First day in snow for Taco - what do you do?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dkurtz42, Nov 15, 2018.
  1. Nov 15, 2018 at 6:12 PM
    #81
    AugustusJack
    AugustusJack Well-Known Member
    A.J.
    NW WA
    '19 DCLB OR, '00 XC 3.4L 4wd MT
    A belt buckle North of Houston on the way to Dallas. I wasn't lying about the Google. I like knowing of places.
    (Belt buckle being an official measurement on whatever scale I had Google maps on)
  2. Nov 15, 2018 at 6:13 PM
    #82
    Dkurtz42
    Dkurtz42 [OP] Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    I don’t live there. I wasn’t going to defend it. It’s not a bad place. Cost of living is half what Houston is but you can drive there in under an hour.
  3. Nov 15, 2018 at 6:16 PM
    #83
    airsickbuffa1o
    airsickbuffa1o Well-Known Member
    Anthony
    2017 Silver TRD OR
    OVtuned 1.03
    Used to be just north of Buffalo.. Good thing about there is that most people are competent enough to drive in the snow, and the municipalities know how to remove it.. I've moved to Long Island and it's a disaster here if just an inch falls.
  4. Nov 15, 2018 at 6:23 PM
    #84
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    First day of snow, drove around on snowy roads in 4H. Went to buy new hunting boots and after I turned off nannies and did some 2WD powerslides in an empty lot.
    If the roads are covered I'll generally have it in 4WD. Slowing down is important, but don't be that guy going 20mph in a 55mph when theres barely any snow and clear tracks.
    I'll do 55-60 in 4WD, but only in certain circumstances. Completely snow covered roads, no slush, no traffic, good visibility, gentle curves.
  5. Nov 15, 2018 at 6:37 PM
    #85
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Were you there in 78ish? I grew up on long point in lake Erie then. We had 25 ft drifts, and buffalo got pummeled worse.
  6. Nov 15, 2018 at 6:44 PM
    #86
    Dkurtz42
    David
    Barberton, OH
  7. Nov 15, 2018 at 6:45 PM
    #87
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Arizona?
    Riding Dirty likes this.
  8. Nov 15, 2018 at 6:51 PM
    #88
    airsickbuffa1o
    Anthony
    2017 Silver TRD OR
    OVtuned 1.03
    Nope, that was a good 8 years before I was born lol.
    TeecoTaco[QUOTED] likes this.
  9. Nov 15, 2018 at 6:52 PM
    #89
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The only possible use for 4 lo is if you are going down a very steep hill and want to be in 1st gear lo range so you don't have to use brakes. If anything it hurts traction. In fact from a stop starting in 2nd gear instead of 1st gear will prevent wheel spin. Which you want to prevent. Wheel spin heats up the tires and causes the snow/ice to melt. Then you have a thin layer of water between the tires and snow. Keep the rubber cold and it grips the snow much better.
    Locking the rear diff is generally a bad idea. If you're stuck and need some extra traction to get moving maybe. But unlock the diff as soon as you start moving. A locked diff will cause the rear end to slide to one side instead of tracking straight once underway.
    If it is safe to drive over 20-25 mph you don't need 4X4. If you need 4X4 it isn't safe to drive over 20-25 mph. The biggest problem is stopping. 4X4 doesn't help stop you, slow down.
    Use 4X4 as needed. They have a switch on the dash and it takes 2 seconds to go between 4X2 and 4X4 or back to 4X2. Road conditions vary depending on what has been plowed, melted, frozen over, or just snow. Learn to read conditions and shift into 4X4 BEFORE you need it. Shift out when you don't.
    erics likes this.
  10. Nov 15, 2018 at 6:56 PM
    #90
    TeecoTaco
    SW Ontario
    Snow vagina
  11. Nov 15, 2018 at 6:57 PM
    #91
    Lerxst
    Lerxst Active Member
    2018 SR5
    [​IMG] First snow run in the SR5 I bought 15 days ago. 3 inches of packed snow. Still coming down, no ice. Central Rhode Island hills. Started in 4 H
    Handled phenomenally
    Almost all highway. Sequenceial shift in 4. Bumped lower when needed to slow down and stop.
    Couldn't be happier.
    Not an overly confident driver in snow but have been doing it for 22 years. And know what to do.
    Dkurtz42[OP] and StayinStock like this.
  12. Nov 15, 2018 at 7:00 PM
    #92
    Dkurtz42
    David
    Barberton, OH
    Did you mean West Virginia? No, this was in buffalo. Lol
  13. Nov 15, 2018 at 7:04 PM
    #93
    TeecoTaco
    SW Ontario
    No, I mean the pic above looks like a snow vagina
    Tacoknife and uurx like this.
  14. Nov 15, 2018 at 7:06 PM
    #94
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    This was our November Storm of 2014, I’m 6’2” for reference.
  15. Nov 15, 2018 at 7:12 PM
    #95
    AugustusJack
    A.J.
    NW WA
    At the time of this posting, 36 members and 27 guests. Holy crap, guests. Register. It's simple to do, and helps in tracking thread viewing, if nothing else
    Dkurtz42[OP] and Riding Dirty like this.
  16. Nov 15, 2018 at 7:21 PM
    #96
    COOutlaw
    COOutlaw Old Guy-fan of: Shotguns,Birddogs,Flyrods,Whiskey.
    Colorado
    2019 DCLB TRD OR CEMENT
    None yet
    I was told a long time ago by a very notable professional driver: Quote- Beginners tend to save 4 wheel drive.....for what?
    I took this to heart from that moment forward....use your 4hi, that's what you bought it for. If traction improves and you no longer need it...disengage it, until then, it's not hurting a thing and only adding safety to your commute. IMO only. FWIW. YMMV. Outlaw out.
    Dkurtz42[OP], Lerxst and AugustusJack like this.
  17. Nov 15, 2018 at 7:26 PM
    #97
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    First thing take all the traction control stuff off, throw it in sport mode and have fun
    TeecoTaco likes this.
  18. Nov 15, 2018 at 7:31 PM
    #98
    TeecoTaco
    SW Ontario
    What is this sport mode you speak of? Is this when you don't punch the clutch til 5500?
  19. Nov 15, 2018 at 8:32 PM
    #99
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    I wish the Tacoma had a sport mode.
    Dkurtz42[OP] likes this.
  20. Nov 15, 2018 at 8:41 PM
    #100
    USPfan
    USPfan Well-Known Member
    North of 60th paralell
    2018 Tacoma TRD OR DCSB
    I love posts from people in the US panicking about a bit of snowfall. :p It hit -20°C here and has been snowing for 4 days non stop. Much more to come!
    YMMPRO likes this.
