first ever toyota gripe after 9 years if ownership
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yota243, Dec 22, 2012.
  1. Dec 22, 2012 at 4:10 PM
    yota243
    yota243 [OP] Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    So u had a brake pad fall off, came completely apart, stopping portion broke clean from mounting part . Not my gripe, got new padsand went to replace it, and got 3 lug nuts off no problem, the last 3 I had decided the tire place tighten too much and stripped the studs. While tryin to apply pressure and turn at the same time the "lug nut cap" came off. This is how I got the remainin two off. In doin so we broke them so I was going to take all if them off, 1 1/2 hours later I had the 6 from one wheel done. Why di they putthese caps on? Sockets don't fit over them right and they are a PITA TO GET OFF. Am I alone in this frustration? Painted nuts black just 18 more to go
  2. Dec 22, 2012 at 4:14 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Works great :D
  3. Dec 22, 2012 at 4:21 PM
    yota243
    E.J.
    north Alabama
    I assume they have been on there sine 05 since the "shoulders" were wore down from tire places using sockets with caps on, and actual nuts looked practically brand new. I read a lot if ppl having problems with.caps falling off, but I was not one of these. I will soon not have to worry with it any more.
  4. Dec 22, 2012 at 6:59 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Toyota studs are for shit. They break pretty easy compared to other makers even if you hit torque spec.
    Lube of some form is needed as well.
  5. Dec 22, 2012 at 7:10 PM
    yota243
    E.J.
    north Alabama
    It'd not the studs or nuts, its the Chrome caps on the nuts the I have come to loathe. Grease or anti cease with not resolve this issue that I am havin, I have found no way to remove the caps w/out destroying them, but u wouldn't put them back on anyway because theyre such a headache as previously described.
  6. Dec 22, 2012 at 7:24 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The dry torque is 85 ft lbs... what's the torque value changed to when using anti-seize?
  7. Dec 22, 2012 at 7:28 PM
    Supra TT
    Eric
    Indiana
    Over 5 years no problems with just the same torque value. Not to mention the 500 other vehicles I used the anti seize on
  8. Dec 23, 2012 at 5:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When was the last time you had the wheels & tires off?
    Do you rotate your tires/wheels regularly?
  9. Dec 23, 2012 at 6:24 AM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    After nearly seven years of ownership many of my lug nuts are toast for this very reason. I've always used a socket (usually 12-point) or the factory tire iron to remove and/or reinstall them, then a torque wrench to snug them to 85 ft-lbs. The only time they've ever seen an air impact ratchet (or whatever those things are called) was at the tire shop when I had the original tires replaced. On a recent tire rotation I found that many lug nuts started to become oblong/marred and wouldn't accept a 21mm socket or the tire iron. I had to use a 7/8" impact socket on an air driver to remove them. I then replaced the bad lug nuts with newer ones I bought from a member here.
    I will only use a 6-point 21mm socket from here on out - not a 12-point socket or the tire iron.
  10. Dec 23, 2012 at 6:52 AM
    Janster
    Jandy
    Lancaster, PA
    Same here.....
    Anti-seize every time when rotating the tires every 5,000K miles. I use a impact gun with a 100lb torque stik and go over them again with a regular torque wrench at 100lb. Every vehicle I've ever owned and never had problems with lug nuts or studs ever.
  11. Dec 23, 2012 at 7:05 AM
    northern cal
    northern cal Active Member
    bay area
    tacoma TRD
    As a rule of thumb, -10 to -15% of dry torque vaule. 85 ftlbs - 10% = 76.5 ftlbs.
    I haven't checked with the Tacoma but most manufactures say do not use anti-sieze or any lubricant.
  12. Dec 23, 2012 at 9:49 AM
    OffroadToy
    Good info... Thanks. I tried to find the thread here about the damage that results if the wet/dry torque value isn't taken into concideration. The thread showed pictures of multiple broken bolts and stripped threads.
  13. Dec 23, 2012 at 11:30 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Used anti-seize and air gun for years.
    Zap on, Zap off. Never had problems.
  14. Dec 23, 2012 at 1:32 PM
    yota243
    E.J.
    north Alabama
    March when I got new tires, again no problem witg the nuts coming off after I got the Chrome caps off. The "nuts" u see are not actually nuts, the nuts are under the caps which are stamped on the nuts from what I can tell
  15. Dec 23, 2012 at 2:14 PM
    Janster
    Jandy
    Lancaster, PA
    I had to go back and re-read your original post.
    You mentioned your brake pad came off ....
    Sounds like whoever installed your wheels/tires the last time, didn't tighten the wheel enough (or it came loose). While the wheel was loose... and you drive on it .... The pads come loose, it could put pressure on the caliper which would bend & snap mounting bolts, pads come out.... wheel studs get bent and/or threads get bitched up.
    Then...when you try to remove the lug nuts, there are no threads to unscrew them off with and you end up trying TOO HARD to remove them and break the outter shell of the lug nut off.
    That's my guess......
    Either way.... Sounds like you need new lug nuts and I would definitely inspect the studs too. Make sure they're not stripped or bent.
  16. Dec 23, 2012 at 8:07 PM
    fjrmurph
    fjrmurph Well-Known Member
    I use never sieze on everything i have apart including wheel studs. I think 90% of the time when you have a garage change tires or rotate tires, they are over torqued. They always use a impact wrench, they are always in a hurry, there is always a young kid doing tires. No garage is going to pay an experienced journeyman mechanic to change tires when the can get a kid to do it for half the money. How many times have i had my rotors ruined because the front wheels are not tightened properly.
    My rant for the day
