First Impression of 2011 TRD V6
Discussion in 'New Members' started by GeoTaco1, Jan 9, 2011.
  1. Jan 9, 2011 at 12:35 PM
    GeoTaco1
    GeoTaco1 [OP] Well-Known Member
    Geo
    11 Tacoma TRD Off Road
    NEW Toyo TIRES Bed Cage to hold 120 LBS of sand and fishing rod holder, window air deflectors, Bug Deflector, & finally Avid Light Bar and step rails....
    I am up to 150 miles and half tank; Assuming a 16 gallon tank, I am pushing 19MPG.
    Drives well on highway, but I noticed a slight engine/trannie vibration aroung 60 -65 MPH?? Is that normal? Accelerates well, and down shifts well when punched. Although there was strong side wind truck stayed on course (maybe the 240 lb sand bags help).
    I am also noticing that from stop the fisrt gear is not very smooth; I am not sure if it is caused by the tranny, rear end, or the ruggerd trail tires? It feels choppy, and the initial acceleration is not shooth. I wonder if the tires are doing this? It smooths out after the initial 5-7 seconds.
    Thanks for your input, as I am a Tacoma newbie! (Not a automotive newbie, as I have rebuilt many Camaros, T/As, Blazers when I was younger and had more free time!).
  2. Jan 9, 2011 at 12:36 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    welcome, but you have a 21 gal fuel tank
  3. Jan 9, 2011 at 12:44 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    really 21? I thought it was 20.
  4. Jan 9, 2011 at 12:47 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    yep, 21.1 to be exact! :D
  5. Jan 9, 2011 at 8:22 PM
    GeoTaco1
    Geo
    There is more vibration in the gas pedal than the brake pedal, which make me think it is more likely engine, trannie, mounts???:confused: It is not noticable, most drivers would not notice it....but I am a looking for perfection on a brand new turck.
  6. Jan 9, 2011 at 9:37 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Even closer... it is an 80 liter tank, so 80/3.785= 21.136 gallons! :rolleyes:
    The gauge has a reserve built in as well... below the first 1/4 tank.
    At 3/4 tank line, you are close to right on, down 5 gallons (vs. 5.25)
    At 1/2 tank line, you are only down 9 gallons (vs. 10.5)
    At 1/4 tank line, you are only down 13 gallons (vs. 15.75) with 8 gallons still.
    When the E Light comes on, you are down 17 gallons (4 still in tank)
    At the E line, you still have about 2.5 gallons in the tank.
