First gen tacoma pinging
Discussion in 'Performance and Tuning' started by tacoman2001$, Oct 18, 2023.
  1. Oct 18, 2023 at 5:14 AM
    tacoman2001$
    tacoman2001$ [OP] Well-Known Member
    On the freeway I seem to get a pinging sound. Sounds almost like a chain rattle but I guess it's pinging. I can watch the afr lean out. Got half way to work before it started happening. Was happening around 2k rpm going up hills. Just seeing what others have done to fix their pinging. FYI supercharged.
  2. Oct 18, 2023 at 10:27 AM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    running lean or rich won't do this. it your timing.
  3. Oct 18, 2023 at 3:51 PM
    tacoman2001$
    Put fresh 93 in it and it seems to help a lot. Going to try some vp racing octane booster and see if the problem gets better.
  4. Oct 18, 2023 at 3:51 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Running lean can definitely impact
  5. Oct 18, 2023 at 3:53 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    You should not have to run high octane, but if the sounds goes away because of it then that's a great way to confirm that there is an issue.
  6. Oct 18, 2023 at 3:54 PM
    tacoman2001$
    I'm a bone head. I forgot to mention it has a second gen supercharger on it.
    treyus30[QUOTED] likes this.
  7. Oct 18, 2023 at 3:57 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Ah, well then yes you are pinging, and yes running lean is probably why if it hasn't always done this. Do you have ECU management? How lean are we talking?
  8. Oct 18, 2023 at 3:59 PM
    tacoman2001$
    No stock ecu. I just put the kit on and I noticed today. I've seen 15 or 16 to 1. I wonder if something is up with my fpr. I do have a boost gauge teed into it. Wonder if that's causing me problems.
  9. Oct 18, 2023 at 4:30 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Yikes. Are you in boost when it pings?
  10. Oct 18, 2023 at 4:35 PM
    tacoman2001$
    It usually pings around 0 boost. The pinging has gotten a lot better with fresh gas. The leanout still scares me though. Tomorrow I will look over the fpr and vacuum lines. I feel if I fix that my pinging will get better too.
  11. Nov 5, 2023 at 5:49 PM
    tacoman2001$
    Update. Installed new maf and added some vp racing octane booster. Still get occasional pinging but runs much better no leaning out. Pinging could be partially caused by heavy 33s with no gearing.
  12. Nov 5, 2023 at 6:22 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Ultimately you need to find a way to retard ignition timing. Higher octane fuel does help, but if there isn't enough of it then it can't help. Typically the stock computer targets 14.7 to 1 afr in all situations except Wot. This isn't good for a boosted engine. It is also running a NA timing map and can't pull enough timing when knock is detected since the factory map wasn't intended to go that low.
  13. Nov 6, 2023 at 7:40 PM
    tacoman2001$
    Yes the knock sensors aren't active until 3k rpm. I have noticed the pinging isn't a problem until I get heat soak. I think methanal may be a solution. Yes, ultimately the right solution is to run a standalone and get it tuned. Monitering afrs and once in boost it does go rich. I see mid-12s. The computer can pull lots of timing up to 20-something degrees. The problem is I only get pinging around 2k rpm. Knock sensors aren't used until 3k rpm. I think running some water meth and running the right gears should be the fix.
  14. Nov 6, 2023 at 8:07 PM
    Jon64l
    Jon
    You might consider the 7th injector kit. Pulls timing, adds fuel, no extra resivours to monitor/refill. Easy and works.
