First Brake Flush pressure brake bleeder?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ron197, Dec 6, 2019.
  1. Dec 6, 2019 at 5:20 PM
    ron197
    ron197 [OP] Active Member
    Looking at the brake fluid on my 97 tacoma looks pretty bad. It looks very simple to change the fluid. I've never done it would it be worth while to buy a decent pressure brake bleeder? It looks to be the easy way to do it by yourself.
    If so what brand would guys suggest? All my cars/trucks are toyota/honda. Also should i use toyota fluid or is any dot 3,4 good.
    I have 3 other cars to change it on wouldn't take long to pay for it self. Dealer wanted $99 to do it on my honda.
  2. Dec 6, 2019 at 5:59 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    I tried vacuum bleeding but never got it to work right. Wife stepping on the pedal works really good, I crawl around under the truck and crack the fittings. Spend your money on a flare nut wrench set and have a spouse/friend work the pedal.
    Don’t forget the proportioning valve above the rear axle.
    get a big container of brake fluid, you will go through quite a lot.
    CS_AR likes this.
  3. Dec 6, 2019 at 6:01 PM
    agalloch07
    agalloch07 Well-Known Member
    I use a 20ml syringe i bought for a couple bucks and suck all of the fluid out of the master. There is a screen you can remove so you can get all of it out even from the front reservoir. Then i fill it with fresh fluid and bleed the brakes put a loop in some clear tubing and crack the bleeder loose and bleed it one wheel at a time making sure not to run out of fluid. It works well and only cost about $3 for the syringe. I also use this syringe for sucking power steering fluid out of reserviors when i do a power steering fluid change.
    CS_AR and cruiserguy like this.
  4. Dec 6, 2019 at 6:03 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I have a “Motive”. You still need to pump the brake pedal, but it does make it a one person job.
    cruiserguy likes this.
  5. Dec 6, 2019 at 6:32 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I really like my handheld MityVac MV8500. It works, but it takes longer than having someone pump the brake pedal because air likes to get sucked in between the threads on the bleed screw when you loosen it, so you get less fluid per cycle. I've heard some people wrap their bleed screws in teflon tape to prevent air from getting in that way, but I haven't tried it yet.
    If I had to buy again, I might go with the pressure-vessel type, like the MV6830. These can hold a lot more volume and can build up more vacuum.
    Go with Prestone DOT3 or whatever is cheapest.
    skeezix, CS_AR and cruiserguy like this.
  6. Dec 6, 2019 at 6:58 PM
    paetersen
    paetersen Well-Known Member
    And people wonder why their brakes suck.
    Get a good quality DOT 4 fluid with the highest WET boiling point you can find. We're talking a couple god damned dollars here.
  7. Dec 6, 2019 at 7:20 PM
    ron197
    So not many suggest a pressure brake bleeder.
    Sometimes getting someone to help can take longer. :)
    Is it the end of the world if you get air in the lines? I guess you would re-do the whole process to get it out.
  8. Dec 6, 2019 at 7:23 PM
    ron197
    I didn't think you had to pump the brakes if you used one?
  9. Dec 6, 2019 at 7:33 PM
    Kiloyard
    Phoenix, AZ
    I don't drive fast enough or brake hard enough to boil my brake fluid.
    Wyoming09 and cruiserguy like this.
  10. Dec 6, 2019 at 7:37 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I use dot 3 fluid in my old slow taco and my brakes work just fine thank you very much :D
    Wyoming09 likes this.
  11. Dec 6, 2019 at 7:42 PM
    paetersen
    Untill they don't. Untill some rental SUV does a brake stand on you near the bottom of LCC after your brakes are already hot.
    Look, we can speculate and theorize till we're blue in the face. I'm really happy for both of you that you don't need to panic stop often, but again: We're talking a couple god damned dollars here. Cheapest brake "upgrade" you can do is a high boiling point quality fluid and good pads. So why would you skimp? You buying knock off tires too?
    cruiserguy[QUOTED] likes this.
  12. Dec 6, 2019 at 7:46 PM
    cruiserguy
    Elijah
    SEKS
    I appreciate your concern:D
    underaroof likes this.
  13. Dec 6, 2019 at 7:51 PM
    paetersen
    Hey, just remember. You've got the life of a 1st gen in your hands. They're not making more... ;)
  14. Dec 6, 2019 at 7:57 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I just followed the ChrisFix and EricTheCarGuy videos and made a one-person bleeder. Total cost about $5 for the 1/4" ID silicone tubing and Nestea :) Maintained 3 vehicles over 9 years this way. The tubing hardens over time and needs replacement every 5 years or so (you'll notice when it doesn't seal well around the bleeder nipple).
    I just use Toyota-branded fluid which is only available as DOT3. Toyota-branded fluid has some lubricants in it that can maximize seal life in the braking system. Some aftermarket brands have lubricants, too, if you want to spend time researching.
    underaroof and cruiserguy like this.
  15. Dec 7, 2019 at 1:22 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have been using a Air operated Vacuum brake bleeder for years since for the most since I don`t know any people smart enough to pump the pedal around in the wee morning hours. I am no longer sure just what make K-D Tools ?
    The fact one needs Air I guess might not work for quite a few
    There are a few tricks to getting the best results in the operators manual
    Brake Fluid I just buy what Napa has on sale It works .Like anything else seems my brake fluid is always being changed just like coolant I doubt either makes it more then a year for one reason or another.
    Yes I buy the house brand tires of my tire dealer as well
  16. Dec 7, 2019 at 4:46 AM
    rnish
    Tacoma 2nd gen
    Speeds up the process. YMMV
  17. Dec 7, 2019 at 5:44 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    One thing that I noticed on the Tacoma and other cars in recent years is that I start changing the brake fluid in the reservoir a few weeks before I do the bleed. I extract the fluid from the reservoir with a turkey baster extractor. Somehow the old dark fluid works its way back up into the reservoir after a few uses. Then when the reservoir is all clear, then I finish bleeding the system and add fluid as needed along the way.
  18. Dec 7, 2019 at 5:49 AM
    cruiserguy
    Elijah
    SEKS
    I'd always thought the hydraulic fluid is somewhat stationary in the brake fluid system? Not sure how fluid would really cycle through. And the black stuff has gotta be seal material from the master cylinder that's right there and floats up. I'm guessing. I'm gonna have to investigate a little bit.
    When you guys get to see all the cool stuff? You're gonna share pics I imagine right? :D
    CS_AR[QUOTED] likes this.
  19. Dec 7, 2019 at 5:56 AM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    I’m about to tackle this on my 03 pretty soon. Might do it at the same time as the trans and diff.
  20. Dec 7, 2019 at 6:52 AM
    CS_AR
    I think I learned about it from some TW member who gave a big long scientific explanation of how brake fluid is hygroscopic and the bad water mollicules like to float to the top. I wouldn't have figured this out on my own.
