first gen bulb types FYI
Discussion in '1st Gen. Tacomas (1995-2004)' started by rab89, Dec 16, 2010.
  1. Dec 20, 2013 at 11:56 AM
    #101
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Ok so I went to put the lil 74 led bulb from superbrightleds in my shifter console on my 03' and it doesn't stay in. It lights up but won't snap in? Thought I read that it's not really a 74??? :notsure: thinking maybe just a dab of glue or something but that's pretty shitty way to make it work. Any input?
  2. Dec 21, 2013 at 9:51 AM
    #102
    DSully72
    DSully72 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    I put the 74 in mine and it works just fine. I don't remember if it snapped in or not but it seems to stay in pretty well. mine isn't loose or anything.
  3. Dec 21, 2013 at 10:30 AM
    #103
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I've got 74s in my shifter so I dunno, easiest thing to do is slightly pinch the inside of the socket then press the bulb in
  4. Dec 21, 2013 at 11:16 AM
    #104
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    ^This…
    It's deff a #74
  5. Jan 16, 2014 at 6:26 PM
    #105
    bellassaiw10
    Currituck NC
    Should fit fine
  6. Jan 16, 2014 at 7:03 PM
    #106
    DSully72
    Daniel
    Appling, GA
    I got the 921 CREE LED back up lights a while back. forgot to post in here. but I F****** LOVE THEM!
  7. Feb 15, 2014 at 5:10 PM
    #107
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Awesome post OP. Rear brake light went out, figured is a good time to go LED. Is there a vendor that sells complete kits? (brake light, backup light, blinkers and blinking relay etc). Thinking of doing the front switchbacks as well.
  8. Feb 15, 2014 at 9:04 PM
    #108
    gman2530
    gman2530 Well-Known Member
    San Diego, Ca.
    04 PreRunner
    Installed a set about a week ago, there is plenty of room... No Issues....
    >G
  9. Feb 16, 2014 at 1:25 PM
    #109
    DSully72
    Daniel
    Appling, GA
    Glad to hear about those emblems man! im looking at debadging soon... im nervous though I know my paint has faded quite a bit so im hoping I can somehow hide any "ghost badges" I get from the debadging
    I got the single projectors. I just tried to find some that weren't too cheap looking construction wise although im sure they all work the same. kinda do wish I got the ones with leds on the sides just because you can tell they don't go off the reflectors at all. they almost look like a retrofit for my back up lights haha
  10. Apr 5, 2014 at 9:51 PM
    #110
    Chriscoe
    Chriscoe PIG
    Seagrove, NC
    98 Tacoma SR5 4x4
    Stocky Stock Stock
    Can anyone make a list of how many bulbs to buy. I plan on changing mine out on my 98
  11. Apr 5, 2014 at 9:55 PM
    #111
    bellassaiw10
    Currituck NC
    Depends on what you want... Just go to superbrightleds and they have a bulb selector that tells you every bulb you'll need
  12. Apr 5, 2014 at 10:36 PM
    #112
    Chriscoe
    Chriscoe PIG
    Seagrove, NC
    98 Tacoma SR5 4x4
    Stocky Stock Stock
    I'm there I just need to know how many to buy
  13. Apr 5, 2014 at 10:37 PM
    #113
    Chriscoe
    Chriscoe PIG
    Seagrove, NC
    98 Tacoma SR5 4x4
    Stocky Stock Stock
    Also which bulb will fit the light ring around the ignition
  14. Jul 12, 2014 at 10:12 AM
    #114
    DSully72
    Daniel
    Appling, GA
    How about the map lights? The lights in the piece that the rear view mirror hangs from.
  15. Jul 16, 2014 at 3:05 PM
    #115
    DSully72
    Daniel
    Appling, GA
    Okay so I'm assuming the map light bulbs are the same as the dome light bulb? They look about the same after taking them out. Has anyone replaced these bulbs? I need to find one that fits and works properly. I bought some from ebay for my dome light and it doesn't fit well and strobes when it should be on
  16. Jul 18, 2014 at 9:59 AM
    #116
    DSully72
    Daniel
    Appling, GA
    Also has anyone found a place to buy nice bright led bulbs that are cheaper than superbrightleds.com? I bought some off Amazon for my gauges because one went out and they are dim as hell.
  17. Jul 18, 2014 at 6:45 PM
    #117
    bellassaiw10
    Currituck NC
    Spend the money, cheap LEDs suck I've had my superbightleds for about 4.5 years now
  18. Jul 18, 2014 at 8:40 PM
    #118
    DSully72
    Daniel
    Appling, GA
    that's what I had behind my gauges originally and one went out after less than a year
  19. Jan 7, 2015 at 8:01 PM
    #119
    Hawaiisurfer
    Hawaiisurfer Well-Known Member
    Utah
    '01 Tacoma Double Cab
    Does anyone know how many lights are needed for the instrument cluster?
  20. Feb 12, 2015 at 3:53 PM
    #120
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
