First compound bow: Draw weight help?
Discussion in 'Guns & Hunting' started by 808Raider, Jul 13, 2012.
  1. Jul 13, 2012 at 5:27 AM
    808Raider
    808Raider [OP] Well-Known Member
    hawai'i
    any bowhunters out there have a good idea for what kind of draw weight i should look for on my first compound bow? going to get my first one and unfortunately there is nowhere near me to try out bows and feel whats comfortable so i have to look for one online. gonna be hunting deer, goats, pig and mouflon. my draw length is 29in and im 6'0 210 pretty fit build dont know if that matters but anyone have a good idea what i should look for? thanks
  2. Jul 13, 2012 at 5:55 AM
    WB750
    WB750 Well-Known Member
    Wade
    Fuquay Varina, NC
    2014 DCSB TRD Off-Road 4x4
    Weathertech Digitalfit Floormats, Sportsman Camo Seat Covers (Mossy Oak Breakup), BAMF Bed Tie Downs, G-TEK Door Sill Protectors, Tailgate Anti-Theft, OEM Bed Mat, & OEM Door Sill Protectors.
    70 lbs should be fine.
  3. Jul 13, 2012 at 10:03 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    go straight to 70lb..it's easy.
    plus you can turn the limbs down in the beginning if you feel stressed about it.
    (my mathews will turn down 10lbs with no problems)
  4. Jul 13, 2012 at 10:04 AM
    aficianado
    back to bone stock.
    a modern 60lbs bow would get it done if you want to go that way..
    you Hawaii guys have a cool outdoor option..cool beast to chase..cool fish to catch. lucky.
  5. Jul 13, 2012 at 10:07 AM
    Holyfather
    Holyfather Well-Known Member
    Arizona
    2011 TX Pro TRD
    Front Bilstein 5100s @ 1.75"
    I agree with the other guys. 70 lbs draw should be perfect for you. I shoot 29" draw at 70 lbs. I'm 6'2" 170 lbs
  6. Jul 13, 2012 at 10:08 AM
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    70 lbs.. I have an older compound that is 90 lbs which is brutal.
  7. Jul 13, 2012 at 10:09 AM
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    a 70 will be fine.
  8. Jul 13, 2012 at 12:11 PM
    808Raider
    hawai'i
    Thank u all. The bow I was looking at was gonna be in the 55-70 range but they will adjusts draw weight for me so what your all saying is have it adjusted to 70lbs right? Sry I'm a noob lol
  9. Jul 13, 2012 at 12:12 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    I pull 72, lbs when I'm deer hunting, the bow I use for fishing is only 60 lbs. hope that helps
  10. Jul 13, 2012 at 12:27 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I'd start out on the lowest end, if you have never had a compound bow you need to practice technique until it becomes automatic, then you can increase the draw weight. If you start at a high draw and learn bad technique it's a lot harder to improve. I don't know about pigs but I know 50 lbs is plenty for deer.
    What the hells a mouflon??
  11. Jul 13, 2012 at 12:59 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    looks like these guys are dead on.
    55,60,65,70# should all be sufficient.
    because they are adjustable, 70# may draw hard at first, but by practicing at a lighter draw weight, and using certain muscles, the heavier draw wt. will get easier. You may even feel more comfortable with a 60# draw.
  12. Jul 13, 2012 at 1:28 PM
    sportsterchop200
    sportsterchop200 Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    What he said^^^^^^^^^^^^^^^^
    50lbs is plenty for everything you listed. I recomend a 60lb bow. On many of the wide adjustable range bows, the lower you adjust the poundage the louder and more vibration they seem to make (in my experience anyway). Most 60lb bows are rated for 61 or 62lbs anyway. All that is happening when you lower the poundage is your backing the limb bolts out which gives a lighter limb pocket to limb fit creating more noise and vibration.
  13. Jul 13, 2012 at 1:32 PM
    aficianado
    back to bone stock.
    mouflon = corsican ram. i think.
    what bow allows you to have that much adjustment range? i know of several, but which one are you after?
  14. Jul 13, 2012 at 1:33 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Yeah 50 pounds is plenty. The pull on my pse is 70. But definite start low. Just don't back the limbs out too far. And never ever dry fire it
  15. Jul 13, 2012 at 1:34 PM
    sportsterchop200
    NE Georgia
    03 TRD Tacoma 4x4
    Im guessing a Mission
  16. Jul 13, 2012 at 1:38 PM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    I pull 75# with ease and it does just fine for pushin thru a deer (probably more than enough), sounds like we're about the same size, you shouldn't have any issues with what you're lookin at
    EDIT: x2 on the "Never dry-fire"
  17. Jul 13, 2012 at 1:41 PM
    BassMaster06
    Dan
    South Carolina
  18. Jul 13, 2012 at 4:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    I usually stay around 60#..........my Mathews shoots fast enough at 60,and my shoulders are close to worn out. On newer bows.......60is fine. You can always go up and readjust a tad.
  19. Jul 13, 2012 at 4:58 PM
    Hubs
    Hubs Well-Known Member
    Mine is a Mission adjustable from 50 - 70 lbs. So that is a good way to go.
  20. Jul 13, 2012 at 7:34 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    If it's your first bow, you'll probably want a lower draw weight just so you can get a decent amount of practice in. Personally I bought an older Bear for about $25 that had a peak draw weight of 50#. After firing a bunch at 40#, replacing the string (I literally shot my target out :p), and firing a lot more at 50#, I finally felt competent enough to buy the PSE, and it's still around 60# (peak 70, I backed it off a wee bit). Once I get the muscles for it, then I'll turn it up.
    Then there's the let-off. If you're only allowed to hunt with 65% in your area, you may want to consider a lower draw weight. With 80% let-off it'll feel like you can stand there at full draw all day in comparison.
    It's all about the distance. Speed gives you distance. It both flattens the trajectory and helps beat the instinctive jerk of your quarry. It doesn't do jack squat for killing power, unless you get the arrow bouncing off bone or something. Once you're north of 70# on a hard cam bow, it's really for those 40+ yard shots that I personally won't try.
    Modern bows are so much faster at the same weight too. Look around the internet for comparisons of different cam types and how they affect speed. My old Bear is a wheel bow, so it has a smooth draw but only about a 40% let-off and because of the mechanical advantage of the wheels (it only needs 50# of force at half-draw, and less everywhere else) it won't crack 160 fps with my arrows. In comparison the single cam PSE is much more aggressive, i.e. it can give more force to the arrow through more of the rotation of the cam than the old wheels, so even with 400 grain arrows is north of 260 fps. It gives peak draw weight for about 2/3 of the draw cycle.
    Then there's cam and a half, and dual cam bows, each with benefits and drawbacks. In general the dual cams can give the most speed but the tradeoff is that the peak weight of draw happens pretty much anywhere in the string's travel (except at full release and full draw) so a 60# hard dual cam can feel as hard to draw as a 70# milder single cam.
    Another rule of thumb is that if you have two bows of the same model but different peak draw weights, say a 60# bow and a 70# bow, and you back out the limb bolts of the second bow so it draws 60#, it'll shoot slower than the bow that peaks at 60. Wierd, but that's the way it goes. That's the main reason (that and vibration as previously said) you want to be near your draw weight goal.
    Consider brace height too (distance from riser handle to string), in general the faster bows have smaller brace height as the string travel takes up more of the draw length. More brace height is more forgiving for twitching, and literally takes less energy to draw at the same draw weight because the draw distance is less; when you're down to the 5" range, sometimes you'd swear that coughing the next day will influence your shot until you get a lot of practice.
    Much more to consider with a compound bow than just draw, but good luck on your purchase.
    Just don't be like my 1st stepdad. 95# wheel bow with 50% letoff on a 31" draw, just to make 220 fps... although, he was buff. I couldn't even pull that string back 6".
    Another little tidbit, don't believe that IBO speed. That assumes 30" draw, 70# weight, and a 250 grain arrow. Most bow manufacturers void your warranty if you shoot an arrow with less than 5 grains per pound of draw weight because of risk of vibration damage to the limbs. That means a 70# bow should have a 350 grain arrow, minimum. D'oh!
