First CB Install
Discussion in 'Audio & Video' started by Brainless, Jul 14, 2011.
  1. Jul 14, 2011 at 10:36 AM
    Brainless
    Brainless [OP] Well-Known Member
    Greg
    Moses Lake, WA
    11 TRD Off-Road 6sp manual
    Ok, so i had ordered the hood mount from Relentless Fab and I am finally getting around to installing it. This is my first cb setup and will appreciate any suggestions/help i can get. Last night I installed the antenna and ran the cable through the firewall and hope to get the rest installed tonight.
    I am using the following parts:
    Firestick FS 4' Red Antenna
    Firestick Heavy Duty Spring
    Firestik FireRing CB Coax with Stud
    RadioShack 40 channel TRC-503 (I know its a cheap radio)
    SWR Meter with Jumper Cable
    I will post pictures of what I have done so far after work, Im sure there is something that may not have been done that I missed.
    Thanks in advance as im sure there will be problems.
  2. Jul 14, 2011 at 12:34 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Sounds good. Let me know if you need a good Mic. I got too many.
  3. Jul 14, 2011 at 1:04 PM
    Brainless
    Greg
    Moses Lake, WA
    ok couple quick shots from lunch break:
  4. Jul 14, 2011 at 1:16 PM
    Brainless
    Greg
    Moses Lake, WA
    Should the stock mic be replaced? Is there that much difference?
  5. Jul 14, 2011 at 9:40 PM
    Brainless
    Greg
    Moses Lake, WA
    ok, so i finished mounting and wiring the radio and drove out into the country a bit (farm fields) and attempted to tune the antenna. According to what i can find i need to shorten it?
    channel 1: 1.3
    channel 40: 1.6
    I really don't want to remove the spring. Are these numbers ok to operate it safely?
    Thanks
    Greg
  6. Jul 15, 2011 at 5:03 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    From what i read, anything under 3:1 is safe to operate.
  7. Jul 15, 2011 at 5:21 AM
    TheTacoTruck
    TheTacoTruck Well-Known Member
    Scott
    Central PA
    05 TRD 6-Spd
    Sorry I'm no help with the CB but I want to install one of my own. That mount looks awesome, Does it interfere with opening the hood or the wipers?
  8. Jul 15, 2011 at 8:14 AM
    Brainless
    Greg
    Moses Lake, WA
    nope!
  9. Jul 16, 2011 at 12:41 AM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    does your cb antenna have a tuning screw at the top?
  10. Jul 16, 2011 at 12:26 PM
    Brainless
    Greg
    Moses Lake, WA
    yes but it will not go any further down.
  11. Jul 16, 2011 at 5:35 PM
    Brainless
    Greg
    Moses Lake, WA
    Ok, I finished putting everything back together and went for a drive up to the top of a hill and tried to tune again. this time i got the following results:
    1 - 1.5
    40 - 1.5
    is 1.5 too high?
    o and a couple pics for ya:
  12. Jul 16, 2011 at 6:01 PM
    NoDrAmA357HK
    NoDrAmA357HK Well-Known Member
    Michael
    North Carolina
    2011 Timberland Mica DBL CAB 4x4 TRD Sport
    3" Pro Comp w/ AAL, 17x9 -6 Offset 4.75 Backspace Pro Comp 7033, LT285/70/17, Xtreme M/T Pro Comp - 67285
    Clean install...as for me I'm looking for a retractable CB Antenna, seen a pretty cool one on youtube
  13. Jul 16, 2011 at 6:17 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    Those nembers are very good.
  14. Jul 16, 2011 at 6:19 PM
    Brainless
    Greg
    Moses Lake, WA
    thanks for the help guys, but now i have noticed interference whenever pressing the brake for like 1 second then its gone. Is ABS interfering? and is there anyway to shield it?
  15. Jul 16, 2011 at 6:21 PM
    kd8awe
    Rocky
    Ohio
    4x4 TRD Off Road
    3:1 on a CB is WAY TO HIGH. You will end up burning up the radio. On an amateur radio (ham radio) that is high but you don't risk burning up the radios finals.
  16. Jul 16, 2011 at 6:28 PM
    kd8awe
    Rocky
    Ohio
    4x4 TRD Off Road
    I use a Firestik on my CB but I don't care for the Fire Ring coax of theirs. Be sure that you ground the radio chassis (use any of the screws on the radios case) to a good metal surface. Be sure that the antenna mount is getting a good ground as well. If you still get noise turn up the squelch and if the radio has a noise blanker (ANL switch) turn it on.
  17. Jul 16, 2011 at 6:48 PM
    Brainless
    Greg
    Moses Lake, WA
    I have a ground strap from antenna stud to chassis already, I will try grounding chassis of radio and see if it helps. thanks!
  18. Aug 3, 2011 at 6:13 PM
    mrrobwood
    mrrobwood Member
    Rob
    Dracut MA
    10 SR5 DBL CAB
    Why not a NMO mount?
