sprig
    Ken
    Out of curiosity what are you towing and what does it weigh?
  13. May 3, 2019 at 11:54 AM
    mix1234
    mix1234 [OP] Member
    Keystone ROV 20ft travel trailer. 3000lbs dry
  14. May 3, 2019 at 3:29 PM
    Sprig
    Ken
    Yep you are right on to go with the new springs, shocks and WDH
