First ever truck and could not be happier!
Discussion in 'New Members' started by Wrigley142, Oct 16, 2020.
  1. Oct 16, 2020 at 3:32 PM
    Wrigley142
    Wrigley142 [OP] New Member
    2021 White Tacoma SR 4x4 Double Cab
    I just purchased our second ever new car and my first ever truck! We just paid off my old used car and our 2017 Ford Focus so decided to go with a truck. I grew up in a Chevy household with my grandpa driving Silverado's as long as I was alive but I wanted something efficient reliable that also looked good. After a lot of research I landed on a 2021 Toyota Tacoma SR with 4x4 and a double cab and it is stunning and the warranty that came on it is incredible. The double cab was a must for us because of our very large Make doberdane that loves car rides. Unfortunately every single TRD Pro was sold out or pre sold and the city I live in had backorders of several months.(would have extended the budget for a pro) But, like the planets aligning we were able to find the one remaining Tacoma in the entire city under our price point of $35k for a non TRD Tacoma.
    We just recently purchased property out in the country off of one of the roughest dirt roads I’ve ever seen and taking the Ford Focus down there was a risky play every time. We will be definitely getting some mud on the paint and using it for quite a bit of hauling as we develop our property but I could not be happier! I am glad to be a new member to the community!
  2. Oct 16, 2020 at 3:33 PM
    Bigdaddy4760
    Maner
    Poolville Texas
  3. Oct 16, 2020 at 5:10 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    buckhuntin-tacoma and tcjacado like this.
  4. Oct 16, 2020 at 5:12 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Nice and welcome to TW!
    buckhuntin-tacoma likes this.
  5. Oct 16, 2020 at 5:12 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW
  6. Oct 16, 2020 at 5:18 PM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Just bought my first truck too, welcome!
  7. Oct 16, 2020 at 5:21 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Welcome! Lots of nice Helpful people here.
  8. Oct 16, 2020 at 6:16 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    tcjacado likes this.
  9. Oct 18, 2020 at 9:13 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  10. Oct 18, 2020 at 8:11 PM
    JBIdaho
    JBIdaho Active Member
    Jon
    2013 Green Tacoma TRD Sport
    First of all welcome to TW, I’m new myself.
    I was always told that unless you send pictures, it didn’t really happen..... waiting...
  11. Oct 19, 2020 at 4:49 AM
    Wrigley142
    Sorry about that! I thought I did attach a photo! Photo now attached from our country property and man it was fun to take this down the road less travelled. There’s a backroad into the property after you hit the gate and it was a wash out yet again and it was fun navigating it.
    Charlie Too likes this.
  12. Oct 19, 2020 at 5:31 AM
    JBIdaho
    Jon
    Wow great and clean looking truck. Going capture! Thanks for the picture. Have fun
  13. Oct 23, 2020 at 8:39 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
  14. Nov 27, 2020 at 9:54 AM
    GreysonTHAO08
    GreysonTHAO08 Member
    Greyson
    Tacoma
    Congrats man. Here’s my 2017 tacoma Sr 4x4
  15. Nov 30, 2020 at 2:37 PM
    Mattjoz
    Mattjoz New Member
    2020 TRD Sport
    Congrats! Welcome
