First-Born Tacoma10
Discussion in '2nd Gen. Builds (2005-2015)' started by Gabe911, Mar 1, 2012.
  1. Mar 1, 2012 at 2:32 PM
    Gabe911
    Gabe911 [OP] Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    Well here it is....long time coming for sure! Got to send a special thanks to the team at Toytec for the tech support and help. KPT and Chris4x4 u guys are always on the ball and answer questions asap. Thanks to everyone else who took the time to answer questions as well.
    2010 Prerunner MGM Dbl Cab
    Suspension:
    OME885 coils trim packer on D/S (no top plate spacer)
    OME front struts
    OME rear shocks
    TSB w/ Toytec 1.5" AAL (made for TSB)
    Wheels and Tires:
    285/70/17 NITTO Trail Grapplers <---AWESOME
    17x9 XD Addicts Matte Black 4.5 Backspacing
    Extras:
    Lamin-x Yellow Fogs
    Matching Hard Top Tonneau cover
    White LED Map lights
    Blue LED Dome Light
    Black Mats from Costco
    Final Measurements: Ground to Fender ( no I did not get 5" of lift 265 tire to 285 tire is 2" more) From my measurements and calculations I got about 2.7" of lift from the OME885 coils no spacers
    before : Front D/S =34.5" passenger Front = 34.75" AFTER: Front D/S =39.2" Pass Front =39.5
    Rear D/S =36.75" Pass Rear = 36.75 Rear D/S =40" Pass Rear = 40.2
    After Top of tire to fender FRONT D/S= 8" ....Passenger Front= 8 1/4"
    Rear D/S = 8 3/4".....Passenger Rear = 9"
    I am definitely 3/4" higher in the rear via many measurements so slight rake ...I like
    and both passenger front and rear are both 1/4" higher than D/S front and rear
  2. Mar 1, 2012 at 3:46 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Silverado Z71
    Readylift, Truxedo, Husky Liners, Carven
    Nice truck man!
  3. Mar 1, 2012 at 3:50 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    This is perfect! I have your identical truck, down to the year... I am going to buy my lift this weekend, and it's probably going to be the ome 885's and 1.5" aal. Although I will be using the top plate spacer ... what are your specs after the lift? level, or do you have a little rake?
  4. Mar 1, 2012 at 3:59 PM
    bizjettech
    bizjettech Well-Known Member
    San Antonio, TX
    2013 MGM DCSB 4x4 TRD OR
    undercover flex bed cover
    can you explain the trim packer on the D/S?
    what is it?
    Looks awesome! I have a 2011 prerunner and would like to go the same route.
  5. Mar 1, 2012 at 4:19 PM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    Sweet sassy-molassy that is awesome sauce!
  6. Mar 1, 2012 at 5:17 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Glad it could help!! It got dark quick so I will post final measurements 2moro....I do have a slight rake which is what I wanted...not for sure but looks around 1-1.5" higher in the rear....I also have the tsb in the rear
  7. Mar 1, 2012 at 5:19 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    The trim packer is similar to the top plate spacer but is located at the bottom of the strut assembly....it came with OME kit. Basically supposed to fix the taco lean on driver side.
  8. Mar 1, 2012 at 5:23 PM
    bizjettech
    San Antonio, TX
    Hey, thanks for the info. did it do the job? (fix the lean?)
  9. Mar 1, 2012 at 5:25 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Looks great to me but I have to do some measurements 2moro...I am sure it did....my before lift measure were off by almost 1/4" driver front vs pass front....I'll have final measurements 2moro for sure
  10. Mar 1, 2012 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Very nice!
  11. Mar 1, 2012 at 5:36 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Very nice Build man!
  12. Mar 1, 2012 at 5:37 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Thanks for all the compliments!! If there are any newbies that need questions answered about my lift or components please don't hesitate! Again big thanks to all those on tacomaworld...tons of research and knowledge here.
  13. Mar 1, 2012 at 5:41 PM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road Vendor
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Looks great, nice job, very tastefully done. Looks like you got quite a bit of lift out of the OME's without adding and top spacers. That's gotta be close to 3" and they advertise 1.75" if i'm not mistaken. Anyway, looks killer
  14. Mar 1, 2012 at 6:16 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Most people have been getting 2.5" to 3" lift from these ...4x4 2.5" and mine 2wd close to 3"....these are the new 885's with pn# ending in X so no sagging
  15. Mar 1, 2012 at 6:26 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    nice truck !
  16. Mar 20, 2012 at 10:21 AM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Photos by my favorite Lake and fishing spot!!
