First gen Extended Cab Topper/Camper shell
Discussion in '1st Gen. Tacomas (1995-2004)' started by Carson_SR54x4, Sep 23, 2019.
  1. Jan 21, 2020 at 8:25 PM
    #41
    Dizzle Problems
    Dizzle Problems Member
    2000 Supercharged Taco
    Here’s a side by side, with, without.
    Mine came with the camper when I bought it. Working on a basket/rack set up for it. Gotta button up some leaks, but stoked to have it.
    chrslefty likes this.
  2. Nov 12, 2020 at 5:55 PM
    #42
    JALLENC
    JALLENC Active Member
    Nice to finally see someone local to me on here. Im from Franklin County!
  3. Nov 12, 2020 at 5:57 PM
    #43
    TacomaEli
    TacomaEli Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    Cool man!
  4. Nov 13, 2020 at 7:39 AM
    #44
    sonofdad
    sonofdad Member
    2001 Tacoma TRD Xtra Cab
    looked a long time for a used topper for my 2001, finally bit the bullet and ordered new from ARE. no regrets. +1 on the windoors ... worth every penny.2019-06-19 19.21.58 HDR.jpg
    1stgenAaronSD and yotadude520 like this.
  5. Nov 13, 2020 at 8:35 AM
    #45
    TacoTaco02
    TacoTaco02 Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    Do you guys have any suggestions on how to fix a leaking topper by yourself?
    Mine came with a Glasstite topper that was on it since new but the seals between the topper and bed have been chewed/pulled out by the previous owners dog so water gets in. I don't have the land or garage space to build a topper rig of any sort. I was thinking of removing 2 clamps on one side, loosening the 2 on the other and trying to manually lift it and place some blocks in between while putting on a new gasket. My fear is the whole thing sliding off.
  6. Nov 13, 2020 at 8:45 AM
    #46
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    I used a pair of folding metal saw horses and blocks to hold my cap off bedrails while replacing cheap foam tape with a double beaded rubber cap seal.
  7. Nov 13, 2020 at 8:47 AM
    #47
    Tdog2.7L
    Tdog2.7L Well-Known Member
    2004 Tacoma 2.7l 4x4 & 2018 TRD Sport M/T
    33D42A6C-0546-44DF-A0DA-EC5C8E1708AD.jpg C58B0A67-1C25-41AD-93D5-DAB122D01D60.jpg Anyone have experience with wilderness canopy camper shells? Found this for 2k local. Been in the market for a flip pac but might pull the trigger on this one. Tent isn’t fully setup in the picture
    Akkording likes this.
  8. Nov 13, 2020 at 1:22 PM
    #48
    rtwbound
    rtwbound Well-Known Member
    The Wildernest's and flippacs are both super rare now a days; I wouldn't be too picky, and I'd just buy it, because you may not find another reasonably priced flippac in the near future, or ever.
  9. Nov 13, 2020 at 3:07 PM
    #49
    cdm97
    cdm97 Active Member
    2000 Tacoma TRD
    Custom Interior, Aftermarket Audio, leveled (32/11.5 BFG AT's, Method Standards), Performance Intake
  10. Nov 13, 2020 at 5:21 PM
    #50
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    Does your Glasstite shell look this?
    TacoTaco02[QUOTED] likes this.
  11. Nov 13, 2020 at 11:14 PM
    #51
    TacoTaco02
    Illinois
    Sure does! Just in silver.
  12. Nov 15, 2020 at 4:21 AM
    #52
    Hamer95USA
    :thumbsup::thumbsup::thumbsup:
  13. Nov 15, 2020 at 12:08 PM
    #53
    coldaccord
    coldaccord Well-Known Member
    André
    Buffalo, NY
    2000 Tacoma 3.4L 4x4
    If anyone has/comes across a flat top camper shell in black sand pearl for an xtra cab, I'm in Buffalo, NY but willing to drive a considerable distance!
    MCJohnston likes this.
  14. Nov 15, 2020 at 8:56 PM
    #54
    tobysan1966
    tobysan1966 Member
    Tobias
    Reno, Nevada
    1997 Tacoma SR5 V6 Extra Cab
    Deck plate and resonator delete, turn signal/fog light wiring mod
    Took mine off for a bit when I broke the back glass. Put it back on as soon as I could afford to replace it. Way better with the shell.
    wjktdi, Hamer95USA and chrslefty like this.
  15. Nov 16, 2020 at 3:28 PM
    #55
    Chris311
    Chris311 Well-Known Member
    1999 White Tacoma SR5 V6 TRD OR 5 speed M/T
    3" OME lift, SPC UCAs, URD Crankshaft pulley (the red gives more HP)
    Hello all. I am also looking for a bed topper and am interested in finding one that offers good ventilation for hotter climates. Would be great to find a topper with windows that open on the side to provide a cross breeze, but not have the entire side of the topper completely covered in glass to reduce the greenhouse effect. I plan on using it for short camping trips (1-2 days) and sleep in the bed of my truck, but am hoping to find a setup that will make it comfortable when it is 100+ degrees in the summer.
    Also, how well has everyone's topper been at keeping out rain? I understand that no matter what topper you get, there will always need to be some work put in to make it water tight for using the bed to sleep in.
  16. Nov 16, 2020 at 6:09 PM
    #56
    Hamer95USA
    My truck shell is water tight due to having all of the windows seals replaced and the shell mounted correctly with the rubber gaskets installed by Campway’s in San Jose, CA. I’ve had water leakage in the past from worn out window seals.
    Concerning ventilation, you can install a fan by cutting a hole in the roof of the truck shell and mounting a Fantastic Fan. Another idea is to bring a generator, an air conditioner, and run the air conditioner ducting into your truck shell. Someone else might come up with a better suggestion.
    You have to buy a new or used truck shell with windoors installed already. I don’t think they’re available aftermarket from the manufacturer.
    Chris311[QUOTED] likes this.
  17. Nov 16, 2020 at 11:33 PM
    #57
    Chris311
    I like the Outback from Snugtops, just wish they made one for first gens. I really like the tailgate door, and you can get it optioned with a center sliding window on each side windoor.
  18. Nov 17, 2020 at 12:12 AM
    #58
    Hamer95USA
    I've been eyeballing the Caravan truck shells: https://caravancampershells.com/our-selection/
    I like the design and options offered for their shells. I wander if the interior being metal will have condensation from moisture though. I did notice that they offer to install a small fan to aerate the interior and keep dust out.
  19. Nov 17, 2020 at 3:13 AM
    #59
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I see shells all around me but they’re for rangers, colorados and frontiers. Do any of these fit without being too short/too long or without looking terrible?
  20. Nov 17, 2020 at 6:11 AM
    #60
    MCJohnston
    MCJohnston Well-Known Member
    Matthew
    CT
    02 Tacoma SR5 TRD 3.4L 4x4 X-tra Cab
    I think it’s going to be a test for fit kind of deal. I have an 02 xtra cab and just picked up a leer 122 6x5 and it’s just about 2-3 inches shorter in length and the cab end sits wider than the cab.
