First Big Bear Trip... Advice?
Discussion in 'Southern California' started by jake slatnick, Apr 25, 2017.
  1. Apr 26, 2017 at 10:37 AM
    jake slatnick
    jake slatnick [OP] Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    Definitely looking to do the scenic stuff but if I don't need 4WD at all it's going to be a seriously disappointing trip! Any trails you'd recommend that require 4WD?
    Noted on the permits and passes! Thanks
  2. Apr 26, 2017 at 11:26 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Well most of those require sliders and you didn't want to go on those. For the 4x4 trails up there you're going to be dealing with rocks. If not then they are mostly easy trails.
  3. Apr 26, 2017 at 11:27 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Sounds like I need to invest in sliders...
  4. Apr 26, 2017 at 11:27 AM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    Also you can get the adventure pass at the Mill Creek ranger station before you go up the hill. A lot less visitors usually so no lines.
  5. Apr 26, 2017 at 11:28 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Thanks!!
  6. Apr 26, 2017 at 11:29 AM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    For sure. Especially since you value your door panels lol. @Shmellmopwho is a local fabricator that does good work. Gonna have him do my sliders in a few months
    Shmellmopwho likes this.
  7. Apr 26, 2017 at 11:30 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    If I'm going to get sliders and play in the rocks do I need to invest in skid plates running across the bottom of the truck?
  8. Apr 26, 2017 at 11:34 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    This is a pretty comprehensive list of the trails up there - http://www.dirtopia.com/wiki/Big_Bear
    Those marked Medium, such as 'Clark's Grade', are probably what you want to look. I see they label 'White Mountain' as medium, and I'd agree to that.
    Thing is about 4WD, if are on a trail that requires 4WD, you are going to be susceptible to possible body damage.
    What you do want to do is to stay away from trails such as John Bull, Gold Mountain, etc. Usually, the entry to these 'hard' trails means overcoming obstacles as rough and tough as the rest of the trail. These are known as 'gatekeepers'. If you can't get through the gatekeeper, then you shouldn't be on that trail...
    Having a spotter (and listening to them) certainly does lessen the chance of damage...
  9. Apr 26, 2017 at 11:34 AM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    I would if you're serious about it. I avoid rocks since I'm 2wd so I won't get skids right now
  10. Apr 26, 2017 at 12:46 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    If you are scared to scratch your paint you should rethink doing anything other than the "easy" trails.
    Other than that, go try Jacoby Canyon.
    While it is not "hard" white mountain is definitely longer and more difficult. You will likely scratch your truck. There are narrow sections where the choice is the edge of the trail or a large bush. If you are inexperienced don't go here.
    Skids and sliders are a good investment if you want to wheel. You never know what your gonna get yourself into sometimes.
    YotaGurlIAm, goblue82, tetten and 2 others like this.
  11. Apr 26, 2017 at 1:16 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Sliders would be the first thing to get then skids then bumper. We did gold mountain last time. I'm on 265/75r16 and got through with no scratches it dents. My friend hit his running boards just a tiny bit. It was a lot of fun.
  12. Apr 26, 2017 at 9:12 PM
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    Took my cousin up White Mountain on one his first wheeling trips ever in his bone stock 5th gen 4runner. It made it up perfectly fine with some spotting help. But the brush did get tight in some spots
  13. Apr 27, 2017 at 12:16 PM
    goblue82
    goblue82 Well-Known Member
    The Dude Abides
    Southern California
    Click muh sig
    Burns Canyon is a fun one. Ran it yesterday with my pal @Dangerousd1987. He's 2wd but lifted and has beef tires. I used 4x. Loop can be done in 2 hrs or you can detour and head into Joshua tree. Pine trees to Joshua trees. Some solid sights to see
    Big Bear 4.26.2017 014.jpg Big Bear 4.26.2017 029.jpg Big Bear 4.26.2017 017.jpg Big Bear 4.26.2017 032.jpg
  14. Apr 27, 2017 at 2:06 PM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    Looks like a party. Nice Trucks
    With all the rain and snow it's tough to say how hammered some of the trails will be. Pin striping and battle scars are half the fun. #shitllbuffout
    Burns Canyon to pioneer town is a fun run.
    Huge Joshua Trees out there
    Cleghorn is a good mellow trail with some fun off shoots.
    Gold mountain Couple tough spots.
    John Bull - is guaranteed body damage with no armor.
    Dishpan Springs had a few tricky tricky spots. probably steer clear of that one
    3N16 - Holcomb Valley pretty mellow.
  15. May 4, 2017 at 10:35 PM
    #35
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Just seeing this now... Great photos!
  16. May 4, 2017 at 10:43 PM
    #36
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Just an update...
    Camped two nights in Big Bear and ran Jacoby Canyon and white mountain with my truck and two basically stock 4x4's with some bfg k02s.
    Jacoby Canyon was really easy. One tight spot, but other than that nothing difficult.
    White Mountain was an awesome trail. A few tough sections. Took up most of the afternoon. Highly highly recommend for people who aren't ready for the gnarly trails like Holcomb and John Bull but want a fun challenge.
    A lot of trails up there though. Excited to go back and scratch more of the surface.
    dwphoto, dirtnsmores and Tombiology70 like this.
  17. May 4, 2017 at 10:48 PM
    #37
    Tombiology70
    Tombiology70 Well-Known Member
    San Diego
    2008 4Runner V8 Limited (Formerly 2017 Tacoma)
    I've been wanting to get up there and explore/camp for awhile so next time you head that way hit me up I'll try and join you:thumbsup:
  18. May 4, 2017 at 11:06 PM
    #38
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Will do man!
  19. May 19, 2017 at 12:23 PM
    #39
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Heading up today to camp/4x4 for the weekend if anyone wants to meet up. Pm me or Ill be on weatherman if you have a radio
    jake slatnick[OP] likes this.
  20. May 19, 2017 at 12:31 PM
    #40
    dwphoto
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    Man sounds like fun! I need to get some parts installed on my truck so I can get out there. Take lots of photos and report back!
    TC yota[QUOTED] likes this.
