first gen aftermarket muffler question
Discussion in '1st Gen. Tacomas (1995-2004)' started by xfrankx, Mar 1, 2014.
  1. Mar 1, 2014 at 10:29 AM
    xfrankx
    xfrankx [OP] Well-Known Member
    Well the stocker on the taco rusted out so I'm looking to replace it with something that has a bit more sound while I'm at it. Anyone know what mufflers out there will work with the stock exhaust? Meaning does anyone know the diameter of the inlet and outlet so I can get something that's an easy fit.
  2. Mar 1, 2014 at 4:12 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    I had my rear wheel off and noticed my muffler is pretty rusted through. The whole exhaust has a generous coating of rust..but that's an exhaust system for you.
    Even though it's clearly rusted, it's still very quiet. Which I enjoy greatly.
    I wouldn't mind a humble growl, but I don't want to be one of 'those' Dodge Ram or Silverado guys that ALWAYS have some screaming exhaust.
  3. Mar 1, 2014 at 5:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    There are a few cat back options out there but most folks just have one welded onto the existing pipes. Either a 2.25" or a 2.5" opening on the replacement muffler is close enough to work with.
    My recommendation is an 18" Magnaflow. Nice tone, not too loud and no loss of performance. Her is the one I went with.
    https://www.magnaflow.com/02product/shopexd.asp?zone=main&id=11395
  4. Mar 2, 2014 at 12:01 AM
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    Magnaflow
  5. Mar 2, 2014 at 12:28 AM
    bk808
    bk808 Well-Known Member
    Brian
    Kaneohe,HI.
    OME lift,882's,10mm top plates,Dakars w/dx6l,ss extended brake lines, LR uca's, poly bushings thru out, PC'd Tundra rims,285-70-17 Goodyear AT's,TG weld on sliders,TG rear bumper,deck plate mod,AFE pro dry filter,Airaid M.I.T., Grillcraft insert,Celica bucket seats,Wet Okole covers,Husky floor mats,Ultragauge,Hi lift jack,LED's on all lights in and out.
    Dynomax Super Turbo. A bit louder than stock,but no drone at freeway speed.When i
    was looking for my replacement it was also the cheapest.
  6. Mar 2, 2014 at 12:29 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    exactly what I'm running too
    perfect tone, no cabin drone at all
  7. Mar 2, 2014 at 1:00 AM
    marintacoma
    marintacoma Well-Known Member
    Marin
    2004 white toyota tacoma 4x4 trd
    Not a lot of people seem to run these, but I described the same thing as you to the muffler shop and this is what they recommended, definitely sounds great, but not too loud with the windows up
