First experience with a flat with my Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pan704, Oct 21, 2013.
  1. Oct 21, 2013 at 11:33 AM
    Pan704
    Pan704 [OP] Active Member
    Rich
    Charlotte, NC
    PreRunner SR5
    So while I'm driving back home down a pretty country road. I drove past a construction zone and hear a pop. Didn't think anything of it, then saw the "exclamation point" hazard on the dash. I pull over and hop out and I can hear the hissing sound. Back passenger tire had a bent piece of metal in it that was folded over itself, so it was pretty much a straw in my tire. This is when it got interesting....
    So I pull out my oem jack for the first time ever and wouldn't you know, it's short and to make it worse, I'm on a short, crappy, dirt shoulder that isn't far from even. I find a flat piece of concrete and started jacking, finally, some movement. Luckily, I had a tire plug kit and cigarette lighter pump from my last SUV. I get the lug nuts off and pull the tire off...mistake. Because of the suspension and hill, the rotor dipped down just a hair too low for me to easily put the tire back on. So now I'm trying to figure out how to raise that part up just a little higher so that I could put the tire back on. After a few minutes, I decided to just grab a set of ratcheting ties, looped it around the axle (bad I know) and hooked the end to the far side of the bed. Luckily I didn't take much but lesson learned.
    First thing after work, I'm buying a new jack, a couple tall jack stands, chop up a few wooden blocks, and get another tire plug kit to keep in the truck. Live and learn.
  2. Oct 21, 2013 at 11:39 AM
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    Hopefully next time I get a flat, its on a road with a proper shoulder.
  3. Oct 21, 2013 at 11:52 AM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    where did you place the jack? If you place it under the axle...the jack has plenty of extension....
    :notsure:
  4. Oct 21, 2013 at 11:56 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    ^^bingo,. Glad you were creative enough to fix your situation though.
    ^^ drum
  5. Oct 21, 2013 at 12:18 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2 and why did you feel the need to remove the tire just to put a plug in?? I just plugged my driver's side tire yesterday from a nail puncture and never even got my jack out. Glad it worked out but you definitely did things the hard way.
  6. Oct 21, 2013 at 12:23 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    yup..get the jack under the axle.
    while you're at it..practice getting that spare tire out while you are in a nice driveway. personally, i think that is the shitty part of the job. you jam the end of the jack rod into the spare tire winch thing. it is like a square peg into a round hole. it sucks. and you have to push that rod into free air space to even find the winch hole..it is a really good time!!
  7. Oct 21, 2013 at 12:31 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Yep, hard enough to get the spare in day time but try doing that in the dark...
  8. Oct 21, 2013 at 12:58 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    I'll bet if there was some pink around that hole, you'd have no problem finding it!;)
  9. Oct 21, 2013 at 1:01 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    :ohsnap:
  10. Oct 21, 2013 at 1:17 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    After all, it is "I love pink" month!
  11. Oct 21, 2013 at 2:04 PM
    Pan704
    Rich
    Charlotte, NC
    PreRunner SR5
    I didn't think it was ok to jack it up by the axle so I did it a little in front of the back wheel. I was a little irritated that I had to dig through the woods to find a spacer for the jack. Good thing there was a pile of broken up concrete near by. By that point, I was just ready to get it done. The jack went up and the tire was off before I realized that was a bad place. Now I didn't just want to sit the bear hub (thanks Sandman614!).
    I usually don't take the tire off for a plug but the piece of metal was deep and the jack on a rock was sketchy. I didn't want anything to tip over. If I knew it would've been such a pain to get back on, I would have risk it.
  12. Oct 21, 2013 at 5:41 PM
    smd3
    smd3 Well-Known Member
    Double check the manual, he jack should go under the axle. The ubolt plate on the bottom, probably. The factory jack can't support the weight of the whole vehicle by the frame, it just lifts the wheel by compressing the suspension.
    I saw a young kid destroy his jack by trying to lift the front of the truck at the frame. It goes under the a-arm up there.
  13. Oct 21, 2013 at 6:46 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Yes I had to change my first flat with my truck the other day.
    Same thing hit something in the road, tpms went off, tire flat as a pancake.
    The conditions were not as horrible as yours but I was on a back road no cell signal so took out the tools.
    It all went ok except for the tire underneath was filthy though was very grateful it was there. :)
    The jack did fine & prayed it would stay up since the top isn't that big, like the size of half dollar.
    I had to have faith it would be ok.
    Lifting the tire well I did ok, I got it up there, it wasn't pretty :eek: but it worked.
    Yes lowering the tire was the biggest pain in the a$$
  14. Oct 21, 2013 at 7:28 PM
    mutilatedjak
    WA
    Truck manual should verify under the axle is good to go.
  15. Oct 22, 2013 at 10:36 AM
    Pan704
    Rich
    Charlotte, NC
    PreRunner SR5
    No doubt I did it the hard way! Its one of those things you don't think about until it's done wrong. We all know how to change a tire and it's rarely something you dig in the manual for but I should have!
  16. Oct 22, 2013 at 11:30 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's all about being SAFE. Surely, we've all done things 'out of procedure' to get ourselves out of a pinch. As long as you didn't get hurt and have learned.
    Sometimes, you gotta do what you gotta do.
    I hit a piece of flying debris on the highway last summer. It took a chunk out of my grill, gouged my front bumper and slashed my front tire. Thank God for the TPMS. I got off the highway and to a parking lot safely. I can't say much for my OEM jack - frigin thing wouldn't go up at all after endless cranking on it. Called the husband and he brought out the Craftsman hydraulic jack.
    As for the OEM jack... We played with it enough until it finally started working (after we got home). I'm not sure I'd trust it again. But then again... Husband and AAA are my backup.
  17. Oct 22, 2013 at 11:30 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Lol, don't beat yourself up about it. There's definitely worse ways to experience a flat tire.
    I had one with the girlfriend's car when we were on our way home from NH this summer. In the middle of a thunder & lightning storm, on top of a hill, in a big field. And it was a front tire, and she's just got one of those crappy cheater spares. I think I must've set a world speed record for the "jack the rear, pop the good tire off and the spare one, drop the rear, jack the front, pop the flat tire off and the good tire on and drop the car" event.
    Crappiest. Flat. Ever.
  18. Oct 22, 2013 at 11:43 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^This. It probably would have been easier to remove still on the truck, cause then you can really put some elbow grease into removing it cause it's still anchored to the truck. I did it a week and a half ago on mine. Same thing, rear drivers side. Chunk of metal that looked like a miniature pick axe. Once I pulled it out my tire deflated in under 2 minutes if not less. Reamed, plugged, pressurized and good to go in 15 minutes.
  19. Oct 22, 2013 at 11:46 AM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    LOL. BEST LAF TODAY
  20. Oct 22, 2013 at 11:53 AM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    I had to change a tire in -10° weather in WY with about 50 mph of wind blowing the snow tacked on. What happened was I hit black ice and started spinning, spun towards the median and hit a gravely spot and ripped the tire off the wheel. And to top it off I was wearing shorts and a light jacket and sperry top siders
