First 80 degree day and........No AC!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BadDad69!, May 14, 2025.
  1. May 14, 2025 at 7:53 PM
    BadDad69!
    BadDad69! [OP] Well-Known Member
    Butch
    N.E. Wisconsin
    2021 Crew cab, short box, 6MT, Army Green, TRD OffRoad.
    none yet
    So, 2021 Tacoma TRD OR MT6. 35,000 miles. Turned on AC and no cold air
    , everything else works, blower, temp settings, air direction, heat.
    Found compressor mag clutch isn't engaging, swapped relay, still no go.
    Hooked up 12v. power to mag clutch leads and clutch works.
    Any guidance on what to check next ?
    Thanks in advance, Butch.
  2. May 14, 2025 at 8:02 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Have you checked the refrigerant?
    Chew likes this.
  3. May 14, 2025 at 9:31 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Welcome to the crappy Tacoma AC club. I’m out $4,000 so far on mine.
    islandhiker and SandyTaco4x4 like this.
  4. May 15, 2025 at 6:02 AM
    BadDad69!
    Butch
    N.E. Wisconsin
    none yet
    No experience with AC, so guess I'll learn how to do that today.
  5. May 15, 2025 at 6:22 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Oh, no. That’s horrible. I replaced my compressor and clutch 2 years ago. By the grace of God this thing is making sno cones.
    xBloodxLinex likes this.
  6. May 15, 2025 at 6:27 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Best to find your local AC specialist to do refrigerant. They will be cheaper than the tools you need to do it correctly. They will need to do a vacuum test, find the leak, fix that, and then purge it again before adding refrigerant. If you leave air in the system it will kill your more expensive parts.
    On the vast majority of cars, Taco included, the AC won't engage if the pressure sensor is not in range. It just happened to my go-cart a few months ago. It cost me all of $300 for my local shop to fix the leak (bad return hose on the compressor) and recharge the system.
  7. May 18, 2025 at 6:12 AM
    BadDad69!
    Butch
    N.E. Wisconsin
    none yet
    Thanks for above advice.
  8. May 18, 2025 at 8:02 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I had to have mine topped up last summer for $170. Knock on wood, it's working good thus far...
    xBloodxLinex and TomTwo like this.
  9. May 18, 2025 at 1:57 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Won't be that hot here for another 2 months. I rely on specialty shops to do my a/c and heating needs just like tires to a tire shop.
    TomTwo likes this.
  10. May 18, 2025 at 2:04 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Low system pressure switch will keep the clutch from coming on. Someone needs to do a leak test on your truck. My compressor took a dump at 70,000 miles. Dumped all the freon and the low pressure switch prevented the clutch from engaging. Of course it was August in Georgia and hot AF.
  11. May 18, 2025 at 2:27 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    If you have installed a front bumper, check the ac condenser hardline coming off the front passenger side of the condenser. Even if you look like it has plenty of clearance, it seems the supports allownit to move around enough it may be making contact on hard bumps.
    Just had to have mine replaced. I checked the clutch first, it wasn't getting power, and the '22 model years no longer have a seperate a/c clutch fuse, so that pointed to either a leak or failed mag.clutch. Turned out to be a leak. Found it as soon as they started to charge the system, still charged me for the whole unit of refrigerant. ~$1200 all in for two charges of refrigerant, the line and an hour and a half labor.
    Steves104x4 likes this.
  12. May 18, 2025 at 3:03 PM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    Had no idea some tacomas had shit AC until recently. Im out $2000cad on my '21 just last week.
  13. May 18, 2025 at 3:07 PM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Busted a AC line when my old CBI T3 bumper damaged a hardline. Was an expensive repair. Won’t let that one happen again. Took the bumper off and cut clearance. Now I have a c4 rock runner bumper.. I cut the same amount of clearance to prevent the same problem.
    Toy_Runner[QUOTED] likes this.
  14. May 18, 2025 at 3:16 PM
    Toy_Runner
    99 4Runner SR5
    Same. As soon as I got home from the shop had it off and went at it with an angle grinder.
    I'm assuming the bamf behind the grille light support and pair of SS5's isn't doing the core support any favors. Roads are absolute trash heading into where I work, and I have to cross bacl forth over railroad tracks on my way in. Need to mount my lights externally asap. Also decided to fab a mount for my winch relay box that ties into the rear support frame of the bumper rather than the core support for the ssme reason.
  15. May 18, 2025 at 4:06 PM
    BadDad69!
    Butch
    N.E. Wisconsin
    none yet
    I noticed that There isn't a fuse where it's labeled on the under hood fuse panel too. I'm surprised at the cost for an AC recharge.
    I guess I've just been lucky all these years never having had an AC related issue.
  16. May 18, 2025 at 4:24 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    First question...
    Are you the original owner?
    Second comment...post#6 is your best bet to get it sorted.
    My question of ownership is very important because the previous owner's due diligence is critical in continued functions as originally built.
  17. May 18, 2025 at 4:32 PM
    BadDad69!
    Butch
    N.E. Wisconsin
    none yet
    I'm the Original owner. Ordered truck for my retirement, none in my area with a 6 speed manual.
    Truck is all stock except for a couple convenience items.
    I try to keep it off the road in Wisconsin winters, use it mostly as our travel, camping vehicle.
    Previous truck was a 2005 Dodge 5.9 Cummins 6 speed manual QC SB.
    Guess I'll be taking it into an AC shop.
    TacoTime55 likes this.
  18. May 18, 2025 at 4:56 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    Good call!
    Enjoy your evening.
  19. Jun 13, 2025 at 8:28 AM
    BadDad69!
    Butch
    N.E. Wisconsin
    none yet
    had AC shop check refrigerant level and it was fine. What all else would keep compressor from engaging? Relays are good, compressor engages when jumpered, refrigerant level is good, no flashing light on dash AC button. What other sensors should I be looking at?
  20. Jun 13, 2025 at 8:39 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    The AC shop didn’t have any suggestions?
    Chew and Toycoma2021 like this.
