First boat coming
Discussion in 'Towing' started by rick carpenter, Jun 27, 2020.
  1. Jun 27, 2020 at 6:38 PM
    rick carpenter
    rick carpenter [OP] Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    We're looking at either a pontoon or v-hull boat possibly fairly soon. The max weight including trailer will be around 3000+ lbs. The trailer will have brakes. What weight distribution hitch should I get? The Tekonsha P3 gets good press here so I'll get that. What else do I need (the truck has the towing package)? I've towed a couple of times before but I'm a novice at it. Thanks
  2. Jun 27, 2020 at 9:11 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Depends on total weight of boat and trailer. 3000 to3500lbs I don’t think you need a wdh. Doesn’t hurt to get one but not really needed. You really don’t need anything else. You have brakes and the Tekonsha is a good controller. If you get into 4000 lbs and above then you may want some extras like wdh and others.
  3. Jul 2, 2020 at 8:20 PM
    Raeburn
    Raeburn Well-Known Member
    2017 ORDCSB
    What kind of brakes are on the trailer? Boat trailers usually have surge brakes because electric brakes and water submersion don't mix well. Surge brakes won't work with weight distribution hitches as far as I know.
  4. Jul 7, 2020 at 1:02 PM
    rick carpenter
    Rick
    The beam for the 16' pontoon we're looking at is 85". That leaves about 1'+ on each side beyond the width of the truck. Has anyone towed with stock mirrors and this much overhang? Do I need to go with the extended towing mirrors? Boat on trailer will come in at just under 3000 lbs, so I figure we add another 1000 lbs with me & passengers & gear fully loaded.
  5. Jul 7, 2020 at 2:35 PM
    NV_Spencer
    NV_Spencer Well-Known Member
    2020 CREWMAX / 2017 OR DCSB
    You can buy WDH's that work with both electric & surge brakes but I agree with Sprig on possibly not needed one. I don't see them often on boat trailers.
    OP - be careful. If you've got 1000 lbs of people & cargo you are likely going to exceed your trucks payload. Check your door sticker.
  6. Jul 9, 2020 at 9:35 AM
    rick carpenter
    Rick
    Thanks NV_Spencer, noted! If it comes down to a people+gear vs beer coolers decision, all I can say is there will be more beer for me.
