Smell of gear oil persists after transmission rebuild with no leaks
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kpsnyder, Jan 17, 2024.
  1. Jan 17, 2024 at 1:11 PM
    Kpsnyder
    Kpsnyder [OP] Member
    Kyle
    1998 Tacoma 3.4L manual, 4x4 SR5
    N/a
    Hey y’all,
    So my problem is I smell gear oil when I’m driving with the windows down. Especially on a steep uphill grade in second gear. I never had this issue until I had my transmission rebuilt and a new OEM clutch installed in November of 2022. The smell had never gone away since then. I don’t smell it when parked, at a stoplight, or driving with the windows up. I cannot find any leaks and any excess oil spillage should have burned off long ago. It’s my daily driver. This smell is driving me insane. It’s that gear oil skunky head ache smell. Bad. many ideas on how to fix this issue? I read that maybe it’s over-filled? Possibly more volatile oil than before. Clutch has already been disassembled to check for spillage on pressure plate. It’s fine. Going to try to replace the steering wheel bushing? Maybe the smell is reaching through there and the windows down “vacuum” the smell thru the cab? That was one Toyota mechanic’s theory. Sounds a bit far-fetched to me...
    any ideas or insight is greatly appreciated! fire away!
    Thank you
  2. Jan 17, 2024 at 2:39 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    First thing - check to make sure that the transmission is not overfilled.
    Second thing - check the breathers. Front diff, transmission, and rear diff. one or all could be not working properly. For the manual transmission- look for write ups replacing the shift lever bushings, they'll have info on what's going on around that area.
  3. Jan 17, 2024 at 3:06 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    Fluid Level
    Bushing/Boot
    Breathers
    Pinon?
    Kpsnyder[OP] likes this.
  4. Jan 17, 2024 at 3:17 PM
    RandyLahey
    RandyLahey Well-Known Member
    Southwest PA
    2013 sport 6mt
    I imagine the shifter bushings would have been replaced during a rebuild, have you crawled under there to see if you notice any gear oil leaks? A plugged breather would be my guess, I intentionally overfill my r150 by a small amount and it doesn’t smell
  5. Jan 17, 2024 at 6:21 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Is the transmission tunnel sealed off from the interior? That would do it.
  6. Jan 17, 2024 at 10:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    No. It is not sealed off.
    Both the tcase and the trans have vent tubes that "T" together near the top of the shifter and a single tube goes from there to the engine bay to the driver's side frame rail below the brake master cylinder. I can envision a scenario where those vent tubes are not hooked up correctly and are allowing vented off-gassing to enter the cab from the shifter boot area.
    Kpsnyder[OP], Bivouac and Madjik_Man like this.
  7. Jan 18, 2024 at 5:02 PM
    MadNachos
    Well, yeah, the t-case and trans have vents but I was asking if the tunnel isn't sealed off anymore because of missing rubber. It doesn't take much for the stank from the vents to make it's way into the cab if the shifter isn't sealed off anymore especially if you crack the windows and it pulls the smell into the cab.
    Kiloyard and Kpsnyder[OP] like this.
  8. Jan 18, 2024 at 5:18 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Mine smelled like that when the shifter seal to the transfer case was bad. I’d pulll the interior plastic and have a look.
    Kiloyard, Kpsnyder[OP] and MadNachos like this.
  9. Jan 18, 2024 at 6:15 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Andy01 is correct
    I had same issue
    Found both tranny AND center diff overfilled
    my smell was coming from both breather tubes, slowly seeping out making that smell
    Btw
    (This was on awd Subaru….2001 fozzie)
  10. Jan 18, 2024 at 6:34 PM
    MadNachos
    My wife reminded me of an old Land Rover we had decades ago that I filled the t-case with some gear oil that just stunk. Like 'gonna vomit' bad. She walked into the garage when I drained it and she isn't a fan of the memory. So it could just be stank oil.
  11. Jan 19, 2024 at 2:07 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I pretty much like this for the problem!
  12. Jan 19, 2024 at 4:38 PM
    Kpsnyder
    Kyle
    N/a
    Thank you all so much for the replies!
    I love Tacoma world
    Ok, going to check to see if they are overfilled. Going to check the shifter seal and going to check breather tubes on transmission, t-case, front and rear diffs.
    Maybe replace the tranny oil with fresh Lucas oil or Amsoil if I can get my hands on some. I hear that or Redline is the best.
    Will get back to y’all as soon as I can which may not be for a few days as I don’t have my truck right now
    thank you all again so much, I’m so grateful
    MadNachos, Currygoat and Digiratus like this.
  13. Jan 20, 2024 at 5:56 PM
    beaverdamland
    beaverdamland Well-Known Member
    97 Xtracab MT 3.4
  14. Jan 22, 2024 at 9:35 PM
    MadNachos
    Skip the Lucas, run the Redline :)
  15. Sep 23, 2024 at 10:11 AM
    Kpsnyder
    Kyle
    N/a
    UPDATE:
    I apologize for the long overdue update but better late than never. I drained the gear oil from the transmission and refilled it with Redline MT 90 using a hand pump. Smell went away pretty quickly and it has not returned. I figure it was over-filled or maybe they used the wrong oil at the shop or maybe both. Either way it’s fixed and I couldn’t be happier. Thank you all for your help!!!
    ControlCar likes this.
  16. Sep 23, 2024 at 2:48 PM
    ControlCar
    Steven
    Sugar Land TX
    awesome!!!!!!!
    me and Andy01 nailed it!
    thanks for updating thread Kpsnyder
