First gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nastruck, Aug 27, 2020.
  1. Aug 27, 2020 at 1:40 PM
    nastruck
    nastruck [OP] Well-Known Member
    Harold
    Mills
    Running boards Soft bedcover Ventshades
    I just bought my first Toyota a 09 Tacoma TRD sport. I got it at a local Toyota dealer. Its a one Owen and was was just traded in on another truck. Just under 150,000 and super clean. What scares me is when I slow for a speed bump or heals sign it is slow shifting into first gear and some times it will bang into gear. This only happens sometimes and other than that it shifts normal. The dealer tells me it is normal because of the split driver shaft. This is my first Toyota and my first 4WD.
    Are they thing e the truth? Is it my driving causing the problem?
    The truck is perfect other than the first gear thing!!!!
    Thank for any advice
    Harold
  2. Aug 27, 2020 at 1:45 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I'm no pro but I don't think it should ever really bang into gear with automatics. Shifting should be pretty consistent when it shifts up and down.
  3. Aug 27, 2020 at 3:22 PM
    nastruck
    Harold
    Mills
    Most of the time it is fine. It happens when I slow almost to a stop and then accelerate. I have been watching the way I drive and I've gotten better. I'm just wondering if it is normal.
    Thanks for the reply
  4. Aug 27, 2020 at 3:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This sounds like axle wrap.
    It is noticeable more when coming to a stop. You are likely feeling it more due to pressing the gas right as it’s happening.
    The “weak” leaf springs on these truck from the factory don’t help it.
    Only other thing maybe be low Trans Fluid. But you probably be seeing the same problem while cornering slowly.
    As in going into a turn at slow speeds.
  5. Aug 27, 2020 at 6:24 PM
    nastruck
    Harold
    Mills
    Fluid level is good and fluid is fresh!!!!
  6. Aug 27, 2020 at 6:32 PM
    TnShooter
    Deogee
    STOCK
    Typically they shift hard on UP shifts when the fluid COLD.
    However, I have experienced a few hard down shifts, but the fluid was COLD then as well.
    It’s possible, maybe, that your timing from -brake to gas- is timed just about the when your
    axle “catches up” (axle wrap).
    If it weren’t for the “bang” right when it shift, I’d be almost positive it was axle wrap.
    BTW, if you are ever at a stop, and feel a “tap” or “lurch” forward.
    That’s normal, it the A/C compressor kicking on, it bumps the RPM up.
    Just figured I’d let you know.
  7. Aug 27, 2020 at 7:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I thought they had a transmission reflash that took care of this issue....
  8. Aug 27, 2020 at 8:00 PM
    TnShooter
    Deogee
    STOCK
    Only one for the TCU that I know of is for 2012+
    And it was for spark knock.
    I always found it “strange” that those were the years when they added the Air Injection.
    The guys that had the issue, and couldn’t get it to go away, later reported that the 3 degree cam gears were the only fix they found.
    https://static.nhtsa.gov/odi/tsbs/2014/MC-10132709-9999.pdf
  9. Aug 28, 2020 at 6:46 AM
    nastruck
    Harold
    Mills
    I think you are right (Hoping) about the timing getting back in the gas. If I pay attention to it shifts perfectly. The bang only happened once and I was a little to hard in the gas. I think that was the day after I got it.
    What do you mean by axle wrap????
    old habits are hard to change. I've been driving for many many years So this is very new to me!!!!
  10. Aug 28, 2020 at 8:38 AM
    NotUrTaco
    NotUrTaco Well-Known Member
    Richmond, VA
    2008 Silver 4x4 Access Cab
    Just to make sure we're talking about the same thing, you went through the whole ordeal of jumping the OBDII ports and making sure it's in the correct temp range, etc?
  11. Aug 28, 2020 at 10:14 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    It’s not axle wrap
  12. Aug 28, 2020 at 1:08 PM
    nastruck
    Harold
    Mills
    I told the dealer I thought I might be low on fluid so they checked it for me and said everything is fine and that the shifting was normal because of the two piece driveshaft
  13. Aug 28, 2020 at 1:59 PM
    NotUrTaco
    Richmond, VA
    This sounds like the sort of problem @gearcruncher could shed some light on.
  14. Aug 28, 2020 at 7:19 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Sometimes if you push on the accelerator peddle at just the right moment you give the truck more gas at exactly the same time it changes to a lower gear. It feels like a hard shift, but in reality is just bad timing.
    I've also had moments where I was cruising along and for whatever reason needed to accelerate quickly. I've pressed hard on the gas pedal at the exact instant the truck upshifted from 3rd to 4th, then it immediately had to downshift to 2nd to get the power I needed to merge or pass another vehicle. It creates an awkward shift, but once again is just unfortunate timing. It doesn't hurt anything and only happens under specific, but rare conditions. I've had the same thing happen in other vehicles too, not just Tacoma.
    Jimmyh and nastruck[OP] like this.
