First 4x4 and Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1stTacoEVR, May 26, 2018.
  1. May 26, 2018 at 1:35 PM
    1stTacoEVR
    1stTacoEVR [OP] Member
    2016 Tacoma 4x4
    I have a 2016 4x4 Tacoma and this is my first. I’m looking to purchase a 3” lift and wheels and tires for it.
    I want something not to outrageous affordable.
    Need help
  2. May 26, 2018 at 1:47 PM
    DubfromGA
    DubfromGA Well-Known Member
    Greg
    2017 Black SR5 4WD
    A hell of a lot of offroad performance can be had by tire choice.
    I have little experience with lifting.
    Never felt the need.
    If and when I do....it'll be a full on suspension lift......because I need the functionality of the gear....not the look.
    GR8APE and 1stTacoEVR[OP] like this.
  3. May 26, 2018 at 1:55 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Make some friends w/ lifted tacos near where you live and ride with them. Ride changes pretty drastically depending on set up you choose. First thing I’d ask myself is what I want out of it. If you go on dirt roads on a daily basis you may choose a different set up than someone who mainly uses their truck as a daily driver on pavement. Once you figure that, then think of a budget. Prices can vary significantly depending on what you wanna get out of the truck. Another question I’d ask is if you want to soften the ride (make make it less capable of handling weight/tow) or stiffer ride (may make ride harsher). And finally, figure out how much weight do you want to carry. Some people have pretty heavier loads w/ all kinds of gear and tools that may weigh your lift down. I’m sure there are many other variables to think about. Those are the ones I wish someone had pointed out for me as I planned my lift. Good luck!
    1stTacoEVR[OP] likes this.
  4. May 26, 2018 at 2:14 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Are you lifting for looks or are you lifting for...
    Point is, unless you are going balls out in the desert or rock crawling there is little point to lift, unless it is for the look.
    Some will tell you it is helpful to fit bigger tires. That is true, if you lift 6". If you stay in the 2-3" range, you have to fit the tires throughout the suspension range and that includes stock height. So you will have to mod to fit the big tires at stock height even if you lift.
    Good luck and have fun!
  5. May 26, 2018 at 2:21 PM
    1stTacoEVR
    2016 Tacoma 4x4
    Thanks for the response guys. Where I live is mostly paved but there’s also a lot of beaches and that’s where I’m trying to get. And I do have lots of gear to haul sometimes. My budget is reasonable around $5k. Looking for some parts suggestions. I don’t know where to start.
  6. May 26, 2018 at 2:22 PM
    henryp
    Henry
    Montana
    https://www.tacomaworld.com/threads/tacoma-lift-faq-guide-read-this.11282/
    hiPSI and 1stTacoEVR[QUOTED][OP] like this.
  7. May 26, 2018 at 2:25 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Call Marie @HeadStrong Off-Road. Tell her what you want, your budget and everything else. She will help you from start to finish and they won't take you for a ride.
    DubfromGA likes this.
  8. May 26, 2018 at 2:25 PM
    henryp
    Henry
    Montana
    My worn out stock shocks (2nd and 3rd gen share suspension) would fade after 30-45 minutes of gravel road driving. Just to give you an idea. Stock suspension is pretty capable. I used to live close to Daytona Beach and the stock TRD OR shocks did great. If you go for looks, make sure you don’t end up making it less capable (ie spacer).
  9. May 26, 2018 at 2:26 PM
    henryp
    Henry
    Montana
    That’s who I used for my rear leaf springs. Couldn’t be happier.
    1stTacoEVR[OP] and hiPSI[QUOTED] like this.
  10. May 26, 2018 at 2:35 PM
    1stTacoEVR
    2016 Tacoma 4x4
    hiPSI and henryp like this.
  11. May 26, 2018 at 2:36 PM
    GR8APE
    GR8APE Well-Known Member
    3 inch lift = bigger tires = less torque = less mpg = you'll be back on the forum in no time at all!
    DubfromGA and hiPSI like this.
  12. May 26, 2018 at 2:36 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    Welcome to the party
  13. May 26, 2018 at 2:37 PM
    henryp
    Henry
    Montana
    FIFY
    GR8APE[QUOTED] likes this.
  14. May 26, 2018 at 2:38 PM
    1stTacoEVR
    2016 Tacoma 4x4
    Thanks for the reassurance GR8APE
    GR8APE likes this.
  15. May 26, 2018 at 2:40 PM
    henryp
    Henry
    Montana
    Tacoma World =
  16. May 26, 2018 at 2:41 PM
    1stTacoEVR
    2016 Tacoma 4x4
    Thanks guys
  17. May 26, 2018 at 4:45 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    Read the build threads tons of information, including possible issues and solutions to those issues.
  18. May 26, 2018 at 6:11 PM
    Natpag
    Natpag Well-Known Member
    2017 White Tacoma TRD off-road
    What these guys say is all pretty true from my experience. I was in the same boat as you and went with a mid travel king set up on 285/70/17s. My mileage has suffered horribly and my power is down big time. Now I've ordered 4.88 gears. Since I'm in there, I'm gonna put an ARB air locker up front. I have a fortune in my tacoma. At the end of the day the guys around town with the cheap 6 inch lifts on 35s look more macho than my truck too. I don't regret it as my ride is awesome, and I went into this wanting to build a sherman army tank. If you don't plan on hitting some sketchy stuff offroad though, stock or a more budget lift may be alright?
  19. May 26, 2018 at 6:20 PM
    GR8APE
    You are welcome! Might want to be looking for an extra source of income to go along with your new hobby.
  20. May 26, 2018 at 6:25 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    These machines are capable of running on the beach stock even with stock tires. Air down to 15 pounds, get a inflator if the beach does not have a air station. I like my Viair. If its an automatic transmission stay in 3rd gear. Get rid of the mud flaps or cut 4 or more inches off.
