First gear/reverse Manual trans questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cameron172, Oct 27, 2012.
  1. Oct 30, 2012 at 11:58 AM
    BamaToy1997
    Bill
    Navarre, FL
    The 4 cylinders have TOB issues as well. Mostly just general wear and part failure. I got a brand new one a while back and it made noise from the start. Had to parts-warranty it. Perhaps not as much as the V6 ones, but yeah, still have issues.
  2. Oct 30, 2012 at 12:40 PM
    Corvus
    Corvus As the crow flies
    Cary, NC
    '12 2.7 5sp 4x4
    I noticed something like this with my brand spanking new '12 2.7. It doesn't want to go into first even with the clutch all the way in while rolling at a decent speed.
    With my muscle cars, I used to get ready for a tight turn by clutching in and going to first and then braking and letting it out. Taco doesn't seem to like it too much. Seems it would rather lug in second. Haven't tried rev-matching too much think it may help with it.
    Reverse isn't an issue though and it certainly doesn't lock me out. Just sometimes it seems to take more force to get it into first while moving and I think I can hear the syncro whirring.
    More info on this would be great, don't want to put a lot of premature wear on my new baby :D
  3. Oct 30, 2012 at 3:22 PM
    BamaToy1997
    Bill
    Navarre, FL
    Not much more info than what has been given I don' think. Different manufacturers set up their transmissions differently. Most every manual uses a syncro to match up the input and output speeds for engagement. the faster you are going, the closer the shaft speed is, so it becomes easier to shift into those gears. First gear tends to be one of those that has the most difficulty.
  4. Oct 30, 2012 at 3:33 PM
    Corvus
    Cary, NC
    '12 2.7 5sp 4x4
    I guess I just think it was more noticeable that it didn't like shifting to first even with the clutch fully depressed. Guess I didn't know that the syncro would be working then. Makes sense though thanks :)
  5. Mar 31, 2015 at 5:52 PM
    eppy
    eppy Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Hey fellas,
    Have a 105k on my Taco and just noticed an issue when attempting to shift into first. The stick feels like it's not locking in crisp and instead feels like its bumping off third and falling in!!! Thought it is was just me at first, but noticed a little difficulty shifting into reverse also.
    Was wondering if it is a synchronizer issue, what it would cost to repair???? My buddy is a Taco Mech and have kept her well maintained with routine lube maintenance and etc. so not sure if a clutch job is needed or something with the stick because I hear a lot of chattering???
    Any help would be appreciated,
    Eppy
  6. Mar 31, 2015 at 7:44 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    The chattering is probably the clutch. You should get the URD throwout bearing while you have it apart. As far as the 1st/reverse issue it probably is the syncros. If you do it yourself the parts will be a few hundred bucks. If you pay someone else to do it I would guess it's $1500 for the trans rebuild, maybe more, plus the cost of a new flywheel, clutch, and the URD takeout bearing...could be as high as $3000. Talk to your mechanic buddy.
  7. Feb 10, 2016 at 2:06 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I have a w59 and my transmission has slowly been getting harder to shift into 1st and reverse from a dead stop. It kinda feels like the clutch doesn't fully disengage. For example it takes a while to spin down or feels like it won't spin down. Some days worse than the other. I typically rev match all the time. The last owner put a performance clutch in it. I put 30k on the truck since I bought it 6 years ago. The clutch doesn't rattle and bites really hard. Curious what should be plan of attack. Clutch wearing out? Transmission need service?
