First alignment coming up...what to hit with penetrating lube?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JKD, Jan 6, 2013.
  1. Jan 6, 2013 at 8:26 PM
    JKD
    JKD [OP] Well-Known Member
    Like the title says, I'm going to have the first alignment done since the truck was new. It really hasn't needed one, but some rough roads this past summer seem to have finally 'adjusted' it out of alignment.
    I'm at 60,000 miles, give or take a few.
    If I want to make the job easier on the alignment technician, I'm thinking it might be a good idea to hit the relevant nuts/bolts/adjusters/bushings with PB Blaster a week or so before I take it in.
    So...what would be the most important parts to hit?
  2. Jan 6, 2013 at 8:29 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The LCA alignment cams / bolts
    But having said that I bet they are all seized
  3. Jan 6, 2013 at 8:39 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    And tie rods....
  4. Jan 6, 2013 at 8:41 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Yeah that's it.
    That being said, do it an hour before you go it. A week ahead of time is not necessary.
  5. Jan 7, 2013 at 7:22 AM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    Good links DoorDing.
    Definitely good advice on bringing spare parts. The extra air time on the lift/labor will most likely supercede whatever cost the parts were. Plus - good to have it done right for the future.
  6. Jan 7, 2013 at 11:56 AM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    . . . Sub'd
  7. Jan 7, 2013 at 3:44 PM
    JKD
    I guess I'll have to look over my platinum warranty really carefully before going in. If the truck is un-alignable without replacing parts, I'd hope the parts are covered.
  8. Jan 7, 2013 at 4:29 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Unfortunately mine weren't covered by warranty. They call it a "wear" item, or some BS like that.
  9. Jun 10, 2013 at 1:21 AM
    JKD
    Took a while to get it in, but yep...siezed. They did the toe and told me to come back and leave it with them for a full day so they could try things to work it free. I'm spending a couple of weeks hitting the LCA mount points with PB Blaster before I take it in.
    If they have to cut and replace parts, I'll be on the phone with Toyota customer service. If they're installed without lubricant (as they appear to be) they need to cover the cost of that manufacturing defect.
  10. Jun 10, 2013 at 4:29 AM
    Soft Taco
    Soft Taco Team Oil Drop
    Tyler
    Colorado Springs, CO
    2016 4WD Auto DCLB TRD Sport
    Forget PB blaster. 50/50 mix of ATF and Acetone in a spray bottle. Shake and spray. Works unbelievably well.
