First gen Extended Cab Topper/Camper shell
Discussion in '1st Gen. Tacomas (1995-2004)' started by Carson_SR54x4, Sep 23, 2019.
  1. Sep 25, 2019 at 9:26 AM
    jtakeda
    jtakeda Well-Known Member
    2002 Turd
    I don’t have windows on my shell. I do sometimes wish I had some but I live in the center of a crime zone and I’d rather not have my truck get broken into.
    I never leave anything in there but people just break windows for the hell of it over here
    Hamer95USA likes this.
  2. Oct 31, 2019 at 10:35 PM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    My $275.00 craigslist special, from an 89’ Toyota. ARE is the sh&t!
  3. Jan 20, 2020 at 1:22 PM
    DustyT22
    DustyT22 Well-Known Member
    Lucas
    Shelton, WA
    2000 Tacoma SR5 V6 Xtra Cab All-Black. 203,000 and counting
    Custom RoyEl Canopy and Homemade Bed Drawer for camping sh!t. Improved Cab roof racks. OME Suspension
    Question for ya Joel!
    Looking at a used 122 that doesn't have racks, and wanting to have a plan for adding some before I buy it. Is the highest roof area where you have your bars level or is it slightly lower in the front? do you have those on a track/rail system, or just bolted into the roof?
    Planning on putting my rooftop box up there too, have you done that? Would it be like 100 feet tall and ridiculous at that point?
    Any info or pictures would be much appreciated!
    Thanks in advance!
  4. Jan 20, 2020 at 4:18 PM
    thenodnarb
    thenodnarb Well-Known Member
    California
    2001 TRD 4x4 379k and counting
    i actually don't like the look of the taller shells but i really appreciate the extra headroom when using the bed as a camper.
    QMEDJoe likes this.
  5. Jan 20, 2020 at 7:46 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    The 122 is not level in the back roof, it is tallest at the rear.
    Since you have extended cab you can also fit a reg cab shell, it just pulls away around an inch at the top at the rear truck window and doesn’t look bad. But you can’t fit an ex-cab shell on a regular cab.
  6. Jan 21, 2020 at 12:19 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Sweet truck. How close are the tundra rim's to the upper control arm?? I thought about going that route.
    Had to go back a bit. But it was a plastic camper. I would rock a shell but I'm to tall to sleep in the back with it closed .
  7. Jan 21, 2020 at 4:28 AM
    Hoots Magoon
    Hoots Magoon Well-Known Member
    Rhode Island
    2004 Tacoma TRD
    chrslefty and Blais03 like this.
  8. Jan 21, 2020 at 6:44 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I wish I did! I chose to skimp out and not order them and aftermarket is just too expensive at $400 a piece.
  9. Jan 21, 2020 at 6:48 AM
    QMEDJoe
    Joe
    This is my ARE MX series. Love it. Wished I could of got used but I searched and waited and ended buying new.
    Yota-xsr, Jpsyoda and chrslefty like this.
  10. Jan 21, 2020 at 8:54 AM
    TacomaEli
    TacomaEli Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    I have an ARE with the sliding windows too. Thing leaks like crazy from the windows. I've siliconed around them and taken them out and resealed with butyl tape and they still leak. Have you had any leaking issues?
  11. Jan 21, 2020 at 9:03 AM
    QMEDJoe
    Joe
    Negative, mine leaks a little in one of the corners. I could probably lift it off the bed and reseal it and be fine but I’m just too lazy right now. That’s waaay down on the to do list. :p
  12. Jan 21, 2020 at 10:21 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    @TacomaEli Mine only leaks on the corners where it meets the tailgate. I think because my bed had widened and I have gaps on both sides of my tailgate. Windows have never leaked. If you come up with a solution let me know in case mine start.
  13. Jan 21, 2020 at 10:47 AM
    Zimm!
    Zimm! Well-Known Member
    1999 Extra-Cab TRD 4x4
    I absolutely love the windows on my shell. I got lucky and it came with my truck when I bought it.
    Its especially nice for camping, but also just for organization.
  14. Jan 21, 2020 at 11:02 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I would have guessed no closer than than the stock rims (maybe 1/4").
    I found this on another post in the Tundra forums but I don't know if it's 100% accurate
    The 17" wheels are 17x7.5 with a +18mm offset/5" BS
    I would have to take measurements myself to confirm but I have 255's on and no rubbing or near UCA
  15. Jan 21, 2020 at 11:04 AM
    #35
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Thanks I was really considering running thoes for a while. Do you rub the frame at full lock?
  16. Jan 21, 2020 at 11:05 AM
    #36
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    mine is also leaking and I think it's down to the windows more than likely. I have a bead of silicone up front since there is a gap but I have "truck tape" over the rest. I can feel the carpet wet above so I can assume it's from higher up. I do think I need a new rear window seal but finding a local ARE supplier is scarce.
    QMEDJoe[QUOTED] likes this.
  17. Jan 21, 2020 at 11:06 AM
    #37
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    yes, but that's due to the 1" taller tires. If I ran stock it would be fine, but meh, I have a lift and stock looks goofy :)
    QMEDJoe and chrslefty[QUOTED] like this.
  18. Jan 21, 2020 at 12:05 PM
    #38
    TacomaEli
    Eli
    Roanoke, Virginia
    I think mine leaks from the window and fills up the window track then leak into the metal piece of the shell where you clamp it to the bed and then drips on the bed. Just gotta figure out where that leak is coming from I guess. Frustrating
    frizzman[QUOTED] likes this.
  19. Jan 21, 2020 at 2:04 PM
    #39
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    yep :|
  20. Jan 21, 2020 at 7:07 PM
    #40
    Eisenhower
    Eisenhower Well-Known Member
    Southern Oregon
    2000 Toyota Tacoma XtraCab 4x4
    I like the look of the flat top shells but it's nice having the extra room back there with the raised shell
      File size:
      147.8 KB
      74
