First gen lower ball joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98_3RZ_NIC, Jan 18, 2021.
  1. Mar 4, 2021 at 9:09 AM
    #81
    Kwikvette
    Fresno County
    4 run, 2 don't
    On the plus side, those come with the bolts.
    The 555 set I got from Low Range 2 years ago didn't but I had purchased the bolts directly from Toyota anyway.
    Running Board Man likes this.
  2. Mar 4, 2021 at 9:10 AM
    #82
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Excellent point!
    @AZDude if you Do have the 5 lug truck, you don't have to worry about your lower ball joints like the pre-runner/4x4 guys do.
  3. Mar 4, 2021 at 9:11 AM
    #83
    jbrandt
    Justin
    I got mine from Ace Hardware.
  4. Mar 4, 2021 at 9:20 AM
    #84
    AZDude
    AZDude Well-Known Member
    1996 Tacoma base
    your assumption is correct... it is a 5 lug. That's probably why I can't find 555 for my truck. thank you for the info.
    jbrandt and Running Board Man like this.
  5. Mar 4, 2021 at 9:28 AM
    #85
    AZDude
    1996 Tacoma base
    can you elaborate? is it because there's less stress or is it because you have to grease the 4x4? I'm pretty sure I don't have to grease mine because I can't find any zerk fittings on my 5 lugger.
  6. Mar 4, 2021 at 9:30 AM
    #86
    Kwikvette
    Fresno County
    4 run, 2 don't
    :violent:
  7. Mar 4, 2021 at 9:31 AM
    #87
    jbrandt
    Justin
    It's about the design. The 4x4/Pre-runners have the ball/socket in constant extension. The coil spring is constantly trying to pull the ball away from the socket, so when you get some wear and tear, they can fail, and do so catastrophically. Rather than most ball joint designs where the ball is being pushed into the sock (see the 2nd gen tacoma design).
    It's not about needing to grease them. Generally, for the 4x4s if the boot tears you just replace them.
  8. Mar 4, 2021 at 9:32 AM
    #88
    Running Board Man
    Running Board Man Well-Known Member
    The 6 lug ones are what are called a constant tension design
    When the joint fails the spindle seperates from the control arm with the help of gravity
    AZDude[QUOTED] likes this.
  9. Mar 4, 2021 at 9:33 AM
    #89
    Running Board Man
    I got mine from the truck
    On 6/7 trucks so far
  10. Mar 4, 2021 at 9:34 AM
    #90
    jbrandt
    Justin
    Dude, they were an exact match. Grade 10.9, flange etc.. I also needed slight longer than oem because I pulled the first few threads out of one of the holes (used a short bolt where a long one should have gone. Luckily the holes/threads were plenty deep enough, just wanted a little extra length to maximize the thread contact.
  11. Mar 4, 2021 at 9:36 AM
    #91
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh, I didn't say anything :laugh:
    jbrandt[QUOTED] likes this.
  12. Mar 4, 2021 at 9:36 AM
    #92
    jbrandt
    Justin
    I buy all my stuff off a truck: Watches, car parts, children, etc...
  13. Mar 4, 2021 at 9:37 AM
    #93
    Running Board Man
    I don't trust aftermarket bolts to not be crap
    And Ive never scheduled replacement a week in advance to order them
    But loctite ftw
  14. Mar 4, 2021 at 9:38 AM
    #94
    jbrandt
    Justin
    Grade 10.9 is grade 10.9
    OEM probably aren't even that strong, since they only require 59 ft lbs.
  15. Mar 4, 2021 at 9:40 AM
    #95
    Running Board Man
    That's the thing, there's also the argument a hard bolt is more likely to fracture given the application sees a lot of vibration and shocks as you hit bumps and such
    The ones on my tacoma were reused 5 times by myself and even going through a ditch than in the air at 70 were fine
    Kwikvette likes this.
  16. Mar 4, 2021 at 9:44 AM
    #96
    jbrandt
    Justin
    There's also the argument that you shouldn't re-use your bolts, which you have been doing as well. I guess we're both living dangerously.
  17. Mar 4, 2021 at 9:49 AM
    #97
    Kwikvette
    Fresno County
    4 run, 2 don't
  18. Mar 4, 2021 at 9:50 AM
    #98
    Running Board Man
    We've evolved from doves, to doges
    Kwikvette[QUOTED] likes this.
  19. Mar 4, 2021 at 9:55 AM
    #99
    jbrandt
    Justin
    I'd be lying if I said:
  20. Mar 4, 2021 at 9:58 AM
    #100
    Running Board Man
    That's Mike Tyson
    Past that idk
    jbrandt[QUOTED] and Kwikvette like this.
