First lift!
Discussion in 'Suspension' started by amyonech, Jul 26, 2014.
  1. Jul 29, 2014 at 11:33 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Pretty much this..
    Amy, from what you describe as needs an upgrade to the 5100's will pretty much give you what you want for well under $500.
    Some of these guys are forgetting about $$$ budget restraints
  2. Jul 29, 2014 at 11:51 PM
    TRDh4vok
    TRDh4vok Well-Known Member
    Gil
    Palm Beach County
    '09 TRD PreRunner Sport
    -4" MaxTrac Spindle lift -5100 RCD Bilstein's -1/2" Strut Spacer driver's side (Taco Lean fix) -1/4" Strut Spacer passenger side (Taco Lean fix) -4" Tapered Blocks -Extended length U bolts -Front Skid Plate -Exhaust Tip -Tube Steps - Silver -Bed Extender -LEER Tonneau Cover -Rampage Roof Cab Lights -Rampage Tailgate Light Bar Six Function SUPERBRITE with Reverse Lights, Running Lights, Brake lights, Emergency Hazard and L & R turn signals -exLED Toyota Tacoma Custom interior LED Light Kit -PIAA Xtreme White Plus head lights and fog lights -NITTO Terra Grapplers 285-70-17 -30" Avec CR-Series Led Light Bar in bumper grill -Two 6.5" Led light bar's attached to the A pillars -Hood hinge bracket mounts from Famous Fabrications -Exhaust muffler Aero Turbine AT2525XL -OEM Roof Racks -OTTRAW Rocker switch -Stant locking gas cap -Large T emblem and mid mount bracket from Diaz Fabrications
    If that stock ride and feel is so important to you then the best and easiest lift for you is a spindle lift. Assuming you are 2 wheel drive. But it will be a little higher than what you are looking for... 4". Check out the MaxTrac Spindles at Headstrongoffroad.com
    The rear you could put 5100 RCD billes with AAL's or blocks.
  3. Jul 30, 2014 at 4:16 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Actually, as our trucks age, our springs are known to sag quite a bit. (Lots of threads on this). If you are after a stock ride I would strongly recommend you stay away from blocks. Their torsional leverage speeds up the spring wear and will create wheel hop eventually. AAL upgrades, or lifted springs as budget allows is a much better route for us.
  4. Jul 30, 2014 at 4:38 AM
    UNDEAD1153
    UNDEAD1153 Well-Known Member
    Weston
    Chattanooga Tennessee
    White 2011 TX Pro Double Cab
    Rough Country 6" lift, 17" XD Addicts, 315/70/17 Nitto Trail Grapplers, 6K HID's, Wet Okole's, Kenwood DD head unit, Custom Exhaust
    I've got a jeep and it's not the lift itself that messes everything up and leads to death wobble. It's the extra strain that the lift puts on the rest of the drivetrain. Just causes parts to go bad a lot faster and when it's already an old jeep that could use new parts like ball joints, ujoints, bushings, etc. it makes things a lot more noticeable.
    But like stated above, the bilstein's 884 or 885 coils, and a new full leaf pack is going to be a solid lift for what you are looking to do.
  5. Jul 30, 2014 at 6:28 AM
    amyonech
    amyonech [OP] Active Member
    Amy
    Long Island, New York
    14 SR5
    Running board, LED interior & plate, weathertech mats. More to come.
    haha thank you. I have been heavily advised to stay away from blocks.
  6. Jul 30, 2014 at 6:31 AM
    amyonech
    Amy
    14 SR5
    Ahhh! I understand, that makes sense. I think I'm definitely going to go with a bilstein kit.
  7. Jul 30, 2014 at 6:36 AM
    Outbound
    Outbound Well-Known Member
    double cab short box
  8. Jul 30, 2014 at 6:39 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
