First Mod-Black Headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZachMX, Oct 21, 2011.
  1. Oct 21, 2011 at 11:08 AM
    ZachMX
    ZachMX [OP] Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Finally did my first mod this morning with some help from the guys on the forum, ChrisNJ's write up, and a bit of toying. Next is new tires with some grip and a grill. That pesky third screw everyone mentions was a pain! Ended up removing part of the inner wheel well plastic piece and crawled up under to reach it, in my opinion is the only way since there's really no room up front to wiggle in there. Took about an hour and managed to get all the screws back in including that third one. Here's a pic (sorry the sunlight is bad out front, and the garage is filled with my other toys). Zach
  2. Oct 21, 2011 at 11:17 AM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    Nice!
    I'm getting ready to try this as well...found a set of stockers to use...
    There is a thread on headlight removal with pics that explains the procedure for removing the "fourth" screw...
    any leaks in the lights yet? what did you use to seal?
  3. Oct 21, 2011 at 11:18 AM
    meantaco
    meantaco Well-Known Member
    Andres
    2005 Prerunner. Gone,but not forgotten.
    Retrofit,bull bar,hellas and color matched grill.
    looks good!:thumbsup:
  4. Oct 21, 2011 at 11:23 AM
    ZachMX
    I copped out and went the route of purchasing the revotec ones (all the members have had no issues with leaks) about $150. That 3rd screw is a b*tch, I would recommend removing the bottom two screws at on the inner wheel well piece and pulling it back, gives you plenty of room to reach up in there. Ya I used ChrisNJ's thread with the pictures, he shows you the screw but not really how to get to it, so I had to figure that part out. Let me know if you need some help and I can take pics of the screws from the piece I pushed back to get to it. Good luck!
