First Lift 2019 TRD Sport-Newbie Needs Advice
Discussion in 'Suspension' started by shad951, Oct 3, 2019.
  1. Oct 3, 2019 at 6:25 PM
    shad951
    shad951 [OP] Member
    '19 Cement TRD Sport
    Hi fellow Taco owners. I just bought a 2019 TRD Sport dual cab short bed. My last Taco was a 2012 that I left bone stock. On my new Taco I am wanting to put 275/70-R17's on the TRD 4-Runner Pro wheels which seem to be very popular. I realize that the 265/70-R17 tires are the biggest recommended tires without any lifts. I would like to do a lift that will accommodate the 275's without rubbing and just give the truck a taller/beefier look without breaking the bank. What are my options for what I am looking to adding with bigger tires? I have read the stickies posted and learned a bit reading all the links. Appreciate any recommendations in advance!
    Joe.Dirt likes this.
  2. Oct 4, 2019 at 8:47 AM
    redfishh20
    redfishh20 Member
    Oregon Coast
    2017 TRD Sport
    following
  3. Oct 4, 2019 at 12:14 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    You can just do a bilstein 5100 up front if you would like but the stock measurements on the tacoma is 21 inches up front and 22 inches. It doesnt take too much to fit a 275 but if you want to lift all away around is you can put the 5100 at a higher c clip setting and add a block or AAL in the rear and fit that tire size with no issues and call it a day.
    shad951[OP] likes this.
  4. Oct 4, 2019 at 12:49 PM
    ruffman
    ruffman Well-Known Member
    2019 Tacoma SR RWD
    I'm rarely off-road (fishing holes and to hunt camp) so I decided to add a 2" spacer in the front and a 1.5" block to the rear. I bought my set-up from supreme suspensions. Cost fit my budget and it was fairly easy to install. Not sure if it would accommodate 275/70-R17's without new UCAs or some trimming.
    shad951[QUOTED][OP] likes this.
  5. Oct 5, 2019 at 4:56 PM
    shad951
    shad951 [OP] Member
    Thanks for the advice. That sounds like the way to go for what I am looking for.
