First gen. steering wheel play
Discussion in '1st Gen. Tacomas (1995-2004)' started by rab89, Mar 20, 2010.
  1. Mar 20, 2010 at 12:19 AM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    We've talked about this before, there is some play in the steering assembly, does anyone know if the 4 runners have/had the same problem?
    I was thinking of pulling a 4 runner steering assy from the junk yard if they had better luck.
  2. Mar 20, 2010 at 12:40 AM
    john32
    john32 Well-Known Member
    Seaside, Ca
    4x4 Reg cab 2.7L SR5 Manual
    diff breather
    What do you mean by that? play in the steering assembly??
  3. Mar 20, 2010 at 3:58 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    there is about an inch and a half of play side to side in the steering wheel, it's in the upper portion of the steering column.
  4. Mar 20, 2010 at 5:05 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    this little guy work wonders
  5. Mar 20, 2010 at 5:14 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    that's different, I did that too, this is actually in the steering column.
  6. Apr 30, 2010 at 7:32 PM
    shift96
    shift96 Well-Known Member
    I noticed that there are 2 universal joints in the steering column. Maybe one or both are worn or have play in them?
  7. Apr 30, 2010 at 8:10 PM
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    i did this also and it was way better for a couple months. the "play" in the steering sucks most when it makes my truck wonder side to side
  8. Apr 30, 2010 at 8:36 PM
    shift96
    There is a little plastic cover inside the truck on the firewall where the steering column goes through. Remoce the little 10mm screws and pull the cover back and you will see the u-joints. Mine have some slop in them and I'm positive that is the knocking in the steering wheel.
  9. May 3, 2010 at 3:07 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    nice, I'll go check it out!
  10. May 3, 2010 at 3:18 PM
    trucklover63
    trucklover63 Active Member
    illinois
    04 PreRunner sr5
    My steering wanders quite a bit too...Would worn steering rack bushings cause this?
  11. May 3, 2010 at 3:55 PM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Abso-tively! (yes)
    Get the Energy Suspension Uretahne steer rack bushing kit. Cheap and effective
  12. May 3, 2010 at 4:01 PM
    shift96
    My rack was moving around also. I replaced the bushings and feel absolutely no difference
  13. May 3, 2010 at 4:13 PM
    Coolidge
    So Cal, Ca
    2003 Pre Runner
    How many miles on your truck?
  14. May 3, 2010 at 4:38 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Subscribed.. I hate loose steering. :(
  15. May 3, 2010 at 4:57 PM
    shift96
    140k
  16. May 4, 2010 at 8:47 AM
    brg88tx
    brg88tx Well-Known Member
    the steering on my 03 prerunner is very tight, much more so than my previous nissan frontier's.
  17. May 4, 2010 at 8:56 AM
    ywen
    ywen Well-Known Member
    Is this what Toyota quality means? Poorly designed/manufactured steering component leading to premature wear?
    So far in ownership of the Taco, I have not perceived a single benefit of the "toyota quality"
    Mine at 78K exhibits this looseness...
  18. May 4, 2010 at 9:20 AM
    Coolidge
    So Cal, Ca
    2003 Pre Runner
    Weird, my 04 Pre Runner 2wd had over 150K when I totaled it. Never a problem with steering, etc. My 03 I did replace steer rack bushings, only because I removed a DB lift and had to reweld #2 crossmember back, and the stock bushings were burnt. My 03 has only 80K. Now (without 6" DB lift/315's) truck is tight, and drives straight. With the big lift/tires/old bushings it WAS all over the road. I suppose a combo of probs related to that POS lift and 'too big for Tacoma' tires.
  19. May 4, 2010 at 9:59 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    those with steering play, be sure to check your tie rod ends.
    while replacing the rack bushings will prevent the rack itself from moving, if your TRE's are bad, you'll still get play ..and probably some clunking.
  20. May 4, 2010 at 10:00 AM
    shift96
    It's the steering column.
