First Gen tail lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by SKelly402, Aug 21, 2025.
  1. Aug 21, 2025 at 5:48 AM
    SKelly402
    SKelly402 [OP] Member
    Seth
    2004 SR5 2.7L
    none...yet
    I'm struggling to chase wires on my right tail light. I have 7 volts on the right, 12 on the left. When I unplug the right assembly the left drops to 7 and I loose the right license plate light. Am I missing something obvious?
  2. Aug 21, 2025 at 6:06 AM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Check and clean all of the grounds: even ones which would seem to have no relation to a tail-lamp. Classic symptom of a bad/corroded one somewhere. Maybe a rusty one or a broken wire. They can cause a lot of strange issues.
    Add some pics of your truck when you get a chance.... We like Pics!
    Welcome to TacomaWorld! :thumbsup:
  3. Aug 21, 2025 at 6:11 AM
    SKelly402
    Seth
    2004 SR5 2.7L
    none...yet
    I chased it last night for a couple hours and got no where. Basically all the wires near the rear bumper came out. I'll remove and clean all the grounds I can find. Would the trailer lights mess with it?
  4. Aug 21, 2025 at 6:26 AM
    Clearwater Bill
    Billy
    Largo Florida
    Very possible. Is it factory or aftermarket wiring?
  5. Aug 21, 2025 at 6:28 AM
    SKelly402
    Seth
    2004 SR5 2.7L
    none...yet
    I'm guessing after market. It is apart of the tail light assemblies but it looks like terrible craftsmanship. I did test the trailer plug but I don't remember what it read.
  6. Aug 21, 2025 at 6:40 AM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I would remove the trailer harness especially if it looks like a poor installation. I have seen trailer wiring harnesses cause all kinds of gremlins.
  7. Aug 21, 2025 at 7:06 AM
    Williston
    They can: Do the truck tail lamp problems only occur when the trailer is plugged into the truck connector? If so, check all of the wires and grounds on the trailer as well. Sometimes, if the trailer plug on the truck is seldom used, it can get corroded a bit just from sitting. Try plugging it in/removing it a few times and see if the problem goes away, or clean it with a small wire brush, (lights OFF!!) :eek: :facepalm:and put a little dab of bulb grease on the terminals.
  8. Aug 21, 2025 at 7:08 AM
    SKelly402
    Seth
    2004 SR5 2.7L
    none...yet
    I just bought it a Friday. The aftermarket receiver doesn't look used at all. I have yet to put a trailer behind it.
  9. Aug 21, 2025 at 7:10 AM
    t0p_d0g
    I suspect the trailer harness is going to be your issue.
    Williston likes this.
  10. Aug 21, 2025 at 7:10 AM
    SKelly402
    Seth
    2004 SR5 2.7L
    none...yet
    I hope that's it
  11. Aug 21, 2025 at 7:11 AM
    t0p_d0g
    :fingerscrossed:
  12. Aug 21, 2025 at 7:22 AM
    Williston
    Good: That should eliminate the trailer wiring as the source of the problems and isolate the issue(s) to the truck as there is nothing connected to the trailer
    harness/plug.
